Question about RTO Spur Sprocket For Stihl 017, 021 Chainsaws
Eng runs but rpm go up and down 1000rpm to 3000
    Brigadier General:
  • 4,088 Answers
Remove the carburetor and check the diaphragm in the lower chamber for loss of flexibility, holes, or cracking. Check the components behind the carburetor for cracking or other damage--air leaks here can cause erratic idle, and could cause cylinder/piston damage if allowed to continue. Make sure the throttle trigger has positive control of the carburetor throttle arm and the return spring is intact. Hope this helps!
Posted on Jul 18, 2010
Toyota corolla hatch 2002 idle at 2000 rpm when
All the above is normal , except 2000rpm is a little high at idle . can be adjusted down to 1500rpm. the computer adjusts the engine speed . in drive the transmission loads up the engine idle drops to 1000rpm . in park engine unloaded rpm increase all normal.
Sep 17, 2014 | Cars & Trucks
Wont rev 3000 rpm
You can continue replacing parts at random or have a competent diagnosis made to identify probable causes of the problem(s).
Mar 24, 2014 | 1997 Nissan Pickup
My 2002 xlt ranger 3.0 v6 flex fuel eng. 115k mi. I start out and it runs good I can run it up to 5000 rpm and it runs good after it warms up to normal temp. if I run it up to 3000 rpm it will just shut...
Could be a mass air flow sensor or the auto choke is staying on,these sorts of problems need the dealer software to drive and diagnose the fault at the same time with nerdy boy with laptop sitting in the passenger seat .Sorry i cannot give a nice fixya easy answer on this one
Dec 31, 2012 | 2002 Ford Ranger
I have a 1998 Freelander 3dr Tdi (L-series Diesel) It just started to idle high (just above 1000rpm) and sometimes it would shoot up to between 3000-4000 rpm when ingaging the clutch (when coming to a...
Check for a possible leaking vacuum system, maybe the vacuum booster is leaking, that would explain the idle being affected by stepping on the brake pedal.
Nov 01, 2017 | 2002 Land Rover Freelander
2006 kawasaki 750 vulcan will not idle , will idle with choke
ok buddy on the carb will be some sort of screw and idle screw turn this in 1/4 of a turn with the machine running until it idles at 1000rpm also the choke will stall the engine when warm the choke is only for cold starts get back to me more info or problems f4d68ca.jpg
Sep 24, 2009 | 1992 kawasaki VN 750 Vulcan
High rev, rough idle in golf
If your car is fuel injection,try changing the cold start temp sender.
Jul 17, 2009 | 1997 Volkswagen Golf
Idle goes down when headlights turned on
Possible weak alternator output or weak battery.
Apr 01, 2009 | 1993 Toyota Corolla
ENGINE DIES
Check for a vaccum leak at the intake with starting fluid. Frankster016
Oct 22, 2008 | 2001 Jeep Grand Cherokee
RTO Spur Sprocket For Stihl 017, 021 Chainsaws Logo
67 people viewed this question
Top RTO Garden Experts
John Trevino
Joseph Mueller
Joseph Mueller
JOHN BROWN
Are you a RTO Garden Expert? Answer questions, earn points and help others
