Question about Whirlpool Duet GHW9150P Front Load Washer
Take out bottom drawer of whirlpool duet washer
  • 15,935 Answers
Pull out all the way - then lift up and pull some more.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 30, 2010
My Whirlpool Duet washer is leaking from the
You could have a clog in the housing underneath the dispenser where the water flows through a hose into the tub.
Pull the dispenser drawer completely out.
There is a tab that needs to be depressed to release the drawer and remove it.
Check the opening at the bottom of the housing just inside the dispenser housing opening to see if a small sock or garment is clogging this opening.
Reach down into this opening to see if an item is inside the hose.
This is the normal issue that will cause water to leak out of the dispenser housing.
Wash the dispenser drawer thoroughly with warm water. Make sure that you pull off the siphon covers and wash all siphon holes. This process is described in your owner's manual. Replace the dispenser drawer and try the washer again.
Jul 20, 2010 | Whirlpool Duet GHW9150P Front Load Washer
My whirlpool duet washer is leaking water from the detergent compartment
Jun 26, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet washer leaking badly. when it starts filling water rushes out of the detergent dispenser and the bottom of the door.
Jul 08, 2010 | Whirlpool Duet GHW9150P Front Load Washer
My whirlpool duet washer will not completely drain the water out of the soap dispenser. It is five years old
Jun 11, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet washer leaking/pouring water out of soap dispenser
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question^^^^
Feb 22, 2010 | Whirlpool Duet GHW9150P Front Load Washer
How do you get the bottom pedestal drawer out,of a whirlpool duet.
The drawer has release clips on the rails. They are a pain somtimes. One one each rail.
Jan 11, 2010 | Whirlpool Duet GHW9150P Front Load Washer
I was just given the drawer for under my Whirlpool Duet washer, however, I didn't keep the packing bolts that look like they are needed for fastening the washer to the drawer cabinet. If needed, where can...
searspartsdirect.com , just put in the model # of your pedestal, which is on a tag when you open the drawer. You can use just regular bolts, as long as the head is large enough to stay in.
Nov 15, 2009 | Whirlpool Duet GHW9150P Front Load Washer
How can I remove the Whirlpool Duet washer pedestal drawer?
When you look this will not appear to be how it is done but it is in fact the way. Pull the drawer all the way out and then look on the side of the drawer at the very front and you will see a single small screw that attaches the track to the drawer. It would appear this is part of a series of screws and the track itself should seperate but neither side of the track removes. Simply remove these screws on both sides of the drawer with a small hex head socket and the drawer will pull right out. Push the tracks back into the pedestal until done cleaning the drawer.
Jun 29, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Attach pedastal to whirpool duet washing machine front loader
you will want to lay the duet unit on its back. remove the legs. put the base up to the bottom of the duet. you can use the legs as bolts and pass them thru the top of the base back into the bottom of the duet appliance, using them as bolts. I have had some people just get new bolts. this should fix you up. please rate this if it was any help.
Thanks,
David
Oct 11, 2008 | Whirlpool LAB2700ML Pedestal Drawer for...
Whirlpool Duet GHW9150P Front Load Washer Logo
42 people viewed this question
Dan Webster
Dan Webster
Sal De
