Thanks I am savy but can not find the service manual or schematics for this unit. If the output transistors have shorted to ground might it cause this efect do you think? I was thinking of just replacing them and see where i go from there. Not an easy set to work on that is for sure.
  • angelo40 Apr 22, 2008
    Robotek. I could not find any service manual or scematic for this unit. Would you be able to provide some test points for me to check to determine the problem?
  • 1,512 Answers
Hey no worries mate... did you get the other post. We can keep working from there :)
Posted on Apr 26, 2008
  • Graeme Ross
    Graeme Ross May 05, 2008
    hey man, how did you go, would be cool if you could close off this ticket with a rating... is still in my pending list :) Happy to help you sort it out. :)
    Graeme
Samson SX1200 - Protect light on. No blown output transistors.
Have you checked the power supply section? Also look out for any IC's in the amp stages. They can go causing that kind of fault.
Oct 11, 2014 | Samson SX1200 Amplifier
I am attempting to repair a Kustom K100A-1 guitar amp. I found one shorted output transistor, an RCA 36892, which crosses with a NTE 130. Do I need to replace all 5 outputs with matched transistors, or can...
I don't have a schematic for this unit, however good design would not demand matched transistors.
If a transistor has shorted, USUALLY mating transistors have been damaged. I am not sure how "5" outputs are configured as usually there is symetry and an even number. If the "5" are all on one side and there are mating trnsistors of another number, then likely there is damage to more components and probably back one stage in the drivers or even farther.
Hint: when re-powering this after repair, put a 100 Watt light bulb in series with the power into the unit to act as a limiting fuse that resets without driving heavy current into the unit causing more damage due to failed parts that were not eliminated in the first reapir.
Jan 06, 2011 | Music
Where can I get the schematic diagram for this unit? The tuner portion works, both channels of the power amp do not
Service manuals are not available on the net for these. They are suplied to service centers only (as far as I know). These are straightforward units however and should be relatively easy to repair. Are you experienced in audio repair? If so, first check the output transistors. I would suspect that one pair are shorted (at least).
Does the standby light come on? Does the unit attempt to turn on and then shutdown (protect mode)?
Dan
Apr 21, 2010 | Onkyo TX-SV414Pro Receiver
Blawn AC fuse
Almost every modern set will just go into power supply shutdown if the horizontal output transistor is bad or other problems place a heavy load on the secondary side of the supply. Usually that results in a ticking or whistling from the set, but it won't blow the main fuse. A blown fuse typically means shorted parts in the primary side of the power supply.
The switching supplies used in today's sets can be a real pain. Check for a shorted input bridge rectifier or shorted switching transistors. There are also optical isolators used to provide control feedback and they can go bad, causing the supply to run away and blow up parts. A service manual or at least schematic diagram is very helpful. You might be able to find one online. I've checked my files and I don't have anything for the chassis used in this set.
Apr 01, 2009 | Panasonic Televison & Video
Looking for circuit schematic for a Teac AG-7D. There's no visible burning on the board, no blown fuses, the power light comes on, it just won't make a noise any more.
This unit has detected a problem in the output section and the protection circuit is preventing the output relay from turning on. In most cases this is due to shorted output transistors which will need to be replaced. If you have a multimeter, set it to read DC volts and measure the voltage on the three legs of one of the output transistors. You should read .6V, 40V or so and 0.0. I suspect that you will read 40V on two fo the three legs. If so, that is your problem. Please note that the actual reading for the higher voltage may be something other than 40. I don't have the service manual for this model, so I don't know the exact voltage. It will be anywhere from 35V-75V depending upon the actual design and output transistors.
I am not aware of the availability of schematics for this unit, but any shop that works on audio gear should be able to repair this without them.
Dan
Mar 09, 2009 | Teac Audio Players & Recorders
Sony Model No STR-DE475 blinks "PROTECT" even with no speakers
With all speaker wires disconnected and still showing the protect message, the short is internal. This is a rather common failure for these units. The output transistors are shorted themselves. These are relatively simple to replace and run about $15 each. Any service shop that repairs audio can fix this easily. Usually, once the outputs are replaced, you can get many additional years of service from the unit. Yes, it is worth it (in my opinion).
Dan
Dec 01, 2008 | Sony Audio Players & Recorders
Power On + red LED turns on + but final relay (click) don't come so no sound
Your audio output transistors are shorted and your unit is staying in "protect " mode to protect your speakers from 40 to 60 volts that is being sent at them from the shorted outputs. If you can use a meter you won't need the schematic MOST likely because the outputs are USUALLY the only parts that short out. The output transistors( or chip ) are mounted to the large, finned heatsink. The #'s on the transistors start with "2SA-" and "2SC-" followed by numbers. There are two output transistors per channel. If your unit uses an IC for audio output then the # on the IC will be "STK-" followed by numbers. These parts are available from tritronicsinc.com. Good Luck!
barneyluc
Oct 17, 2008 | Denon PMA-2000R 2-Channel Amplifier
Denon AVR-3105 Unit tries to come on but after a few seconds power LED flashes red. (Unit shuts down) I found transistors Q1015L and Q1035L in the output circuit shorted. However, replacing these...
Look for open resistors in the same area. Also, if the transistors that you replaced are the output transistors, you should replace their compliments as well. I don't have the service manual with me at the moment, so I'm juist giving you generalities. If you can, lift the center pin of the output transistors and measure (and post) the voltage readings on each of three pads for each transistor. That should give me enough info to guide you further.
Thanks,
Dan
Oct 07, 2008 | Denon Audio Players & Recorders
INFINITY BASSLINK X BLOWS FUSES
What probably happened was both of the final audio output transistors shorted. This caused a higher than normal drain on the switching transistors on the primary side of the torrid power transformer causing one to short and then blowing the fuse. I replaced both switching transistors and ramped up the current to about 5 amps. I could see the power supply was not working but there was still a short. I traced the short to both audio output transistors. Replaced them and unit is like new. After I found a service manual on this item it was a breeze to find the problem.
Sep 19, 2008 | Infinity BASSLINK Car Subwoofer
Audio Amplifier JVC Model A-GX3
If the service manual is not available on the JVC websites then you should just Google search "JVC A-GX3 service manual" There are many websites that archive manuals. You'll probably have to pay for a copy. Why can't you disassemble the unit and see the output transistor numbers first? More importantly how do you know this is the fault?
Sep 13, 2007 | Audio Players & Recorders
24 people viewed this question
 Grubhead
Grubhead
