Mitsubishi Mr Slim: Hi, I read your response to a question from someone who had a Mr Slim that was leaking inside their house. I have the same problem. In your response you said to locate the drainage pipe and blow into it to clear it. Could you elaborate? I have three Mr Slim units in my house but only one is leaking. The outside condenser has six hoses or pipes leading into it, I assume three are air and three are for drainage. Is there any way of figuring out which is which? and once I figure out which is the correct pipe, how do I detach it from my condenser unit in order to blow into it? I'd appreciate any help you can provide. Thanks!
  • Brian Niten Jul 17, 2010
    Hi, I didn't give the response you're talking about, but the line he was probably talking about will be pvc or some type of clear tubing. You do not want to remove any copper lines from your condenser unit as this will let you refrigerant charge out. I don't have a lot of experience with the ductless units so I not sure were the line is the other tech was talking about.
  • Xerxes725 Jul 17, 2010
    Yeah, it was 1kbron who posted the response I was referring to. I tried contacting him with my question but I'm new to this website and instead of sending my question directly to him, I guess it got posted to a general forum on AC units.
  • 70 Answers
There should be a clear or white pipe comming out of the back of the wall hung unit.
Posted on Jul 18, 2010
Mr. Slim aint cool!
Unit short of refrigerant or outside condenser very dirty. Clean outside thoroughly and make sure there is plenty of warmth coming from it when working.
Jul 07, 2012 | Mitsubishi MSZ-D30NA Mr. Slim Wall Heat...
My evaporator is leaking inside the house. It is a steady drip. Is there some way for me to fix this myself?
Attach a hose to the drip pan to lead the condensation somewhere else (eg. outside, the drain, a pot). If it was properly installed, it should already have a drain hose. The hose might be clogged.
Aug 08, 2011 | Mitsubishi Mr. Slim MXZ30TN Air...
Its not working and flashing P6. Its a Mr Slim
dear sir/madam i think.... mr Slim A control R407c & R410a systems.
P6 = indoor coil frost protection in cooling or indoor coil overheat protection in heating.
Cooling
One of the 2 indoor coil sensors reads minus 15 deg C for 3 mins.
Heating
One of the indoor coil sensors reads over 70 deg C.
If you are sure the refrigerant charge is correct & system operation is correct then it could be a coil temperature sensor reading wrong temperature.
If you have one of those little monitor things which plug into the outdoor circuit board you can monitor the indoor coil temperature.
On later type remote controllers you can get all operating data like temp sensor data but you will need a service manual to do this.
Or you can measure the ohms resistance of the temp sensors & compare with the chart in the service manual. if you can do it by yourself do if not then contatct ot mitsubishi maintenance personnnel for furhter action, thank you hope answer the question please vote!
Sep 23, 2010 | Mitsubishi Mr. Slim MXZ30TN Air...
MMy Mitsubishi Mr. Slim Air conditioner is
Here is where you can find all the info you will ever need about Mitsubishi Air Conditioning units...
Check out this tip that I wrote about that...
Mitsubishi Air Conditioner Troubleshooting and Repair
http://www.fixya.com/support/r5643983-mitsubishi_air_conditioner
heatman101
May 26, 2010 | Mitsubishi Mr. Slim MXZ30TN Air...
Hi I have a Mr Slim Mitsubishi Aircon. I am not
my dear i am so so sorry but that oily liquid is freon an that will take a tech to come an find the leak an repair problem i wish i could coach you though to fix problem but i know you dont have the tools to fix it so hope i completed your question
May 19, 2010 | Mitsubishi Mr. Slim MXZ30TN Air...
How do your read the serial# of a MUY-A24NA unit ,
hi.right below the model number there is a number that has numbers...model is muy-a24na..this is a 2ton unit...serial is possible the other number...hope this helps you..michael doctor airr appl.repair...843-384-8474...call if need some advice...its free..good luck
Mar 26, 2010 | Mitsubishi Mr. Slim MXZ30TN Air...
Mr.Slim keeps freezing up
Hi my is Paul. it could be a number reasons but i would check to make sure the filters are clean and coil is clean. that thing that looks like a radiator. should be one facing inside the house and anther outside, clean them be careful not to been the fins. Or it could be low on Freon.
Jul 18, 2009 | Mitsubishi Mr. Slim MXZ30TN Air...
Heating & Cooling Logo
214 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
