Question about Quinny Buzz 3 Sulphur Jogger
One of my tires on my quinny buzz keeps going flat how can this be fixed? Is there a tube inside the tires?
    Problem Solver:
  • 5 Answers
Yes there is an inner tube which sounds as if it has a puncture. I bought replacement inner tubes off e bay for mine when the same happened to mine. You can then either take the tyre off yourself and replace the tube (bit fiddly unless you have a suitable tool like a strong screwdriver for releasing the tyre) or try taking it to your local bicycle shop who could no doubt remove and refit the tyre for you for a small fee.
Posted on Jul 17, 2010
I need a new wheel for my quinny freestyle, it keeps going flat and now i have a thorn in it. i need it asap
Most strollers use the same tires and tubes as kiddy bikes. 10" or 12" your local bike shop could help. I buy spare tubes and tires from Kmart.
Jun 03, 2011 | Quinny Freestyle 3 XL Stroller
I just purchased a second hand Quinny buzz 3 and I believe I need a new front tire. When I go to turn the tire bumps on the cement and prevents me from turning with ease. Where can I find a new spare tire?...
hi you can get a new wheel unit from quinny direct or eBay
the folding is something else turn the buzz over and check the groove on the middle tube to see if it is clean try an oil like wd40
if that doesn't work it may need a re gas which can done by quinny
Feb 16, 2011 | Quinny Buzz Three Wheel Stroller
Hi, the tyres on my quinny buzz seem to be flat (I can press them right down with my finger) but the inner tubes are fully inflated and do not have a puncture, is this normal?
Both Bugaboo and Quinny recommended tyre inflation pressure as 15 psi / 1 bar. I find this way to soft and run my tires at 30 psi / 2 bar with no problems and far easier pushing.
Feb 08, 2011 | Quinny Buzz Three Wheel Stroller
The tire in the back left is continuously flat. Have tried numerous ways of filling it with air. It's been like that since the day i've received it, i've had to stop using it because it was too difficult...
I'd check the inside the rims, there must be something rubbing against the tube. There is a product bike shops sell that is basically a solid foam inner tube. Check out your local bike shop
Dec 09, 2010 | Quinny Buzz Three Wheel Stroller
I have pram quinny buz 3 (second hand) but the back tires are flat. How to fix them since they won't fit in with my bike tire pump . many thanks
Hi you can purchase the correct pump on ebay, if they are punctured they also sell new inner tubes very cheap they also have a bent valve which makes them easier to pump up.
Mar 08, 2010 | Quinny Buzz Three Wheel Stroller
One of my tire is usually flat and since I bought stroller I can't pump just this one tire because I like this stroller tell me how I can sole this problem? It's like impposible for pump it.
You need to either have a new inner tube put in it or you can try adding a flat repair gel in the tube to fix the leak. You can get what they call "Green Slime" their are other brands also available under different names but this is most common. It can be purchased at Walmart, Home Depot, Ace Hardware and Auto Parts Stores. This is easy to pump into the tube valve stem without removing the tube or wheel and should fix any holes or leaks on it. Then just pump it up and you should be ready to go.
Nov 02, 2009 | Quinny Buzz Jogger
The 2 back tires on my brand new quinny buzz are flat. Is there a special pump needed for these tires? We have tried 3 different pumps and they don't fit the tires.
You should have received a tyre pump inside the black bag (Buzz Box) that is clipped onto the back of the chassis.
I hope this helps.
Nov 02, 2009 | Baby Gear
One of my Quinny Buzz Tires are flat. It is
Hopes this was helpful, DutchTexan
Oct 15, 2009 | Quinny Buzz Jogger
How do you change the inner tubes on the quinny buzz
I took the whole tyre off the alloy bit, then when I had fixed the inner tube pushed it back inside the tyre then put the silver alloy bit back on.
Oct 20, 2008 | Quinny Buzz Jogger
Flat tire
You can repair the tube the same way as you would a bicycle tire. If you don't want to do it yourself you can bring it to any bike shop.
Nov 08, 2007 | Quinny ZAPP Stroller
Quinny Buzz 3 Sulphur Jogger Logo
473 people viewed this question
Top Quinny Baby Gear Experts
Jennifer Rock
Jennifer Rock
Oloyede Monsuru
ray gallant
Are you a Quinny Baby Gear Expert? Answer questions, earn points and help others
