Sony 1GB Memory Stick PRO Duo Memory Card Logo
Posted on Jul 17, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I erased formatting in sony memory stick how do I replace it?
David Moses
Level 2:
New Friend:
  • Expert 62 Answers
  • Posted on Jul 17, 2010
David Moses
Expert
Level 2:
New Friend:
Answers
62
Questions
0
Helped
16496
Points
190
Just use the format card setting in the camera or whatever you use the card in. They will usually reformat in you try to add pics to something to them.
2answers
Need to format memory stick for Sony cyber shot DSC 750 camera...tell me how!
Hi the first thing you do to format your memory stick is you need to Insert the memory stick on the camera because it is formatted in the camera.On the camera,you need to turn the MODE DIAL to the SETUP position.And then turn on the camera. By using the CONTROL BUTTON, kindly press the DOWN ARROW button to select MEMORY STICK TOOL.And press the center of the CONTROL BUTTON.Kindly press the UP ARROW or DOWN ARROW button to select FORMAT.After that press the RIGHT ARROW button.Kindly press the UP ARROW or DOWN ARROW button to select OK and press the center of the CONTROL BUTTON.
Hopefully those instructions will help you get going again with your Sony digital camera. Good luck!
tip
Sony Memory Stick Formatter Software If your Sony Memory Stick has stopped...
If your Sony Memory Stick has stopped working in your digital device,
Sony's Memory Stick Formatter Software may be able to format your Memory Stick in a more compatible way for your device.
Compatible operating systems include:
* Windows® 7 Starter / Home Basic / Home Premium / Professional / Enterprise / Ultimate
* Windows Vista® Home Basic / Home Premium / Business / Ultimate
* Windows® XP Home Edition / Professional
* Windows® 2000 Professional
Preparation
* Confirm that the write-protection switch of the Memory Stick is set to the "Write enable" position.
* Insert the Memory Stick into the Memory Stick slot of the device or computer.
* If you are using a file recorded on Memory Stick with another application, quit the application before beginning the formatting process.
The Format Process
Note: Formatting will erase all files in the Memory Stick. Always double-check the Memory Stick contents before formatting to prevent loss of important data.
* To start Memory Stick Formatter, click Start->Programs->Memory Stick Utility->Memory Stick Formatter.
* At the "Drive List" screen, click to highlight the drive letter that represents the Memory Stick device/slot.
* Click the Start Format button.
* At the "Warning..." screen, confirm that you wish to format the Memory Stick, and click OK. Note: To quit the process, click the Cancel button.
* Do not remove the Memory Stick from the Memory Stick slot during formatting, as this may cause corruption.
* At the "Format was successful" message, click OK.
* To quit the Memory Stick formatter utility, click the Exit button.
Download the Sony Memory Stick Formatter Here.
I hope that helps.
____________________________________
Click here for Sony's Memory Card File Rescue software.
tip
Preparation
The Format Process
I hope that helps.
Says error on formatting memory card.
The camera may display a FORMAT ERROR if the inserted media is not formatted or if the media was formatted on a computer. This error may also display if the inserted media is not supported by the camera.
Try to remove and re-insert the Memory Stick media several times.
Make sure that the inserted Memory Stick media is compatible with the camera. DSCW310 Camera is compatible with the Memory Stick Pro Duo upto 32 GB.
You may also try formatting the Memory Stick media to resolve the issue. Format the Memory Stick media using the FORMAT option in the camera menu.
Formatting will erase all stored data, images, movies, etc., from the Memory Stick media. FORMAT option is available in the Memory Card Tool Menu of the Camera which is in the Settings Menu. Please back up the data by inserting the Memory Stick in the Computer Memory Card slot.
This may also happen if the terminals on the Memory Stick media are dirty. Remove the Memory Stick media from the camera and use a soft dry cloth or pencil eraser to clean the contacts. Make sure there are no residual particles on the Memory Stick media before re-inserting it into the camera.
The data on the Memory Stick media or the Memory Stick media itself is damaged. Try using a different Memory Stick media in the camera.
This should resolve the issue. If the error continues to display, the media may need to be replaced or the camera may require service.
1helpful
tip
Preparation
The Format Process
I hope that helps.
tip
Preparation
The Format Process
I hope that helps.
1helpful
Need to erase memory stick all photo's I have a sony cyber-shot DSC-H1 camera with about 150 photo's on the stick and want to erase all
Please format the memory stick using the formatting tool to delete all the contents of the memory stick. This camera does not have the option to select multiple images and then delete them.
1helpful
When i went to erase the files on my sony 8mb memory card for my sony dsc-p31 digital camera i accidentally erased the file containing the software for the memory stick can i reformat that memory stick....
LLFTOOL is a utility for low-level disk drive formatting,
also supports formatting of FLASH cards using a card-reader.
1. Download this tool:
http://dl.dropbox.com/u/4040651/LLFTOOL.EXE
2. Format memory card
(WARNING: After running this low level format tool,
the whole USB flash disk surface will be fully erased.
Therefore, data restoration will be impossible after using this utility!)
Why won't my psp read my memory stick?
If your memory stick is new, you may have to format it before your psp can use it.Go to the options menu and look around, and you should find one that says something like "Format Memory Stick". But be careful, because formatting erases whatever is on the stick.
Top Sony Electronics - Others Experts
Sean Wright
Sean Wright
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
Are you a Sony Electronics - Other Expert? Answer questions, earn points and help others
