Question about Denon DP-47F Turntable
Do I need an adapter for playing 45rpm records on my denon dp-26f
  • Denon Master
  • 5,554 Answers
The only adapter you will need for 45's are for the ones with a large hole in often used in jukeboxes.
Posted on Jul 19, 2010
Denon dp-26F when i tried to play a record the arm just skated all the way across the record. is there a way to adjust the arm so it plays correctly?
The short answer is that you need a new stylus as the one you have is either broken or worn away so that it won't stay in the groove. It could also be out of place. Rubbing your finger on the stylus you should be able to feel it digging in. If you can't it's gone!
Nov 16, 2014 | Denon DP-26F Turntable
Replace cartridge stylus
Hi, my advise to customers is to buy the best quality audio gear you can afford. If you tell me your budget I will suggest a couple of carts that match. Cheers John. Styluscity
May 27, 2013 | Denon DP-26F Turntable
Replace cartridge
as per my previous answer
My Denon DP-26F tonearm does not return "all" the way when finished playing a record.
Tonearm can be adjusted to travel back to its support. At the base of the tonearm is a small rubber stopper. Remove the stopper and insert a flat blade screwdriver into the slot beneath. Turn to the left and then test arm for repositioning correct. Adjust until its correct. John
Dec 27, 2012 | Denon DP-26F Turntable
In my DENON DP-300F tone arm don't come back after playing record. It just stays in the end of record? How can i fix it?
A lot of decks don't actually do that anyway. But if it previously did this then it's probably a mechanical problem. Removing the bottom of the turntable might show up the cause of the problem.
Dec 08, 2012 | Denon DP-300F Turntable
Sound is too loud and harsh.
Hi, connect it to an aux or CD input. John Styluscity.com
Dec 03, 2011 | Denon DP-26F Turntable
Which thickness setting should I use when playing my 33 rpm records on my Denon DP 297 fully automatic turntable? 17 or 30?
hi,
There are only two types of records available like 17 and 30. the size 30 will be as same as the turn table plater's size. 17 will be in half sized of the 30.
OK
Oct 22, 2011 | Denon DP-47F Turntable
Denon turntable DP 26F turntable doesn't turn
through the platter motor access window, unhook belt from motor spindle (usually brass) which is exposed on the left side when you remove the mat.
Now give the motor a spin with your thumb/index finger. repeat up to maybe a dozen times. sometimes a motor like this will get a dead spot where a bit of debris will 'gum up the works' and stop the electrical contact it needs to spin.
if it does start working by some miracle, then just let is sit and run at 45rpm for hours or even days, this may kinda rub off some very light corrosion that might have built up on the armature over the years. (if it is a brush type motor)
Jan 08, 2009 | Denon DP-26F Turntable
Belt is off on my DENON dp-26F tURNTABLE
http://www.archive.org/details/Turntable_Belt_Installation
above is a generic video that applies to almost all belt driven turntables including yours that will show how to install the belt and a few other things.
Aug 24, 2008 | Denon DP-26F Turntable
Denon DP-47F Turntable Logo
87 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
