Question about HP Photosmart C6180 All-In-One InkJet Printer
My printer suddenly has no power. HP Photosmart C6180 All-In-One. The light on the power cord is on. I have unplugged, re-plugged, re-set the surge protector to no avail. Is there a re-start button on the printer somewhere? We just had a wicked thunderstorm go through and am suspicious its been impacted.....although nothing else plugged into the same surge protector is affected. Any suggestions?
5 Suggested Answers
jonb3838
  • 237 Answers
SOURCE: Scan problem with HP Photosmart C6180 All-In-One
Have you tried to reinstall the drivers try that it should solve your problems
Posted on Feb 12, 2009
sgoswami
  • 114 Answers
SOURCE: HP PHOTOSMART C6180 WIRELESS NETWORK PRINTER
Try This :
Put the CD in the computer ;
Goto My computer- Right click on Black HP logo - Click on Explore - Open UTIL (Folder)- Open CCC (Folder)- Double Click on UNINSTALLATION L1 file;
Restart the computer;
Take out the CD and put the CD back in
Install the printer By clicking on add a Device
and reinstall it ..
This should resolve the issue
IF not then again follow the particular Link
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00724861&cc=us&lc=en&dlc=en&product=1153494
Regards Somajit
Posted on Sep 17, 2009
  • 100 Answers
SOURCE: printer keep restarting. c6180 hp photosmart
Apparently some defective components were used in the construction of the logic board (see photo). On my C6180 there were 3 failed capacitors (the green cylinders - the puffed top indicates failure) and a 4th from the same manufacturer (TEAPO - many unfavorable web references to this manufacturer). I purchased 3x 330uF 16V and 1x 680uF 10v rated to 105 degrees Celsius (total about 60cents). On the logic board, the capacitors I replaced are labeled C613, C614, C660 and C662. If you are not comfortable replacing the parts yourself (or don't have a soldering tool), you will have to find someone who will. The time to repair should be less than 30 min - I did it in 25 min with only a solder pen. This also fixed the ink system failures the printer was having. A similar fix may apply to other printers produced by HP around this time. acca299.jpg
Posted on Oct 03, 2010
  • 100 Answers
SOURCE: my printer is a c6180 and keeps repeatedly
My C6180 had the same problem. Apparently some defective components were used in the construction of the logic board (see photo). On my C6180 there were 3 failed capacitors (the green cylinders - the puffed top indicates failure) and a 4th from the same manufacturer (TEAPO - many unfavorable web references to this manufacturer). I purchased 3x 330uF 16V and 1x 680uF 10v rated to 105 degrees Celsius (total about 60cents). On the logic board, the capacitors I replaced are labeled C613, C614, C660 and C662. If you are not comfortable replacing the parts yourself (or don't have a soldering tool), you will have to find someone who will. The time to repair should be less than 30 min - I did it in 25 min with only a solder pen. This fixed the on and off problem and also fixed the ink system failures the printer was having. A similar fix may apply to other printers . acca299.jpg
Posted on Nov 15, 2010
How do I reset displaylanguage to english HP C6180
You can do a reset on your printer.Unplug the power cord of the printer.Press and hold the # and 6 buttons together and then plug the power cord back into the outlet.Keep holding the 2 buttons until the display goes blank or RESET is displayed.If the printer automatically turns off, turn on the printer.The printer should start up and you will be able to select language code.
Oct 26, 2011 | HP Photosmart C6180 All-In-One InkJet...
HP Photosmart C6288 Ink System Failure
Turn off the machine, unplug the power cord from the back of the machine, remove the ink cartridges, wait 2 min, plug the power cord back in, press the on button, wait until the printer prompts that the ink cartridges are missing, replace ink cartridges. If this doesn't clear the error you may need to re-prime the ink lines to fix it. Instructions for doing this are at http://www.ccl-la.com/blog/index.php/hp-photosmart-ink-system-failure-1/.
Mar 14, 2010 | HP Photosmart C6180 All-In-One InkJet...
Photosmart C6180 All in one printer will not start although live
Strange because I have the same issue, and I've had this printer for over 3 years but the problem just started about a month ago.
I reset the printer by: 1) Unplug power to the printer 2) Hold #6 on the keyboard 3) Plug power cord back in while holding #6 Eventually (10 seconds?) the printer will shut down. Once it does, release #6 and power up the printer again.
Warning: This reset all the configuration settings.
This works for me, but there is still an issue because I have to repeat this every time I turn off/on the printer.
Mar 03, 2010 | HP Photosmart C6180 All-In-One InkJet...
Need to reset factory defaults for hp c6180/ have had Ink system failure
1. Remove all cables.
2. Unplug the printer power.
3. Hold down # and 6 on the keyboard.
4. Plug the power cord back in.
Nov 28, 2009 | HP Photosmart C6180 All-In-One InkJet...
HP Photosmart C6180 All-In-One err oxc18a0201
Press the On button to turn the printer off.
Unplug the power cord from the back of the printer.
Remove all the ink cartridges.
Wait two minutes.
Plug the power cord into the back of the printer.
Press the On button to turn the printer on.
Install the ink cartridges when prompted.
If the error code does not display, the issue is resolved.
If the 0xc18xxxxx or 0xc19xxxxx ink system error code displays on the front panel, service the printer.
good luck
Aug 05, 2009 | HP Photosmart C6180 All-In-One InkJet...
I have a 2 yr. old C6180. It will not turn on as of yesterday. Power is coming from the socket as the little green lights on the plug are lighted. I have unplugged all cords and plugged them back in but...
try unplugging power cord and holding #6while your plugginmg in the power cord hold the button down until you see the display lights turning on and release if you are printing wirelessly you will have to do the wireless setup wizard again.
if that doesn't work try plugging it directly to the wall
if all else fails it may be the printer
Jul 14, 2009 | HP Photosmart C6180 All-In-One InkJet...
Cannot turn printer on
might as well do a reset:
for partial reset:
1.unplug the power cord wthout turning the printer off
2.while the cord is unplugges, press # and number 3 simultaneously
3.hold the 2 button for 10 seconds while inserting the plug back
4.release the 2 buttons when the printer reinitialized.
for semi-full reset:
follow same steps but press # and number 6
semi full means the printer is set back to factory settings or default settings.
Mar 04, 2009 | HP Photosmart C6180 All-In-One InkJet...
HP C6180 ''Unable to scan, copy or send a fax''
Check the following steps:
Connect the printer directly to the wall outlet and
1. Verify that the unit is switched on. Unplug the all-in-one from power and disconnect the connection port.
2. Wait 30 seconds.
3. Plug in the power only.
4. Repeat steps 2-4 two more times.
5. On the third time after plugging the unit into power, reconnect the connection port from the all-in-one to your computer.
1. Unplug the power cable from printer when the printer is powered on.
2. Press and hold # and 6 while plugging in the power cord
Try to check the result.
Regards,
Sagarjd
Nov 20, 2008 | HP Photosmart C6180 All-In-One InkJet...
HP Photosmart C6100
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Hi,
You can try to reset the unit to its factory defaults by performing the following steps .
unplug the power cord from the back of the unit without turning off the printer.
press n hold # key and 6 key together n do not release the keys ,while holding them down plug in the power cord back into the unit.
wait for a few seconds as it would make certain noises and turn off , when the unit turns off release the keys .
after a few seconds turn on the printer , wait as it wud go into initialisation mode > might ask to press 1 for language (please follow instructions ) it would give 2 or 3 allignment sheets.
5
after its done try to copy.
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} note - after the RESET fax seeting are to be done again as it goes to factory default settings .
Thanks
May 09, 2008 | HP Photosmart C6180 All-In-One InkJet...
HP Photosmart C6180 All-In-One InkJet Printer Logo
Ben Johnson
