Question about HP Presario C555nr Notebook
Reg ram upgradation
Hai,
I have a HP Presario C555NR Notebook PC . I would like to upgrade the ram. It has 512 mb of ram. How much ram will it support. I know it has only 1 dimm slot. Kindly help.
    Problem Solver:
  • 10 Answers
Each memory slot on the C555NR can support a maximum of 1GB of RAM. There are actually 2 slots, but only one is easily accessible to you. By upgrading both the primary and secondary DIMMs, you could achieve a total of 2GB of memory but you would have to remove the 512mb chip that is already installed and replace it with 1GB (+1GB in the expansion slot as well.)
If you don't plan on taking the computer to a professional to be serviced, you will probably only want to upgrade the memory in the secondary slot located under the memory cover on the underside of the computer. It can handle a 1GB SODIMM.
FYI the memory is:
200 Pin DDR2-533 PC2-4200 SODIMM
Posted on Apr 21, 2008
I want to change my RAM which is of 512 MB.Can I do so
The Crucial System Scanner Tool will scan your PC and tell you what you type of RAM you have installed and suggest what the best option for upgrading would be. You can buy from crucial directly after running the tool or take this info to your local electronics store.
Jun 08, 2010 | HP Compaq Presario PC Desktop
How can I upgrade/improve the capabilities of my Inspiron 1200
The best and quickest improvement is to add more RAM. Add another 512 Mb of RAM. If you already have a 512 Mb of RAM module then add another 512 Mb RAM module. If your laptop has 2X256 Mb RAM modules then you need to remove these and insert 2X512 Mb RAM modules.
The reason why you have 504 Mb RAM is that the video card has grabbed 8Mb of RAM off the main memory.
May 21, 2010 | Dell Inspiron 1200 Notebook
I have compaq presario 5000 series...and iwant upgrade my ram ...i have 128+128 sd ram so how much i upgrade my ram...can i upgrade 512+512 sd ram OR 256+256 sd ram...thank you
the RAM upgrade will depend on ur motherboard capacity and specification.
u need to check ur MB manual
if ur MB can have only SD RAM then only SD RAM upgrade is possible...DDR will not work....
so be careful while buying ur RAM
intelD845GLLy MB...the following details are from the intel website
http://www.intel.com/support/motherboards/desktop/d845glly/sb/CS-012825.htm
System Memory Features
The D845GLLY board provide the following memory features:
  • Two DIMM sockets supporting 3.3 V (only) 168-pin 133 MHz Single Data Rate (SDR) SDRAM DIMMs with gold-plated contacts
  • Unbuffered non-ECC DIMMs only
  • Maximum total system memory: 2 GB; minimum total system memory: 64 MB
  • Serial Presence Detect (SPD) DIMMs only
  • Suspend to RAM
Caution Do not use ECC DIMMs with the Desktop Board. Using ECC DIMMs could damage the Desktop Board.
Integrator's Notes:
  • Registered DIMMs are not supported on the Desktop Board.
  • This Desktop Board has been designed to support DIMMs based on 512 Mbit technology for a maximum onboard capacity of up to 2 GB, but this technology has not been validated on this board.
Note To be fully compliant with all applicable PCI33 SDRAM memory specifications, the board should be populated with DIMMs that support the Serial Presence Detect (SPD) data structure. This allows the BIOS to read the SPD data and program the chipset to accurately configure memory settings for optimum performance.
hope this helps
Reg....bye
Feb 24, 2010 | Intel D845GLLY Motherboard
Upgrading system ram
This computer supports up to 512 MB of RAM, so you can add another 256 MB of RAM....
Apr 10, 2009 | Toshiba Satellite 1805-S274 Notebook
I want to upgrade my HP BA 600 Mother Board`s RAM Capacity
Most likely your MB is too old for this upgrade although there is a chance you could flash your bios (reprogram your computer's brain to accept the new memory providing hp has a flash for it).
here is a link for the latest bios flash for your computer, use at your own risk.
http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareDescription.jsp?lang=en&cc=us&prodTypeId=12454&prodSeriesId=32895&swItem=vc3903en&prodNameId=20305&swEnvOID=54&swLang=13&taskId=135&mode=4&idx=0
good luck.
Thank you,
agadycom
Nov 27, 2008 | HP Computers & Internet
Regarding a warranty/windows vista upgrade
You can get it done at Bestbuy, but their very expensive. Take it to a small computer shop in your area, you'll get the same technical service at a much better price. Here at my shop, I can undercut the local Bestbuy by $100 every time. As far as the ram goes, 384 will run Vista, but it will be a little sluggish. Upgrading the ram will improve the performance of the machine and is always a good idea.
Jul 09, 2008 | HP Compaq Presario V2000 Notebook
Upgradeable?!
RAM - 512 MB (installed) upgradable upto 2 GB (max)DDR 2 SDRAM ( 1 x 512 MB ) that means your laptop has only 1 slot for memory.. ____________________________________________________
Was this solution helpful .Show your appreciation by rating it.
dilipbagdi - Technical Associate
Jun 09, 2008 | HP Business Notebook 530
Ram upgradation
According to the specifications on the HP website the maximum RAM for your HP is 512MB and you are correct it only has one DIMM slot. So you're only alternative would be to buy a 1GB stick and insert it and try. It will not do any harm, but, you may lose some money because it will only operate at the spec given.
Apr 21, 2008 | HP Presario C555nr Notebook
Ram upgradation
The system uses shared video memory, so it will always show less memory than actually installed.
It's a good machine, but needs all memory it can get for Vista.
Good luck
Dec 08, 2007 | Toshiba Satellite A135-S2266 Notebook
HP Presario C555nr Notebook Logo
187 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
