Question about Hobart HL200-1STD Mixer
Drive settings for Hobart Legacy HL-200
Hello I was wondering if anyone could supply me with the program settings for the AF-300 mini drive for the mixer motor. Our unit failed and I was unable to retrieve the data off the old unit, and the replacement unit has only the GE factory default settings on it.
  • monomoy May 11, 2010
    did you purchase unit from hobart or did you buy a competitors
    are you that mixer didnt have the sr drive.as far as i know you should not have to prog. any thing in the v.f.d.
  • Hobart Expert
  • 119 Answers
That software is proprietary. The only way to get a properly functioning drive is to order one from Hobart. www.hobartservice.com
Posted on Jul 21, 2010
What is this HOBART piece?
If this is it, it is a speed drive. It increases the speed of an attachment hub 3 times the normal speed usually used with a 9" vegetable slicer.
Dec 13, 2014 | Hobart Food Mixers
Switch reluctance drive fault
There are no schematics for the reluctance drive unit to get details of every resistor, at a technician level. Perhaps try resourcing the company that makes the drives for Hobart. The troubleshooting of the drive is complex and dangerous because of residual high DC voltages. Use extreme caution while near the drive. Voltages take a while to dissipate.
Feb 16, 2014 | Hobart HL600 Legacy Stand Mixer
Older, (1950) Hobart A-200 runs in first gear no matter where the shifter is set?
My Hobart had a switch on the side to change Gears... 3 Different Speeds
Apr 11, 2013 | Hobart Food Mixers
Power went out then back on and mixer reads err and 12 in the timer turned breaker off then back on still reads err
Leave the breaker off for at least one minute then try it. If that doesn't take care of it then you will need to have Hobart come out and check the frequency inverter (drive).
May 21, 2011 | Hobart HL600 Legacy Stand Mixer
What is error code 99 for a hobart HL 600 mixer?
error 99 stands for communication fault between timer board and the sr drive.there are 5 things that can cause this error.1.rs-485 cable disconnected or malfunction 2.1 con monitordisconnected or malfunction. 3.run/stop wiring disconnected or malfunction. 4.timer board malfunction. 5.sr drive malfunction. hope this helps, dont forget to vote, thanks, monomoy
Jan 29, 2010 | Hobart HL600 Legacy Stand Mixer
Hello, I have a commercial dough mixer,
it's a standard drive system found on most hobart mixers like the a200 style and you may find only hobart parts will fit it
Oct 10, 2009 | Hobart D300-6036 Mixer
Keep getting error code 23 when trying to start mixer
i will try to help, always include ml# with problem description on any hobart pc. of equip. which is located on the info. plate. there are 2 v.f.d.for this mixer ,sr drive being 1st generation, and gen. elec drive 2nd generation, on the sr drive err23 indicates a motor stall condition there are 6 most likely causes for this err. 1st, batch size too large,ck. capacity chart. 2nd,encoder malfunction. 3rd,motor malfunction. 4th,drive malfuction. 5th,1 con coil malfunction. 6th,2 cr malfunction. if this does not help, repost problem and i will ck. to see if i can be of anymore help, please dont forget to vote for me thanks, monomoy
Oct 05, 2009 | Hobart HL600 Legacy Stand Mixer
I need a parts manual for hobart legacy hl 2oo mixer. Start button dose not work need a new one!!!
www.hobartservice.com.
Enter your machine ML number in the smart parts window. It will give you exploded diagrams with part numbers.
Aug 15, 2009 | Hobart HL200-1STD Mixer
Hello...I am looking for specs for the Hobart 300 slicer....does anyone have them? I would appreicate your help...Diana dlbwholesalers@hotmail.com The county is requesting them as soon as possible...I...
Hi Diana. Have you given us your complete model # for your slicer?
I can't find a listing on Hobart's website for a 300 slicer. Is there a digit missing in your description?
You could call your nearest Hobart parts place and ask them to email your specs. ASAP.
If this solution has assisted you, please rate it. Good luck! ricardok45
Mar 24, 2009 | Hobart Food Mixers
Hobart HL200-1STD Mixer Logo
195 people viewed this question
Top Hobart Food Mixers Experts
Ross Keen
John Tripp
John Tripp
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Hobart Food Mixer Expert? Answer questions, earn points and help others
