Question about SimpleTech SimpleDrive Pininfarina 500GB External USB 2.0 Hard Drive - Onyx
I plug in my hard drive and it tells me that i need to format it before use. how do i get my data off of the hard drive?
    President:
  • 2,571 Answers
Try it in differenf usb port
or if you can, try in another pc.
If that dont work, you can take the drive out of the enclosure and try and fit it internally into a computer
if thats not possible, you can buy new enlosures quite cheap to fit the drive into
Posted on Jul 17, 2010
How to recove Seagate external hard drive data?
Probably, the new operating system cannot recognize your Seagate external hard drive. You can connect the Seagate external hard drive to another computer to copy data to another device. If the problem still exists, you might need to perform data recovery. You can free download the data recovery software: http://www.icare-recovery.com/seagate-recovery/seagate-external-cannot-be-recognized.html
May 14, 2014 | Seagate FreeAgent Pro 500GB External USB...
My toshiba 1 tb hard drive all ofa suddn says that i need to format it and i have alot for stuff on it that i need how can i make it work again
Don't be panic. you can try some data recovery software. You can see
http://www.asoftech.com/adr/
It tells the steps how to perform data recovery.
If above does not work, you may have to format the hard drive (use quick format), and then use above mentioned software to scan again the hard drive and recover your files.
Aug 28, 2011 | Maxtor OneTouch 4 500GB External USB 2.0...
I have toshiba cavino 750gb hard drive. it was working fine since last night i can't open it.. it takes long time to open and i see format to paly it i don't want to loose my file i need some...
Don't be panic. you can try some format recovery software. You can see
Aug 03, 2011 | Toshiba (1TBEXT-HDD) (1TBEXTHDD) 1000 GB...
Whenever i plug my toshiba hard disk mk3265sgx its being detected by my computer but cannot access it and if repeatedly bieng accessed its not responding......can u help pls.........
Aug 03, 2011 | Toshiba 320GB MK3265GSX SATA 3Gb/s 2.5"...
I have been using this hard drive with this computer for a couple months now buut this morning when i plugged it in my computer was telling me i need to format it to be able to use it. and i know its...
Best solution would be to try it on another computer & if it works there use the windows check disk tool (& maybe the defragmenter) to correct this problem. OR you could transfer the data onto another hard disk, format this one keeping 2-4 partitions and reload your data.
Nov 11, 2010 | Iomega 1TB Desktop USB 2.0 Hard Drive
Wants me to re-format. how can i keep my documents
download recover my file or ontrack recovery. Recover your files from the hard disk and then format your hard drive if you need crack or serial for the software mail me at dpmmishramishra@gmail.com with the subject recovery crack
May 05, 2010 | LaCie Hard Disk 1TB Desktop with Hi-Speed...
How to avoid formatting drive
What did you format to,fat,fat32,NTFS,
I am not sure if your saying you had it on a desktop pc and now you plugged it into a laptop, or its always been on the same computer
and it just wants to format.
Either way, a computer should not want to format, usually you have to tell it to format, and the only reason to format a hard drive whether internal
or external ,is to change the file system from one to another,
example; FAT to NTFS , or your going to install a operating system to the hard drive.
Its sounds like you had it in a computer whether the same one or a different one, and you did not use the safely remove hardware, or you unplugged it while it was writing data back and forth.
Turn both off, the computer and external hard drive, plug the hard drive
into a different USB port, or firewire, how ever it connects.
Now turn on the external hard drive, wait a few minutes, now start the computer, once in windows if you see this I want to format you hard drive, tell it no, go to control panel and open devise MGR, and look for a yellow shield, under Universal serial bus controllers , the one that has a yellow mark, right click on it and choose properties, read what it says
in the open box, if it says disabled, enable it, if it says no driver,
click on driver tab, and click update driver.
Feb 07, 2010 | Iomega Prestige 1 TB USB 20 Hard Drive
I have a 3.5" hard drives use for back up purposes. This is a very old HDD bought more than 5 yrs ago. What happen was I have not use it for almost a year and when I tried to retrieve some old data, the...
You maybe able to retrieve data from this hard drive by connecting it to an USB hard drive adapter. Then plug this adapter into a working computer's USB port. If the hard drive is OK then this computer will see the adapter as an external hard drive and you can open the folders and files and copy them to the computer's hard drive or to a USB flash drive.
Jan 22, 2010 | Maxtor Hard Drive
Cannot Access my data, even if my laptop detects the drive when plugged
http://www.facebook.com/pages/Asoftech-Data-Recovery/290956907592436?sk=info
Jan 08, 2008 | Western Digital External USB 2.0 80 GB...
SimpleTech SimpleDrive Pininfarina 500GB External USB 2.0 Hard Drive - Onyx Logo
59 people viewed this question
Top SimpleTech Computers & Internet Experts
Marvin
Marvin
Ricky Ostrom
Ricky Ostrom
Arora Singh
Arora Singh
Are you a SimpleTech Computer and Internet Expert? Answer questions, earn points and help others
