Question about IBM ThinkPad 600E 2645 Notebook
Thinkpad 600E won't boot from disk - IBM ThinkPad 600E 2645 Notebook
  • mslataprada Jul 18, 2010
    This old stupid computer read-- after I ran a diagnostic from the easy setup screen---System Board error message-- Dev 001 Err 91 FRU 3610--I went online from my desktop and found that it's the battery and/or the motherboard or something to that effect. I ran another Diagnostic for the FRU and while in the easy set up I clicked on test then I pressed ctrl-- plus the A key and it ran the FRU diag---guess what? It read that the battery voltage was too high and that I have to replace the battery and/or motherboard--fa-get-a-bout-it--i'm throwing that computer away--I'm thinking about buying me one for my birthday in Octorer!
    I had it working fine last night, it was just sitting in the corner for awhile minding it's own business but wanted to re-install the operating system because it was giving me error messages with the modem--I accidently installed windows XP on both partitions--i had no storage--so I wanted to delete one copy--I deleted one partition -that's when the problems began--oh well--live and learn!!
    thanks a million anyway
    mslataprada@aol.com
    President:
  • 2,571 Answers
Set the boot order to boot from cd drive first, to enter the bios ...
With the unit powered off, hold the F1 key and power the unit on. Keep F1 held down until Easy setup appears.
Posted on Jul 17, 2010
Testimonial: "very goood"
I get disk read error when I try to boot it up.
It is hard disk problem kindly take the backup of system if you can and replace the hard drive immediately.
Hope this helps. Please rate my response.
Thanks.
Have a good day.
May 10, 2010 | IBM ThinkPad 600E 2645 Notebook
IBM Thinkpad 600e (2645),error 189 and could not installing win98
Usually this means a hardware failure. I would suggest reseating the CMOS battery overnight to reset the system. Also you might want to replace it as well. It could also be more serious such as a motherboard component failure.
Also IBM error code # 189 according to Scott Mueller's Upgrading and Repairing PC's (8th edition) - "Excessive incorrect password attempts." Is there a password on your CMOS ?
Also try hitting ESC key on boot to bypass. Good luck!
Sep 23, 2009 | IBM ThinkPad 600E 2645 Notebook
IBM THINKPAD 600 can't detect HARD DISK FUJITSU 40GB. what can I do???
Check the power cable of harddisk if found it is ok then go to bios and detect the harddisk by pressing enter on primary boot device
Jun 01, 2009 | IBM ThinkPad 600E 2645 Notebook
Formatting IBM Thinkpad 600E
I know you can't boot from the Windows 98 CD, and probably not from Windows 2000 either. It is possible to turn the the Windows 98 bootable floppy into a bootable CD, but I think you would be much better of trying to install Linux.
Mar 16, 2009 | IBM ThinkPad 600E 2645 Notebook
On a ibm 600e, how do I boot from a cd? I'm
ok go to the bios system by pressing esc or F12 or F2 key when the computer restart. After that change the boot sequence. CD drive first after that HDD or follow the instruction that are given by computer in bellow or side, after configure just press F10 for saving.
Mar 14, 2009 | IBM ThinkPad 600E 2645 Notebook
How do I put new windows on the thinkpad I have got the cd
this is sometimes due to the boot sequence. identify the key to press so that you can access its bios at start up. a shot message is usually displayed for a short time at start up.
please go to the bios and change the boot sequence to start from HDD.
Dec 18, 2008 | IBM ThinkPad 600E 2645 Notebook
Ibm thinkpad 600e
It is one of two items. You have a floppy disk in the unit or you have a bad hard drive.
I’m happy to assist further over the phone at https://www.6ya.com/expert/lou_afa492c634393790
Nov 12, 2008 | Computers & Internet
Thinkpad 600E
IBM Thinkpad error code 19990301 is a Hard-Disk sector problem. Basically your hard-drive is faulty and you need to replace it. This is why it wont boot; because the area of the hard-drive that stores data is damaged.
Sep 20, 2007 | IBM ThinkPad 600E 2645 Notebook
Open Questions:
ibm thinkpad does not boot My IBM Thinkpad 600 (Type 2645-310) stops and hang during bootup. What happens is: 1. LED test, then green Power on and orange battery/charging 3. RAM OK (Responds when I take out /put in different amount of RAM and displays correctly. I have 128 + 32 removable, + 32 internal not possible to take out) 2. I can hear fan, CD drive and evt diskette drive. If I use diskette drive the LED wil give 1 blink, if I use CD drive it will give 14 blink. 3. No cursor seen, but this is displayed: Upper left show the amount of RAM present: 196032 KB OK Upper right IBMs logo in blue; IBM Lower left shows "ThinkPad(R)" in large letters and red dot over "i". 4. Then a "rrrrrr" sound from the loudspeakers after a while, this is in fact 28 clicks shortly after each other. Then nothing more happens. Diskette and CD drive is OK (But can not be used because bootup is never finished). I hear CD speed up and then down again but nothing more happens. No effect in booting with bootable diskette or CD, "Live Linux" CD or else. Backup battery OK (3V) and if I take it out I will be asked for correct date and time when Power on. I can then use keyboard or TrackPoint to set date and time, and after that hangup at the usual point. Starting without battery, HDD, CD drive and removable memory sticks makes no difference in symptoms. Pressing and holding F1 before and during poweron and startup (in order to enter BIOS and selftest) has no effect. I could not find help on IBMs home page, but maybe I did not look at the right place. Is somebody able to help me?
Feb 28, 2017 | IBM ThinkPad 600E 2645 Notebook
See all IBM ThinkPad 600E 2645 Notebook Questions
IBM ThinkPad 600E 2645 Notebook Logo
423 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
pankaj rautela
pankaj rautela
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
