Question about Ford Tractor Grill 2600 3600 4600 5600 6600 7600
Lift system isnt working and pto shaft dusnt rotate when activated
    Sergeant:
  • 200 Answers
The pump may be bad or need bleeding out.Thanks for asking and I hope this helps out.Please leave me 4 thumbs up.
Posted on Jul 20, 2010
Pto won't disengage, unable to start tractor. pto attached to post hole digger in ground
It could be gear bound and not allowing it to disengage, i experienced that a few times in my farming days, we dug a lot of postholes with a PTO driven digger. What usually happened is i ended up getting caught on rocks and stalled out because i had the engine speed to low. What i generally had to do to fix it was remove the PTO shaft from the digger, disconnect from the tractors output shaft, then get it started and everything moving, then disengage the PTO and reconnect the post hole digger, then give her hell and get the engine speed up before re-engaging the PTO, that would generally shock it loose. If not then i would have to disconnect the PTO shaft again and spin it backwards by hand to rotate the digger in the opposite direction to remove the hangup.
Nov 25, 2015 | John Deere 670 770 870 970 1070 Compact...
PTO turns with mwoer shaft disengaged, blades turn when shaft is rotated by hand. Put shaft into PTO housing and the mower wont turn.
bad pto, 400 dollar to fix but a cheap option is to replace the pto switch in the dash first, is the pto switch clicking with the key in the ON position? if it is then it is the pto clutch bad
Jul 29, 2015 | Garden
Remove plastic shroud off shaft from pto
never defeat a safety device like a safety cover on a pto , and allways connect small chains on cover to solid non moving parts to keep cover from rotating with shaft , so many folks i know have been really hurt even killed doing just that, removing the covers or leaving them unhooked , pto's are nothing to not be serious about
Dec 08, 2014 | Garden
Timecutter PTO clutch switch clicks when I engage the switch but will not engage the belts
Check under the deck and make sure the blades can spin freely, there will be resistance but mostly check to see if they are stuck. If they are not and can move, yiu can try to remove the belt from the pto, engage and see if it spins then. If it does not than there is probably an issue with pto clutch
May 12, 2014 | Toro TimeCutter SS5000 zero turn mower
We had several, identical gearbox failures on several Merceds Benz 1823 trucks. Each time the PTO pump was ripped off and the bell housing destroyed whilst the vehicle was driven on a straight road. We...
There is a gear that is in constant mesh in the PTO with a gear in the cluster shaft of the gear box. Fitting a PTO is a critical operation as there are shims between the PTO flange and the gear box housing to ensure correct teeth clearance . IF this clearance is not enough then the gears bottom out and jam prevention proper lubrication and rotation. Also it is vital that the teeth pitch of the PTO gear matches the pitch of the gear box gear as this will cause the PTO to be pushed of the side of the box.
Feb 21, 2014 | Cars & Trucks
Is there a way to operiate the hydro to raise and lower with out the PTO spinning
If your tractor does not have "live pto", then neither the pto shaft, nor lift arms when the clutch is depressed.
I don't think any 2n's, 9n's, or 8n's came equipped with a live pto.
Hope this helped.
Jan 23, 2011 | Ford 8N Tractor
Lexmark T630
Repeated, Unexplained Paper Jams With Little or No Damage to the Paper ID:ENUS5286 null.gif null.gif null.gif
IMPORTANT: The printer should rest on a surface that is flat, level, and uniform. This is for safety reasons as well as for paper feed reliability. In the bottom left corner on the front of the printer, as well as on the duplexer and each paper feed option apart from the 2000-sheet feeder, there is a shaft that rotates as the main drive motor in the printer operates. The purpose of this shaft (called the Power Take Off shaft) is to turn the pass-through rollers in the option below. The Power Take Off (PTO) shaft rotates during the printer's POR as well as any time the main drive motor turns, including while paper is feeding from any source and when the toner is agitated in the cartridge.
If the printer is on an uneven or non-level surface, the PTO shaft may not make full contact with the bevel gear on the lower options.
If the printer is on a surface that is not uniform (such as a carpet or foam padding), the PTO shaft on the lowest option may catch or bind, causing the paper feed operation to slow or stop completely.
In either case, repeated and unexplained paper jams (with little or no damage to the paper) may occur. The paper jam is due to the increased amount of time it takes the paper to feed through the path because the PTO shaft is bound or caught on the surface below, or is slipping on the bevel gear.
NOTE: This is not a printer defect or failure although it may result in a broken or stripped PTO shaft.
May 30, 2008 | Lexmark T630 Laser Printer
Camera isnt working
go to settings on the fone and press up once and you will see restore
factory settings select it and it will ask for a security code type in
12345 and ok and the fone should work grand......... im chris from dublin
Dec 23, 2007 | Nokia 7373 Cellular Phone
Ford Tractor Grill 2600 3600 4600 5600 6600 7600 Logo
394 people viewed this question
Top Ford Garden Experts
Dennis Key
Dennis Key
donald boissonneault
fordexpert
Are you a Ford Garden Expert? Answer questions, earn points and help others
