Question about Kenmore 54701 Dehumidifier
Fan stopped running but it sounds like the compressor is still trying to operate.
  • 70 Answers
Eather the fan motor is going bad or the cap is try changing the cap first, if not the motor.
Posted on Jul 18, 2010
2 Suggested Answers
  • 116 Answers
SOURCE: The compressor will not kick
The condition you describe usually indicates that either the compressor is working too hard and drawing too much current or the start relay is gone bad. The noises that you hear may just be a safety shut-off within the relay. A good place to start is changing start relay for the factory recommended one. you will have to access the compressor compartment to see this.
If the standard relay does not correct the problem, there is in most cases a temporary fix, it is called a hard start relay/capacitor. It is usually available from an appliance parts retailer for around $15 to $20. Installation instructions are included, just be sure to unplug your dehumidifier first and make sure that someone following you can repair from where you left off. This relay assembly can normally get you up and running but it should not be used as a permanent fix. This will not correct for a refrigerant leak in the system or a faulty compressor. Outside of this may require having a professional come in to fix the issue, it can range anywhere from a faulty compressor to a refrigerant leak.
Check your owners manual before making any repairs or modifications to your refrigerator. And there may be an extended warranty on the sealed system and compressor if needed.
Posted on Aug 06, 2008
My dehumidifier will run for a minute and stop model 66e0101rf23
It sounds like the fan may not be operating or the air path is plugged up. I think what is happening is you are running the compressor on high head causing it the thermal relay to drop out.
May 15, 2014 | Goldstar Dehumidifiers
Why does the fan run non stop? the compressor runs and shuts off but the fan just runs on high and low. I have 3 other dehumidifiers that the fan runs only when the compressor runs...why doesnt the...
Depending on the time sequence you have this unit set to run, Fredrich's are designed so that the fan runs almost constantly, to keep the air moving. When it senses a rise in humidity above the level you have it set on, the compressor turns ON and runs until the level of humidity is lowered. This is especially true, if you are operating this unit in continual mode.
Hope this helps you and thanks for choosing FixYa.
Aug 14, 2011 | Friedrich D50C Dehumidifier
Compressor runs and gets hot but fan will not kick on. Replaced the capacitor and that did not help. One side of coils gets hot, the other side gets cold, which seems normal. Just can't get the fan...
Don't run the compressor for any length of time without the fan operating. Is it possible that the fan must be replaced? Can you power the fan safely to test it?
Gary
Jul 26, 2011 | Maytag M7DH45B2A Dehumidifier
I have the a Kenmore dehumidifier sometimes it runs fine and other times just the fan runs not the compressor or just the opposite the compressor runs not the fan it is only 2 1/2 years old. What should...
Kathy, I'm not sure you have a problem with the dehumidifier. Depending on which mode you're operating it in, the fan will run in an effort to recirculate the air. If the humidity level rises above the level you have the unit set on, the compressor will then turn ON. This is particularly true, if the unit is operating in continual mode. Then there are other times the fan isn't active, but the compressor turns on when the humidity sensor feels a rise in humidity. So, for the most part, I don't think it's a problem.
Just be sure that you clean the air intake filter at least once every two weeks, during times of daily operation.
Hope this helped you. Please let me know. Thanks.
Jun 27, 2011 | Kenmore 54351 Dehumidifier
Compressor and fan both kick on when starting. Frosts up (normal for this time of year) but then compressor stops but fan continues to run but compressor does not start up again....
From what you have described, it sounds like the defrost sensor may be bad. However, if you're operating the unit in a temperature of 40 degrees or lower. That's the problem. If in a basement application, keep in mind the floor temperature is lower than the air temperature.
Also, cleaning the air intake filter on a regular basis will help.
May 16, 2011 | Edison 40 Pint Dehumidifier
My humidifier has stopped dehumidifying while the unit itself is running. It simply does not take the water out of the air even though the motor is running, sensing the humidity of the basement. Is this...
There are many reasons why a dehumidifier willnot work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrongwith their dehumidifier
Dehumidifier is running but no water is in bucket
heatman101
Apr 23, 2011 | Whirlpool AD50USL Dehumidifier
Year 2005 cycling fan and compressor
Your unit is probably operating in defrost mode. When you use a dehumidifier in a cold room, the condensing coils can freeze water. The unit senses this and thus stops the compressor until the water frozen on the coils melts. Then it resumes its cycle. This is a problem you will have during the winter months. It makes the operation of the unit inefficient, but this is otherwise normal behavior.
Jan 04, 2009 | LG LD50EL Dehumidifier
Fan no compressor will run
I have AD75USTO. Whirlpool  was running yesterday. Today it sound like its starting but will not boot up fan will not kick on. Does it need resetting or what. Only a year old only used for one summer?
Feb 04, 2008 | Whirlpool AD40USR Dehumidifier
Kenmore 54701 Dehumidifier Logo
124 people viewed this question
Top Kenmore Dehumidifiers Experts
Bill Long
Mike Squire
Are you a Kenmore Dehumidifier Expert? Answer questions, earn points and help others
