Won't change channels ,adjust volume ,go to activities or turn off
    Guru:
  • 1,894 Answers
Do a hard reset and try it sir
Posted on Apr 21, 2008
  • dewan nafees ahmed Apr 21, 2008
    or it may be a software problem... please reinstall the mobile software
    thank you
    have a great day
  • dewan nafees ahmed Apr 22, 2008
    do a update of the PDAs software first.
    if it is not getting resolved then do a reinstall of whole PDA software by taking it to some expreienced person.
What does this mean "this function is not available now"
Change input device to some other like a DVD player and see. Look for any child lock, or other locking systems active. Look through settings and if necessary, resort to factory default settings.
Aug 05, 2012 | Televison & Video
Someone sold me a Coby HDTV HDMI without a remote. The channel or the volume button on the side of the tv won't work so I got a universal remote. For some reason the only thing the universal remote...
the code that's entered on the remote is the wrong one for the tv. use the instructions for the remote and get the correct code.. for your model or search ebay for the exact remote. also child lock maybe activated on the tv meaning you cant use the buttons on your tv until you use menu on the remote to take it of.
Jun 08, 2011 | Televison & Video
I have a Fender 2x12 Hot Rod Deville. The clean channel seems to be working fine but the overdrive channel is not. I have to turn it up all the way in oder to get just a little bit of sound. So that...
For the Drive channel you need to use the Drive control AND the MASTER volume control. When the Drive channel is active, the Channel Indicator lamp should be RED indicating the Drive Channel is active. The Drive control knob is used to adjust the preamp volume and distortion level of the Drive Channel. This gives you a clue as to what to check if adjusting the controls doesn't work -- the preamp tubes. Having said that, ONLY try to check these tubes with the amp OFF! Never stick your hand up into the chassis of a live amp. It could be lethal. Your preamp tubes are the ones farthest from where the power cord enters the chassis. They have a rubber like stabilizer on them. They have a tendency to wiggle loose, which is part of the reason for the stabilizer. Again, if you're not familiar with the insides...stay out and get an amp tech to help you.
The Normal Channel only uses the Volume Control to adjust volume.
Feb 01, 2011 | Fender Hot Rod Deluxe Guitar Combo...
Just turned the TV on and the volume won't work. Have tried to manually turn it on, use the cable box and adjust the audio settings and nothing will make the volume work.
Memory Initialize operation
NOTE: The execution of this function returns the adjustment codes to the preset values, therefore, adjustment
data will be lost.
Procedure
(1) Enter Adjustment Mode.
(2) Select MEMORY INIT adjustment code (No.704) and change the data value from 0 to 1.
(3) Activate MEMORY INIT by pressing OK button for more than 3 seconds.
(4) Select No.374 and change data value from 1 to 0.
(5) Check that the receiving channel goes to AV1. Unit is set to preset values
Dec 28, 2010 | Hitachi 42PD6600 42 in. HD-Ready Plasma...
Controller will only turn equipment on and off. Can't do anything else, ie: adjust volume, change channel, etc. Universal MX-900 Remote
Hello, Reset the remote control and use with the equipment . If it does adjust volume, change channel. then use have to get another one of different model
May 20, 2010 | Universal MX-900 Remote Control
Multiple issues with tv
Pressing i+ button (bottom left on the original remote) for 5+ seconds worked for me...
Feb 21, 2008 | Philips 32PF5320 32 in. HD-Ready LCD...
Samsum PLH403W service menu
Here is how you get to the service menu. Just be sure to write down anything you change in case you want to change it back.
1. TV turned off
2. Press 'Mute' then '182' then 'Power' buttons on the remote.
You are now in the Adjustment mode
4. Use the 'Channel up'or"Channel dwn' to select the category.
5. Use the 'Volume up or dwn' to enter the category.
note:Some models may not have Category Selection.
6. Use the 'Channel up or dwn' buttons to select item to be adjusted.
7. Write down the old value of the item before changing.
8. Use Volume up and down adjust the value.
9. When you have made all the adjustments you want turn the set off to exit.
Feb 01, 2008 | Samsung PLH403W 40" Rear Projection...
Service menu
1. TV turned off
Jan 23, 2008 | Televison & Video
TV turns on and changes channels on its own
Keeps changing channel
Check voltage on D12 if below 4.8V then change
Changes channel or volume adjusts by itself
Check S900/1/2 on pcb H1, alternatively this could be due to failure of IC005 (CD4052BCM-FL63) on pcb A
Oct 17, 2007 | GE 31GT740 31" TV
Computers & Internet Logo
44 people viewed this question
David Payne
David Payne
