Question about Nokia 7270
WANT TO CHANGE RIGHT NAVIGATION KEY FROM WEB2GO TO SOMETHING ELSE
  • 524 Answers
Hi...
To select a function for the right selection key for some other
functions,
press Menu, ----> select Settings,------> Personal shortcuts.
Select Right selection key to set a function for the right selection key. Scroll to a function and select it.
thanx
Posted on Jul 17, 2010
Nokia 302 change language
Find "Device language"
  • Press the Navigation key.
  • Scroll to Settings and press the Navigation key.
  • Scroll to Device and press the Navigation key.
  • Scroll to Language settings and press the Navigation key.
  • Scroll to Device language and press the Navigation key.
2. Select language
  • Highlight the required language and press the Navigation key.
3. Exit
  • Press Disconnect to return to standby mode
Jul 06, 2014 | Nokia 6220 classic Smartphone
N95
HI,
To change the date on your Nokia N Series or E Series, follow these instructions:
* Click on the Menu button, highlight Tools and click the centre selection key (the ‘OK’ key)
* Highlight Settings and click the OK key
* Highlight General and click the OK key
* Highlight Date and time and click the OK key
* Highlight the date and click the OK key
* Use the Right Navigation key to highlight the year. To change the year back one year, press the Down navigation key once.
* Press the Red “End” key to return to standby mode.
Aug 05, 2008 | Nokia N95 Cellular Phone
I need to set up a security code to delete my recent calls how so i set one up
From the home screen press the RIGHT SOFT KEY (Soft keys are located above the center navigation key on the Right and Left sides, usually denoted with a horizontal line on the key)
Scroll to the SETTINGS option and press the CENTER NAVIGTATION KEY to make the selection.
Scroll to the PHONE SETTINGS option, and press the CENTER NAVIGATION KEY to make the selection.
Scroll to the SECURITY option, then press the CENTER NAVIGATION KEY to make the selection.
Scroll to the PHONE LOCK option, then press the CENTER NAVIGATION KEY to make the selection.
Scroll to the desired option, then press the CENTER NAVIGATION KEY to make the selection.
THE DEFAULT SECURITY CODE IS 0000 (4 zero's)
To change the current code, scroll to CHANGE CODES, then use the CENTER NAVIGATION KEY to make the selection.
Scroll to desired code, then use the CENTER NAVIGATION KEY to make the selection.
Enter the security code, then use the CENTER NAVIGATION KEY to confirm the code.
You will be prompted to enter a new security code, ENTER THE NEW CODE and use the CENTER NAVIGATION KEY to confirm the new code. You will do this twice. I hope that you have found this information useful, and if I can be of further assistance, please let me know. Thank you for using fixya!
Jul 11, 2013 | LG A340 MobiPhone - Silver AT&T A340
My samsung monte slide makes a beep when i send a text, how do i stop this from happening
Choose settings for profiles info.png 1 Find "Profiles"
  • Press Menu.
  • Scroll to Profiles and press the Navigation key.
2 Select profile
  • Highlight the required profile and press Options.
  • Scroll to Edit and press the Navigation key.
3 info.png Select settings for incoming calls
  • Highlight one of the following options:
  • Call alert type, go to 3a.
  • Call ringtone, go to 3b.
  • Message alert type, go to 3c.
  • Message alert tone, go to 3d.
  • Keypad tone, go to 3e.
  • Volume, go to 3f.
3a "Call alert type"
  • Highlight the required incoming call alert and press the Navigation key.
3b "Call ringtone"
  • Highlight one of the following folders:
  • Default melodies
  • Sounds
  • Music
  • If you select Default melodies:
  • Highlight the required ring tone and press the Navigation key.
  • If you select Sounds or Music:
  • If required, highlight a folder and press the Navigation key.
  • Highlight the required ring tone and press Select.
3c "Message alert type"
  • Highlight the required message alert and press the Navigation key.
3d "Message alert tone"
  • Highlight the required message tone and press the Navigation key.
3e "Keypad tone"
  • Highlight Mute or the required key sound and press the Navigation key.
3f "Volume"
  • Highlight the required category and press Navigation key right or Navigation key left to select the required volume.
  • Press the Navigation key to save.
4 Exit
  • Press Disconnect to return to stand-by mode.
Jun 25, 2011 | Cell Phones
Hello sir my name is makarand kelkar i'm 4m mumbai my cell phone is nokia 5130 my cells kye pad is not work properly means navigation key of left & right & also go to key and music kye...
The Navigation key set can be changed, it will cost around Rs.250.... Just take it to a mobile repair shop and ask them to change the key navigation board. It is very simple, even you can buy the spare and change it yourself... But the music keys I'm Not sure they will work or not, because it is a well known complaint in Music series of Nokia and nothing can be done properly(so don waste time in spending money for music keys)...
May 13, 2011 | Cell Phones
Hi! Everytime I touch my phone screen, the web2go always opened. I don't know if I did something to make it like that or the real problem is the screen. I hope you will reply as soon as possible. Thank...
Hi! Usually when you try to access the internet/cellular data, Web2go will come up asking you to sign up for a data plan. Make sure that applications are not trying to access the internet and by making sure you are not touching anything that may access the internet. If a slight touch triggers the Web2go page make sure your screen is responding to where you touch. Phone model and brand will be helpful.
Mar 08, 2011 | Cell Phones
I want the keytone to be silent - how do I set it to silent?
You have to do the following:
Sound Profile
You can customize various sound profiles for your phone by
changing the sound settings.
1. In Idle mode, press the Menu soft key and select Settings
➔ Sound Profile.
2. Highlight one of the following sound profiles:
• Normal
• Silent
• Driving
• Outdoor
3. Press the Edit soft key to access the sound settings.
4. Press the Change soft key to change the "phone" option.
• To move between the various tabs, use the Left and Right Navigation
keys.
• To highlight individual options, use the Up and Down Navigation keys.
• To change the setting for a highlighted option, press Change ( ).
There you have these options:
– Keypad Tone: allows you to choose between Beep, Xylophone, and
Mute (no tone) for keystrokes on the phone.
– Power On Type: allows you to select the way in which the selected alert
is played when the phone is powered on.
• Melody: the phone sounds the selected melody.
• Vibration: the phone vibrates.
• Vibration & Melody: the phone vibrates and also plays the
melody.
• Mute: the phone neither vibrates nor plays a ringtone. The only
indication of a message is an alert on the display.
5. Press the Save soft key when you are finished.
Normal Profile
To access the available options for this sound profile, press the
Edit soft key.
keys.
• To save your changes, press the Save soft key.
This should do it.
If you still have some problems please download following manual and go to page 69 where you find all related info.
Propel Manual
.pdf
Hope it helped.
Nov 20, 2009 | Samsung Propel A767 Cell Phone
I want to change it so there are no key pad tones. also, i'd like my alarm clock to be on the right hand corner of my screen, not the web2go button...
Go to settings on your phone menu and go to sound and change key pad tones to silent or none or volume zero then for the buttons go to shortcuts and on the right soft key change from web to alarm clock! if not then this setting may not be available on your phone.
Nov 11, 2009 | Samsung Gravity SGH-T459 Cell Phone
My spouse changed my security and phonelock codes
Try this out:
  • Press Menu
  • Use the Navigation Key to scroll to Settings and press the Center Select Key
  • Use the Navigation Key to scroll down to Security and press the Center Select Key
  • Use the Navigation Key to scroll down to New Passwords and press the Center Select Key
  • Use the Navigation Key to scroll down to Unlock Code and Press the Center Select Key
  • Press the keypad to Enter Old Unlock Code (Default 1234) and select OK by pressing the right soft key. If you have forgotten the unlock code, press Menu and enter the Security Code (000000)
  • Press the keypad to Enter New Unlock Code and select OK by pressing the right soft key
  • Press the keypad to Re-enter New Unlock Code and select OK by pressing the right soft key
Nov 10, 2009 | Motorola Mobility RAZR V3m Cellular Phone
Any way to change the soft keys?
Go to your "settings", then to "display" and you should see an icon that titles "navigation keys". Click on this icon and from this application you should be allowed to change your basic navigation keys to fit your own preference. Hope this helps! Thanks.
Mar 13, 2009 | Cell Phones
Nokia 7270 Logo
124 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
