Question about Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System
How do you get the water filter out of refrigerator so you can replace it
    Scholar:
  • 121 Answers
Without knowing your particular model number, I checked and most 25 cu.ft. side by sides have the water filter in the grille. You just push a release button and it pops out. There is a cap on the filter, do not through it away as you will need it on a new filter. Also ensure the O-ring protective covers are removed on the new filter prior to installing. You can run the water dispenser without a filter as well. Here is a link to the PDF for one type of 25 cu. ft. Whirlpool side by side.
http://www.whirlpool.com/assets/pdfs/product/ZUSECARE/GS5VHAXWA_Use%20and%20Care_EN.pdf
Posted on Jul 17, 2010
Why my refrigerator is leaking water from the top where the water filter is located?
Shut off water supply valve. Relieve water pressure by dispensing water. Unscrew water filter. Examine to see if the gasket is damaged or if filter was loose and just needed tightening. Or simply replace water filter with the correct water filter that your GE refrigerator calls for.
Jul 19, 2014 | GE Refrigerators
Water dispenser leaks when getting water . This is Frigidare refrigerator , is it the valve on back ?
Hello Marie Baxter: If you suspect the water dispenser is leaking, make sure it is the hoses coming from the filter and not the actual filter.
Sometimes the clamps on the hoses for fridge water filters can come loose or the hose itself could crack; in which case the hose would need replacing (or tightening the clamp), and not the filter.
If you clearly find the filter is leaking, the best thing to do is make sure it is installed properly.
If it is securely in place, then you may just have a defective filter and changing it will solve the leaking.
You will need to remove the filter, which is typically located in the back of the refrigerator and inspect it to see what condition it is in.
•For instance, if it is black or looks dirty, you probably will want to replace it.
•Moreover, when there is a leak or a clog, you will notice a dramatic decrease in the output of the water dispenser tab, which is another sign there may be a leak in the water filter. If you know the water filter in your refrigerator is leaking, then you can take the water filter out and see if it has anything loose on it, but typically if it is leaking, it probably is best to replace the water filters for refrigerators.
•This is especially true if you use the filtered water from the refrigerator as your main home water filter systems.
•Moreover, if it has been awhile since you changed the filter; it can become clogged over time, which can cause it to leak.
When you are faced with having a leaking filter refrigerator water unit, it helps to think through the pros and cons of fixing the leak vs. replacing the refrigerator water filter.
Apr 19, 2013 | Electrolux 25.9 Cu. Ft. Side-by-Side...
Water filter is leaking in water pan under refrigerator
Pull the refrig away from the wall , It is on rollers. Next locate the valve for the water and turn it off untill you can replace the filter. You can get replacement filters at most appliance stores or sears.
Aug 01, 2012 | Frigidaire FRS3R5EMB Side by Side...
We are trying to replace the ice maker filter on a Maytag mf2557hes. Where is it located? Does this Maytag Refrigerator have a filter?
Maytag brand water filter removal and replacement:
refrigerator_maytag-filter.jpg Removing and replacing a water filter
There are two different types of Maytag brand water filters. Each one is removed in a different manner, depending entirely on where it is located in your refrigerator. There are two main locations. Select your filter location from the options below for specific removal and replacement directions.
  1. The upper right corner of the refrigerator compartment.
  2. In the center of the ceiling of the refrigerator compartment.
Jun 12, 2011 | Maytag MFF2557HES Stainless Steel French...
Water won't flow, water line clear and has water running thru it....
Then you have to replace the water filter of the refrigerator. It is having some blockage that is why water is not flowing in it.
Filters situated in the interior liner of the refrigerator compartment of samsung-built side-by-side refrigerators are relatively simple to replace. Follow these steps:
  1. Remove the old filter by grasping it and slowly making a one quarter turn to the left.
  2. Pull down gently on the filter to remove it from the mounting bracket assembly. Be careful to not tip the filter, as water may spill out of it.
  3. Discard used filter.
  4. Remove the new filter from its packaging. Apply the appropriate month sticker to the filter to remind yourself to change it again in six months' time.
  5. Fill the filter with water from the tap, and then line the arrow on the filter up with the arrow on the cartridge holder inside your refrigerator.
  6. The filter automatically pulls itself into position as you turn the filter to the right and lock it in place. Be careful to not over tighten the filter into position.
  7. Run water through your dispenser for about three minutes to clear the system. Keep in mind that a newly installed water filter could initially cause water to spurt from the dispenser.
Water by Culligan filter cartridges need to have a water filter adapter installed. This is a one time installment, and once you have this adapter installed, it stays in the refrigerator for all future filter replacements. If your refrigerator already has this adapter in place, do not remove it to replace the filter.
Smart Water filter cartridges do not require the use of the water filter adapter. If for some reason your refrigerator has an adapter in place already, you will have to remove it before installing a Smart Water filter cartridge. The adapter is removed in the same manner as the filter itself: with a gentle quarter turn to the left.
Note: Replacing this type of filter is a quick process - there is no need to unplug your refrigerator when replacing it. Also, this filter should be replaced every six months.
Hope this was helpful to you. Thank you for using fixya.
Jan 27, 2011 | Samsung 26.1 Cu. Ft. Side-by-Side...
What is part number for water filter?
Hello there:
Water Filter
Item # 1017291
$35.75
Item # 1017291
img-descriptiontab-on.png Ice and water filter in front access grille for refrigerators made by Whirlpool, including some Kitchen Aid and Kenmore refrigerators. This is manufacturer part 4396508, and it replaces 4392857, WF-NL300, WF-L500 and 4396163. Replace every 6 to 12 months.
Related Items:
Jan 26, 2011 | Whirlpool 25.4 Cu. Ft. Side-by-Side...
Where is the water filter for the ice maker located on a GE tfx24zr side by side refridgerator located
Filters situated in the interior liner of the refrigerator compartment of GE-built side-by-side refrigerators are relatively simple to replace. Follow these steps:
Jan 26, 2011 | GE Refrigerators
Side by side refrig - ice maker and water don't work after replacing the filters. is there a re-set?
Removing a water filter from the inside of your Frigidaire brand refrigerator:
Removing and replacing a water filter - upper right hand corner inside location
Filters situated up front in the refrigerator compartment of Frigidaire-built side-by-side refrigerators are relatively simple to replace. Follow these steps:
  1. Open the door of the refrigerator compartment of your Frigidaire brand side-by-side refrigerator. The filter is located in the upper right hand corner. It has a push button for quick release just to the right of the filter.
  2. Locate the icemaker On/Off power switch and place it in the OFF (o) position.
  3. Push in on the filter release button and pull the filter all the way out to remove it. Remove new filter from its packaging and remove the protective plastic caps. Insert the new filter in the same manner it was removed. Make sure to push in firmly on the filter until you hear the filter cartridge click in place.
  4. Return the icemaker's power switch to the On (l) position.
  5. Condition the filter by running water through the dispenser for about three minutes. This will flush the filter of all fine carbon particles.
  6. In some models, you will have to reset the filter status light. It is located on the ice and water dispenser control panel. Push in on it for ten to fifteen seconds until the green, red, and amber lights flash. If your refrigerator model does not have a filter status light, you should make a note on a calendar, or place a month sticker on your filter to remind you to replace the filter again in six month's time.
Note: Replacing this type of filter is a quick process - there is no need to unplug your refrigerator or shut off the water supply when replacing it. Also, this filter should be replaced every six months.
Oct 31, 2010 | Electrolux 25.9 Cu. Ft. Side-by-Side...
We have a Amana refrigerator Model # SXD22SW2 and need to replace the water filter. We don't have the owner's/service manual for the refrigerator and I have looked everywhere on-line, including the Amana...
Removing a water filter from the base grill of your Amana brand refrigerator:
Removing and replacing a water filter - base grill location
Filters situated in the base grill (below the freezer compartment) of Whirlpool-built side-by-side refrigerators are relatively simple to replace. Follow these two steps:
  1. Grasp the filter's end and make a one-quarter turn to the left.
  2. Pull the filter straight out.
To replace with a new filter, repeat these two steps in the opposite order, making sure to first remove the red cap from the filter. Proceed by pushing the filter straight into the slot, and then giving it a one quarter turn to the right.
Note: Replacing this type of filter is quick - there is no need to unplug your refrigerator when replacing it. Also, this filter should be replaced every six months.
Oct 13, 2010 | Amana SXD524VW Side by Side Refrigerator
Water filter replacement on a GE Profile Refrigerator
You should NOT have to turn the water off to replace the filter. I have the same refrigerator and it closes water line itself when you turn the filter and drop it down. If yours flooded, I can only imagne the valve that the filter opens when in place got stuck.
There is a valve on the wall behind your refrigerator which can be shutoff.
The old filter should be heavier as it would still have water in it. Turn them over one by so water can drain out. The one with the smallest amount of water should be the new one. I always use a sharpie and mark the filter with the install date... that way ou know when to replace and which is the old one.
Jun 05, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System Logo
580 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
