Question about Apple iPod touch 3rd Generation MC086LL/A MP3 Player
I need a passcode for my Ipod - Apple iPod touch 3rd Generation MC086LL/A MP3 Player
    President:
  • 1,561 Answers
There are two options by which you can unlock the code on your ipod. Follow any of the procedures below to unlock your ipod.
Unlock with the Primary Computer
  1. Plug the iPod into the primary computer linked to that iPod, the first computer you synchronized it with unless you have designated another computer as the primary computer.
  2. Open itunes and sync the iPod as normal.
  3. Remove the iPod, following the normal removal procedure. The iPod unlocks automatically as you remove it.
Unlock by Restoring
  1. Restore the iPod to factory settings if you do not have access to your primary computer. This erases all of the data you have stored on the iPod.
  2. Plug your iPod into the new computer you want to be the primary computer. Open iTunes and click on the "Restore" button.
  3. Reload your data, if it is available and sync your iPod. Remove it following normal procedures.
Take care
Posted on Jul 18, 2010
I need to change my password but my 5s isnt allowing me to do so
Go to iphone setting - then passcode or touch id & passcode. now tap on change passcode and then enter your old passcode and then new passcode. And if you forgot your passcode and your ipod iphone disabled and you want to unlock disabled iphone ipad.
here is the detail procedure
First method you can restore your ipod. But this will erase all your data on ipod. So if you have recent backup then go for restoring ipod. For that just connect your ipod to computer- then open itunes. Make sure you have installed latest itune version otherwise update your itunes first. Now open itunes then find your ipod under deivce tab at the top left sidecorner. Click on your ipod icon. Click on summary and then click on restore.
You can also restore your ipod from old backup also. For that open itunesfind your ipod under device menu. Now select your ipod and then right click on your ipod the you will get options for restore from backup.Select restore from backup this will provide list of all your previous backup on that computer itunes. Now select your backup which you want to restore and then click on continue. Once your restoring is completed your ipod will shut down and then again restart your ipod it will take few minutes to start up. And it also asks few information about you. Once you complete all that procedure your ipod is unlocked which was disable or locked due to wrong passcode.
Dec 26, 2016 | Apple iPhone 5S
How do you reset passcode on ipod touch?
You will need to know the present Passcode to access your iPod Touch and change the Passcode.
1. Go to Settings
2. Go to General
3. Go to Passcode Lock
4. Select "Change Passcode"
5. Remember your new Passcode.
Jun 15, 2014 | Apple iPod touch
How to unlock an ipod
Apple's iPod touch, a portable music player with a touchscreen display, is powered by a built-in rechargeable battery that provides up to 40 hours of audio playback and up to seven hours of video playback when fully charged. To conserve power, the iPod touch locks by default after a minute of not being used. If you want to use your iPod touch after it locks, you will need to unlock it. You might need to type a password, depending on how you've configured the device.
Press the "Home" button, located below the screen, or press the silver "Sleep/Wake" switch located at the top of the device. Swipe a finger across the "Slide to Unlock" slider on the screen. The iPod touch unlocks. Press the "Home" button or press the "Sleep/Wake" switch when you have enabled passcode protection on your iPod, then swipe a finger across the "Slide to Unlock" slider on the screen. The "Enter a Passcode" message appears. Type in your passcode, and then tap "OK." The iPod touch unlocks. Forgot Your Password b> Connect the iPod Touch to your computer using the USB cable. Wait for iTunes to open and sync with your computer. Eject your iPod Touch from the computer by clicking the "Eject" icon beside the iPod's entry in the "Devices" section of iTunes. Disconnect your iPod Touch from the USB cable. Your iPod Touch will be turned on and will be unlocked. Tap the "General" menu on the iPod Touch. Tap "Passcode Lock," and then tap either "Turn Passcode Off" or "Change Passcode." If you tap "Change Passcode," you can then enter a new passcode.
Mar 04, 2013 | Apple iPod touch
How do i unlock my ipod touch
Hope it helps
Jan 23, 2013 | Apple iPod Touch Fifth-Generation
How to disable a ipod touch
WARNING: DISABLING AN IPOD TOUCH WILL MAKE IT UNUSABLE UNLESS YOU PLUG IT BACK INTO ITUNES AND RESTORE IT.
If you want to know how to disable an iPod touch:
  1. Go to Settings> General > Passcode Lock >Turn Passcode Lock On > type in a passcode
  2. Now, hit the button at the top of your iPod.
  3. Try logging in with the WRONG passcode many times. This will disable the iPod touch.
Jan 29, 2011 | Apple iPod touch
How can i disable my ipod touch?
Do I read your question correctly: you want to disable your iPod?
Or do you want to recover it from being disabled?
For the first one, to disable your iPod:
  1. Turn ON the passcode-lock by going to Settings> General> Passcode Lock> ... and then, tap Turn Passcode On.
  2. Now, to disable it, put your iPod to sleep by pressing the POWER button once. Then wak it up. You will be asked for the passcode before you can use it.
  3. Enter an incorrect passcode several times to disable the device.
Now, if what you want is to recover your device from being disabled, all you need to do is read this tip:
http://www.fixya.com/support/r5541493-put_iphone_ipod_touch_dfu_mode_restore
For more iPhone / iPod touch tips like jailbreaking and unlocking, click here.
If you need online help about jailbreaking and unlocking, you can contact me personally at this email: sale-47hyk-1863377234@craigslist.org
Jul 18, 2010 | Apple iPod touch
Forgot passcode to ipod
You'll need to restore the software with iTunes. Select the iPod in iTunes, under the Summary Tab, select Restore. You will then need to resync it as well.
Sep 29, 2009 | Audio Players & Recorders
Ipod touch disabled
If you repeatedly enter the wrong passcode, iPhone or iPod touch will be disabled for longer intervals, before you can try again. After too many unsuccessful attempts, you won't be able to try again until you connect to the computer you normally sync with. Note that starting with iPhone 2.1 software, there is a setting to cause the device to erase itself after 10 consecutive incorrect password attempts. This setting is off by default. It can be turned on by tapping Settings > General > Passcode Lock after you enter a correct passcode.
If you cannot remember the passcode, you will need to restore your device on the computer that was used to originally sync the iPhone or iPod touch so that you can reset your passcode and resync the data from the device (or restore from a backup). If you restore on a different computer that was never synced to the iPhone or iPod touch, you will be able to unlock the device for use and remove the passcode but your data will not be present.
Jul 29, 2009 | Apple iPod touch Second Gen (8 GB,...
Ipod touch 16gb, passcode forgotten screen reads disabled.
well you can conpleatly restore it by no luging it in and holding the power buton for 3 seconds then with out leting go of the power buton hold the home buton for 10 seconds then let go of the power buton and just hold the home buton for a further 30 seconds.....
after you have done this plug it in to your computer with iTunes allready running and a icon should say unresponcive ipod or somethin along those lines just click RESTORE
hope this helps
dale gough
Jul 21, 2009 | Apple iPod touch
How to reset password on itouch
how can i reset my ipod touch when its disabled
Oct 12, 2008 | Apple iPod touch
Apple iPod touch 3rd Generation MC086LL/A MP3 Player Logo
54 people viewed this question
Top Apple Audio Players & Recorders Experts
Nagendra Baliga
Parshiv Luthra
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
