Leaking Mitsubishi Mr Slim: I read a response to a question from someone who had a Mr Slim that was leaking inside their house. I have the same problem. In the posted response the person was told that their drainage pipe was probably blocked and they should locate the drainage pipe and blow into it to clear it. Could anyone elaborate? I have three Mr Slim units in my house but only one is leaking. The outside condenser has six hoses or pipes leading into it, I assume three are air and three are for drainage. Is there any way of figuring out which is which? and once I figure out which is the correct pipe, how do I detach it from my condenser unit in order to blow into it to clear the blockage? I'd appreciate any help you can provide. Thanks!
  • 767 Answers
Hello my name is Heath it will be my pleasure to assist you. The drain line shouldn't be hooked to the condenser. It will run from the bottom of the unit either to a drain in the house or to a pump that will pump the water to a drain. If you pull the front coner off the unit you will be able to see the drain pain and the line connected to it. On the side where the drain line connects this is usually where the units get plugged up from dust and debris that build up in the drain pan.
Posted on Jul 17, 2010
  • Xerxes725 Jul 17, 2010
    Thanks for getting back to me so quickly. This may sound like a dumb question, but how do I pull the front corner off? Is it supposed to snap off or do I need to unscrew something? I pulled at the right front corner and nothing seems to come off - I dont want to break anything by pulling even harder, but I cant see any screws to unscrew...
  • Heath Moyer Jul 17, 2010
    There should be screws in the bottom I believe three across the bottom and the the top part lifts up off the base unit.
2 Suggested Answers
  • 70 Answers
SOURCE: Mitsubishi Mr Slim: Hi,
There should be a clear or white pipe comming out of the back of the wall hung unit.
Posted on Jul 18, 2010
Leaking water
sounds like the drain is blocked or possibly the drip tray has a crack in it
Aug 01, 2013 | Mitsubishi MSZ-FE12NA MUZFE12NA Mr Slim...
My evaporator is leaking inside the house. It is a steady drip. Is there some way for me to fix this myself?
Attach a hose to the drip pan to lead the condensation somewhere else (eg. outside, the drain, a pot). If it was properly installed, it should already have a drain hose. The hose might be clogged.
Aug 08, 2011 | Mitsubishi Mr. Slim MXZ30TN Air...
Water dripping out of Mr. Slim on indoor unit.
Reason for water leaking.
1. Filter block. 2. Cooling coil block. 3. Alignment of indoor a/c unit is sloping downwards. 4. Drain pan block. It's advisable to service your unit first.
Jul 02, 2011 | Mitsubishi Mr. Slim MXZ30TN Air...
Our Mitsubishi Mr. Slim split a/c unit is wall mounted and is leaking badly from the bottom left side inside our home. We have to use a bucket underneath the unit to catch the leak. Please help us to fix...
Dec 06, 2010 | Heating & Cooling
Hi I have a Mr Slim Mitsubishi Aircon. I am not
my dear i am so so sorry but that oily liquid is freon an that will take a tech to come an find the leak an repair problem i wish i could coach you though to fix problem but i know you dont have the tools to fix it so hope i completed your question
May 19, 2010 | Mitsubishi Mr. Slim MXZ30TN Air...
The Mr. Slim is leaking water. It is 103 out.
is there water coming from the drain line outside? If not take a garden hose and back flush the drain line there may be some sludge in the line. DO NOT FLOOD YOUR HOUSE short quick burst's
Jul 23, 2009 | Mitsubishi Mr. Slim MXZ30TN Air...
Mr.Slim keeps freezing up
Hi my is Paul. it could be a number reasons but i would check to make sure the filters are clean and coil is clean. that thing that looks like a radiator. should be one facing inside the house and anther outside, clean them be careful not to been the fins. Or it could be low on Freon.
Jul 18, 2009 | Mitsubishi Mr. Slim MXZ30TN Air...
Heating & Cooling Logo
83 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
Marvin
Marvin
