Question about Western Digital My Book Home Edition 500 GB USB Hard Drive
Power doesnt work...
For some reason the power on my hard drive wont work. Is there a way I can take the hard drive itself out? Or is there a place where i can get it fixed?
    President:
  • 2,571 Answers
Both, you can get a replacement psu, have you checked the fuse in the plug????
Or take it out of the enclosure and either put it into a pc or buy an enclosure
Posted on Jul 17, 2010
Dell desktop says no boot device available
Good Morning
I looks like your computer is trying to boot off of a floppy disk that is not present or doesnt work.
Hit the f2 and enter setup
Look for BOOT
and choose c: drive or hard disk drive as your first boot device.
If this fixes the problem then you know your hard drive is good. If the drive is good you probably want your first boot device to be your dvd or cd rom drive. Then you want your Hard drive second.
If your hard drive wont boot the drive itself could be bad or your operating system will need to be reinstalled.
Good Luck
Jim
Nov 27, 2012 | Computers & Internet
When I switch on my computer it will not activate the hard drive, but keeps on restarting. The red and green lights on the motherboard stay on.
try to change the pin at the back of your hard drive, place it into master if it doesnt work move it to slave, and if doesnt work again. , change your sata or ide cord, and if doesnt work defenitly, your hard drive have a problem.Try to buy a new hard drive . .
and your power led is not a problem with that. .:)
Feb 09, 2011 | Gigabyte GA-EP45-UD3R Motherboard
My mac wont find my lacie external hard drive
do u connect it in the keyboard? if yes then that doesnt work cause it doesnt have enough power to go through the keyboard. if u connect it in the back of mac then it should work
Aug 11, 2010 | LaCie External USB 2.0 500GB 7200 RPM 500...
My simpletech portable 250 gb hard drive wont read
Hello my  friend, regarding on your problem we have to consider first the different possibilities that cause this hard drives won't work. First try to double check the connector if it is properly connected or the power cable connector that causes no power that eventually give no power to the hard-drive. Another if you can notice the hard-drive, if the power of that device if present then eventually the problem is your hard-drive but if doesn't have a power then their are possibility that the power supply is  wrong. My recommendation, if you could fine a technician in your place then better you have to seek assistance in order to help you save your files from lossing it and to check if what are the main reason why this device won't work properly even you tried different computers. In that way, you can save files. Or if that device is under warranty then ship it back to the supplier to have a replacement but make sure that they have to make a back up from all of your data.
Hope this advice helps you from your problem. If you need more assistance just reply to this post. Thanks
Jun 17, 2009 | SimpleTech Computers & Internet
640 GB WD element hard drive has no power
Try it on a different USB port or on a different computer - is this hard drive powered via a mains cable ? If so is that plugged in and switched on as well ?
Also does the hard drive have an on off switch at the back or on it anywhere that needs turning on ?
Does this hard drive have a firewire port or another way of connecting to it ?
Apr 10, 2009 | Western Digital Elements powered by WD 320...
External hard drive
bad hard drive, try it on another laptop makesure there's power going to it the usb cable by itself wont work it needs power
please rate
Mar 05, 2009 | Verbatim External, USB 2.0, 750GB...
Lost everything on my laptop as soon as i open it
I dont think you lost everything. Do you see any green power lights and do you hear the normal hard drive and fan sounds when booting up ? If you do and still wont boot up to Windows then reboot and keep tapping on F8 to safe mode and select "last known good configuration". You can also perform system restore.
If you dont hear anything at all, no power and you dont see any green power lights then you may have to plug into another known good power outlet. check that your power connections (including the power adaptor) are secured and if on a strip power off and on. If that doesnt work, try another power adaptor. If those doesnt work
remove the laptop battery and just plug in the adapter.
If youre concern about your personal files you can always take out the hard drive, piggyback it to another hard drive on a known good PC and retrieve the files.
Jan 04, 2009 | Microsoft Windows Vista Ultimate Edition
Dell Inspiron 8500 doesnt continue boot up
is the crackling noise constant?
if so, your hard drive is lockup on the bootup. you have to get a new hard drive.
or you can try to reformat the hard drive, but I don't think that will help.
Jan 03, 2009 | Dell Inspiron 8500 Notebook
Drive wont power up or down
It sounds like the hardware failed. If it no longer mounts or powers up then I would say the hdd crashed and died. Sorry.
Dec 20, 2008 | Western Digital 500GB My Book World...
Laptop wont power on!!
I would suggest first formatting the hard drive and then go from there, If that is feasible for you... Good luck... GURU JAY
Jan 30, 2008 | HP Compaq Presario 2500 HP Pavilion ZE...
Western Digital My Book Home Edition 500 GB USB Hard Drive Logo
Top Western Digital Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Marvin
Marvin
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
