Question about Canon imageCLASS MF6590 Copier
Feeder takes paper in partially then stops feeding
  • 1,219 Answers
Hi, clean the rollers with alcohol, and check for any foreign material inside adf.
Posted on Jul 18, 2010
Paper feeds over 50% into printer, makes noises an stops. When I try to see the paper by lifting the lid, it's not there. It's as if its feeding into another area of the printer
One of the leading causes of paper jams is some sort of debris falling into the feeder. Remove the sheets of paper from the feeder. Grab a flashlight and look into the feeder for any foreign objects. If you're willing and capable, carefully lift your printer upside down. Any debris should just freely roll out from the feeder.
Apr 25, 2011 | Lexmark X5470 All-In-One InkJet Printer
Hi My epson rx620 keeps feeding paper on angle. when i take out paper there is a dent on the leading edge which seems to indicate an obstruction about 60mm from left hand side stopping left hand side of...
Top loading printers often get items falling into the paper feeder. Check for blockages and try using a vacuum cleaner hose with a narrow attachment to clean any rubish out.
Mar 16, 2011 | Office Equipment & Supplies
Paper feeder stuck
If the paper feeder stuck, do the following:
  1. Gently pull any jammed paper out from the output tray or sheet feeder.
  2. If paper is stuck inside, open the printer cover and remove the jammed paper, including any torn pieces. Then close the printer cover.
  3. If paper remains near the sheet feeder, press the paper feed roller lever inside the paper feeder to release the jammed paper, then carefully pull it out.
  4. Load the paper correctly.
  5. Press the cp_button_14.gif stop button to resume printing.
  • If the printer continues to jam or misfeed paper, and you are certain that there are no foreign objects lodged down inside the paper feed area, your printer may require service. Please call Epson technical support for further assistance.
  • Jan 29, 2011 | Epson Office Equipment & Supplies
    Information on how to use rear feed
    1. Prepare your doc/file for printing.
    2. Insert card stock with narrow side of stock in slot in back of printer until it hits rollers and stops. Don't force in any card stock thicker than max. rated.
    3. Change printer setup to feed from rear.
    4. Print.
    Depending on what software you print from, you may need to change this each time you print if you intend to keep printing from that "tray."
    Mar 09, 2009 | HP Deskjet 1120c InkJet Printer
    When I print on my Canon MP730, it always prints out a blank page after every print job. How can I fix this?
    SOLUTION(S): Reset the Sheet Feeder Gears
    If the power fails while the paper is feeding or during a print job, the paper feed gears will lose their proper
    alignment. The reason is that after the power is restored the paper feed gears will attempt to return to the
    home position, which may not be possible if the paper stop cam is not in the correct position.
    PROCEDURES
    1. Remove the sheet feeder from the unit.
    2. Remove the sheet feeder motor from the sheet feeder assembly.
    3. Remove the drive gear from its spindle.
    4. Realign the lifting tray gear and paper stop cam gear.
    5. Reinstall the drive gear and sheet feeder motor.
    6. Reattach the sheet feeder to the print unit.
    7. Reassemble the unit.
    Jan 11, 2009 | Canon MultiPASS MP730 All-In-One InkJet...
    Can't Print on Card
    I had the same problem with my 3 year old HP Officejet 5610. Feeding heavy paper or white card stock would result in a paper jam. The card stock would start to feed, but then stop half way. The pinch rollers seemed to spin without advancing the paper, even if the paper was fed one sheet at a time.
    Solution: Clean the rubber pinch rollers with isopropyl rubbing alcohol. Partial disassembly/reassembly required.
    To access the rollers, remove the scanner plate:
    1. Disconnect power, USB, and phone cables.
    2. Open up the scanner sheet feeder by tilting it left.
    3. Unlatch the scanner scanner feeder so that it opens completely vertical. Latch is on front hinge only.
    4. Remove the 4 corner hex screws on the scanner plate. Remove the 2 hex screws on the sheet feeder. (I used a small flat blade screw driver in the hex heads)
    4. Lift the plate and sheet feeder away from printer box. Disconnect the 2 flat cable wires from the circuit board.
    5. Scrub rubber pinch rollers with alcohol on a swab. Dry thoughly.
    6. Reassemble. (NOTE: This is a good time to clean the underside of the glass plate and the scanner head)
    Oct 18, 2007 | HP Officejet 5610 All-In-One InkJet...
    Card feeder
    It's not a card it's just paper
    Jan 10, 2007 | Faberware Eltron P210C Color Card Printer...
    The document feeder keeps trying to feed
    You have a bad Document transfer sensor. Sensor is located under the doc. transfer roller.
    Nov 15, 2006 | Sharp FO 6600 Plain Paper Laser Fax
    Canon imageCLASS MF6590 Copier Logo
    161 people viewed this question
    old marine
    old marine
