Question about Acer Computers & Internet
My monitor screen is black and the yellow standby light is blinking. I can not get the light to stop blinking or get the monitor to show anything, but a black screen. What can I do to coerrect the problem?
    Genius:
  • 1,970 Answers
Mcdevito75 here, Press the SHIFT key, a screen should come up telling you too click on your user name, left lower side of screen. If this doesn"t work, press the yellow blinking light on the monitor see if picture comes back, then follow the directions. If this doesn"t work, shut computer down with switch on the computer itself. Hope this helps.
Posted on Jul 17, 2010
Finlux tv showing black screen after switching on by remote. standby light is flashing buy mo picture or sound
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://electro-medical.blogspot.com/
If blinks continue without any pause, the main board is faulty.
Oct 08, 2016 | Finlux Televison & Video
Why my computer cpu is on but moniter is black screen
is the light on the monitor red or yellow or green. red is off. yellow standby, green on. if you could lend or have a spare monitor try that first or take computer to a shop that fix's computers and ask if they can try it though a monitor. this will astablish if it is the monitor or lead from monitor or even graphic card.
May 25, 2014 | Microsoft Computers & Internet
I have a Dell Dimension E521. When I cut the power on everything comes on including the monitor, but the monitor will stay black. It does say something about power save hit any button but the screen
A solid green light means the computer is operating normally.
A solid yellow light indicates the power supply is operating normally but the computer is not processing data.
This could mean there is a problem with the CPu or another component on the motherboard.
((A blinking yellow light indicates the power supply is receiving power from the wall, but not functioning properly.
This generally means the power supply itself is bad and should be tested or replaced.))
A blinking green light means the computer is in standby mode.
You should consider visiting Dell Support and downloading the manual for your
your Dell computer. So use the LED power light codes if your Dell computer has them.
hope this helps
Sep 10, 2012 | Dell Dimension E521 PC Desktop
Monitor appears to be in permanent standby mode - - black screen and blinking blue power light. It is a Gateway FPD2185W monitor. It will not turn off or on. Unplugging and re-plugging changes nothing. ...
Look for bad caps with bulging top in the power supply. I would replace all 10 with PANASONIC FM or FC series from DIGIKEY. Post back what you see inside so we can guide you further, see example of failed monitors due to bad caps: http://s807.photobucket.com/home/budm/allalbums
Feb 22, 2010 | Gateway FPD1975W 19" LCD Monitor
Dimension e310- Black screen when powering on, 1 & 2 lights blink
Generally, the 1 and 2 Diagnostic LEDs indicate a failure of a PCI expansion card.
http://support.dell.com/support/edocs/systems/dim3100/en/sm/adtshoot.htm#wp1130520
So remove any expansion cards, see if anything changes. If it does, one of the PCI cards is suspect.
If the system has an expansion video card in the PCI-E slot, and removing the PCI cards had no effect, remove the PCI-E video card and connect to the intergrated video port (You may have to remove a black cover from the port) and see if you get video. If you do, then the Expansion video card has failed.
Nov 21, 2009 | Dell Computers & Internet
What would cause your power button light on the monitor keep blinking and the screen is black and you have trouble getting the light to stay on and get the picture back on. what is the problem. thanks,...
If the button on monitor is blinking, it means your computer is either turned off or in standby mode (or in hybernation).
You should push the power button on your computer to restore it from standby (or hybernation).
Aug 09, 2009 | Acer Computers & Internet
Laptop not booting up and nothing showing up on the screen
What leds you can see blinking on laptop? Can you hear any bootup sounds? Sometimes my laptop hangs on standby or hibernat, then screen is black and some leds may blink. Usually i need to take charger and battery off for 10 seconds and boot up again. If that dont help then there must be some hardware damage.
Jan 27, 2009 | HP Pavilion FE849UA Notebook
Acer AL1912 Monitor - Screen to black and light on yellow
I found some solutions other posted that didn't come up the first time I looked. I did a reboot and I'm good to go!
Dec 07, 2008 | Acer Computers & Internet
Computers & Internet Logo
358 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
