Question about Whirlpool RBS305PDS Electric Single Oven
My new oven just keeps getting hotter and hotter. I think the thermostat dont work.
  • 1,284 Answers
Hi, you guessed right. You need to replace the thermostat which is in charge of regulating the heat in the oven.
Take care
Posted on Jul 17, 2010
I have chef EGC651S oven with separate grill. On fan assist oven only heats up to a certaain temp and doesnt get any hotter what could be the reason for this
Probably thermostat problem, although some chance you have one side of a 220vac breaker not working. In otherwords oven heating element is "getting" half of the required power. Call electrician!
Mar 08, 2015 | Ovens
Bosch built in double oven: had new element fitted to main fan oven, but now oven keeps on getting hotter does not stop heating up when right temp reached.
This type of problem normally can be ascribed to a defective thermostat. Unfortunately there is no test for a thermostat, it has to be replaced to see if the problem has been sorted out.
One thing you can do is remove the thermostat bulb from the oven and place place it in a position where it will not heat up. Place an oven thermometer in the oven. Switch on and see of the temperature climbs above what you wee seeing before. This is a very much hands on test as you have no control over the temperature that the elements can get to. As soon as you see the temperature reach a point above that seen before, shut down immediately.
Mar 27, 2011 | Bosch Ovens
Oven runs much hotter than set temperature. Usually 50 degrees hotter than what it is set at, but can go over 100 degrees higher.
Sounds like you need a new oven thermostat or get an oven thermometer and by experimentation draw up a new heating range for the oven dial.
Feb 11, 2011 | Frigidaire Ovens
Fan oven temperature is much hotter than it should be incinerating food the fan is still working
Sounds like the oven thermostat is not working, I would suggest fitting a new thermostat.
Dec 19, 2010 | Ovens
Fan oven is getting much hotter than what the thermostat indicates. Is it the thermostat or the switch
The thermostat controls the oven temp, therefore it is logical to assume that the thermostat is not sensing the temperature properly, so I would fit a new one.
Nov 27, 2010 | Electrolux EOD5310 Electric Double Oven
Inconsistant oven temperature
Check out this tip that I wrote about this problem...
http://www.fixya.com/support/r4511800-oven_problems_electric_oven_heating
heatman101
Apr 25, 2010 | Ovens
When using the oven setting it justs get hotter and hotter.
tt sounds like the thermostat sensor
Dec 27, 2009 | Ovens
The problem is that the oven seems to get hotter and hotter as if the thermostat doesn't cut out, i.e. i was cooking braising steak yesterday temp set between 150 -100 this just boiled over. so i had to...
You are quite correct in saying that the thermostat is faulty.
Only solution is to replace it with a new one.
This should solve your problem.
Nov 29, 2009 | Belling Ovens
New replacement thermostat needs calibrating on my Kenmore oven
There is no real way to calibrate the thermostat. Most ovens have the same problem. By lowering the setting slightly will help get a closer temperature. Sometimes similar thermostats are substituted and may not be exactly the same as the original that came with your oven. Hope my trying to answer your question was helpful, Thanks, Sea breeze
Mar 27, 2009 | Kenmore Ovens
Bottom oven gets extremely hot
It would appear you have a faulty thermostat that controls the temp. SUggest you get a new thermostat fitted.
Dec 08, 2008 | GE JTP27 Electric Double Oven
Whirlpool RBS305PDS Electric Single Oven Logo
227 people viewed this question
Top Whirlpool Ovens Experts
Dan Webster
Dan Webster
ashburton
Sal De
Are you a Whirlpool Oven Expert? Answer questions, earn points and help others
