Question about Shimano Shifter Pods 3x7 Shm Bicycle Parts
Large trigger has to sit for a while befor it will engage. Derailleur does move when it does engage. You get one pump and then you wait. This bike has been sitting for 3 years unused.
  • blaf11 Jul 25, 2010
    When I say engaged, I mean it will move the deraileur up a gear. Until it "engages", the trigger moves freely but does nothing with the derailleur. Wait a few minutes and it will give you one push and then it is free -not engaged-again. I've squirted Triflow into trigger mech to no avail.
  • 1,514 Answers
If you mean the derailleur doesn't move straight away when you move the gear trigger it's likely that the derailleur needs cleaning and oiling. As the bike hasn't been used for 3 years also oil the chain, check that the cable pulls the derailleur far enough. if it doesn't there the cable may need to be tightened. If the derailleur is not going back out far enough there's an adjusting screw which sets the limit. this may need adjusting.
Posted on Jul 17, 2010
  • Joe Bannon Jul 26, 2010
    It sounds like the cable might be sticking sticking. If you've oiled the the trigger mechanism and the derailleur it's the only thing left. Try removing the wire centre from the cable and see if it's rusted or if it moves freely. When the cable is disconnected from the derailleur check that the derailleur moves freely in and out. If not it needs cleaning and oiling. The spring in the Derailleur puts the pressure on the cable which in turn puts pressure on the trigger so it's a matter of tracing where the pressure is being stopped.
My shifter on my bike will not change gears on the 1-7 shifter
Too little information. Does the shift lever not move, does it move but the derailleur does not, or does the derailleur move some but does not reach all gears? If the last one is it the small or large rear gears that you can't get?
Jun 06, 2017 | Cycling
Brand new bike gears won't engage. The gear shift is on 6 and the chain is on the smallest cranks.
the derailleur cable is too loose. Shift the shifter into the smallest cog, make sure the chain is on the smallest cog. The derailleur cable will most likely be very slack now. At the rear derailleur, there will be a nut or a allen bolt pinching the cable to the derailleur. loosen this, pull the cable finger tight, tighten the nut or bolt again and then try shifting again. You can dial it in using the barrel adjuster on the derailleur or the shifter.
Oct 15, 2011 | Pacific International Pacific Evolution...
Shimano STX (combo brake and shifter) rear shifter does nothing up or down. Shifters move but do not engage the derailleur. The cable is tight and obviously not broken. Is the shifter broken or can...
You can't have end-to-end intact cable movement and NOT move the derailleur unless it is NOT tight to begin with. Look closer.
You need to figure out at which end the problem lies.
You can elevate the rear wheel (or hang the bike by the tip of the seat on a low branch) and pedaling it forward with your hand you can grab the bare exposed cable somewhere in its routing (usually along the down tube) and pull sideways on it (away from the bike) to see if the derailleur moves as expected when the cable REALLY moves. Then you can decide if the shifter is or is not controlling the cable.
Everything is replaceable as required.
Adjustments: http://www.parktool.com/blog/repair-help/categories/derailleur-systems
or use a search engine "how to...." for videos.
Jul 09, 2011 | Shimano Cycling
My shimno sora front derailler shifts perfectly to the small and large chain set cogs, but on the middle, the chain rubs along the cage.
Set the rear derailleur to the lowest gear (big cog) and the front to the lowest gear (small chain ring). Disconnect the derailleur cable. Screw in the adjuster for the cable tension all the way (this adjuster is on the shifter of a mountain bike or the down tube of a road bike). Pedal to make sure the chain is not rubbing on the derailleur cage. If it is, adjust the "L" setting on the derailleur until the chain moves by without touching the cage. Now pull taut and reattch the cable and shift the front to the big ring while pedaling. If it does not shift up well or completely, hold the shifter past its normal shift and adjust the "H" screw so that the derailleur allows the shift. Shift into the highest cassette gear and keep pedaling. The chain should not be touching the front derailleur's cage when you pedal. Adjust with the barrel adjuster until the chain moves freely without touching the derailleur cage.
i hope this helps
-matthew
Oct 30, 2009 | Cycling
Problem with chain and gears
Wash, degrease and scrub the chain and derailleurs with a good degreaser (like Simple Green). Dry the chain and relubricate it with an appropriate bike chain lubricant (not oil or WD-40). Shift the derailleurs to the smallest chain ring and cog on the cassette (low front gear, high rear gear) and then loosen the cable at the derailleurs, pull the cables taut and reattach them. If the derailleurs still need adjustment, here is a procedure for it:
Flip the bike over (so you can pedal the bike manually while you shift) and shift the front to the middle chain ring. Shift the rear to the highest gear (small cog). Release the cable from the pinch bolt on the derailleur. Adjust the screw marked "H" on the derailleur until the jockey wheel on the derailleur is aligned perfectly over the small cassette cog. Set the cable adjuster on the derailleur to the middle of its range (find this by screwing it all the way in and then count how many revolutions it makes until it screws out completely. Screw it back in one half of the total revolutions). Reattach the cable and shift to the lowest gear (the biggest cog). Over-shift and hold on the shifter, then adjust the "L" screw on the derailleur until the jockey wheel sits just past the last cog. You have to hold the shifter to do this. Now shift into the middle gear (or one of the two middle gears if the bike has an even number of gears) and adjust the derailleur using the barrel adjuster you previously set to the middle of its range. Adjust it so that the derailleur is sitting perfectly over the appropriate gear. Shift up and down the cassette while pedaling and in every gear, reverse pedal (freewheel) to make sure the chain does not hop. Adjust as necessary until all gears are smooth.
Now the front:
That should be it, unless there is another mechanical problem causing the missed shifts, like a bent derailleur hanger or damaged teeth on the cassette cogs or a bad derailleur. If it is still problematic, come back for further information.
i hope this helps
-matthew
Oct 26, 2009 | Cycling
I can not pedal back and the angle of the lower section is at a 45 degree angle more or less
Make sure your rear derailleur is lined up with one of the rings of teeth on your rear gears( cassette ). Also make sure Your chain is riding correctly on one of the front gears on your crank. If you are still unable to back pedal make sure that one of the cogs (gears) in the rear derailleur arm isn't seized. They must both be able to rotate and the chain should pass through them in a backward S pattern. If you still can't back pedal remove the back wheel or move the chain off the cassette to see if the cassette will freewheel. It has to move freely in a counterclockwise direction in order for you to backpedal. Moving in a clockwise direction engages pawls inside the cassette which lock it into a drive situation which propels the bike. If the cassette will not freewheel in a counterclockwise direction you will need to take the rear wheel to a good bicycle shop to have the cassette replaced. It requires a special tool to remove it. Hope this helps.
Aug 06, 2009 | Shimano 09 Xtr M971lc Mountain Bike Rear...
The chain is rubbing on the rear tyre when its free wheeling. what do I do?
You may have too large a tire on the back for the bike. However, if the derailleur hanger is bent, this could also cause the problem. Flip your bike over onto the bars and seat and make sure the derailleur alignment is good (vertically and longitudinally straight). If the derailleur hanger is straight, then you will have to use a narrower tire in the back.
Jun 30, 2009 | Mountain Shimano Tourney 6/7 Rear...
I am having problems with my Shimano front derailleur
Adverse temperatures can affect metal, and left idle over time the cables can stretch.. It needs adjustment. Usually the is a pair of screws on top which limit the movement of the derailleur.
Mar 14, 2009 | Mountain Shimano Alivio Front Bike...
Adjusting front derailer
Typically adjusting the front derailleur is a matter of adjusting the two adjusting screws on the derailleur. So turn the bike upside down. It should sit on its seat and handle bars. Find the two adjusting screws one will prevent the derailleur from traveling too far out preventing the chain from coming off. The other screw prevents the derailleur from traveling too far in keeping the chain from falling off that way. Now once you have found the screws slowly start turning the pedals like it was being ridden. Move the derailleur out as far as it will go if you see the chain is about to come off adjust the screw. Do same for inside screw. Now move the back derailleur all the way in and retest front derailleur, repeater with rear derailleur all the was out. Hope that helps. Oh, the back derailleur adjusts same way.
Feb 27, 2009 | Shimano Brake Cables Atb Mountain Bike...
Shimano Shifter  Pods 3x7 Shm Bicycle Parts Logo
71 people viewed this question
Top Shimano Cycling Experts
Michial Gueffroy
Eric Hidle
Level 1 Expert
Mike
Are you a Shimano Cycling Expert? Answer questions, earn points and help others
