Question about Craftsman 24 Hp 48" Deck Yard Tractor
Auto Transmission slips
I have problems going up hill either forward or backwards it feels like I'm spinning but I'm not. When it starts bothering if I slow down the speed it helps some but nothing like it use to do. I have purged it and checked to be sure the brake isn't holding and can't find anything wrong. Looked to see if I could find any way to be sure it has the right amount of oil but can't find anyway of checking this out. Can you give me any advice as to what to do. Thanks for your help. ****
    Sergeant:
  • 200 Answers
The drive belt is probably slipping.Thanks for asking and I hope this helps out.Please leave me 4 thumbs up.
Posted on Jul 20, 2010
  • 110 Answers
The belts on these are kept tight by a large spring and they do not loosen to slip. The simple, however unfortunate; fact is the trans-axle is going bad. There are no serviceable components on the trans-axle and it needs to be replaced. It is an easy but expensive fix. This is what the Sears service plans are for.
Posted on Oct 23, 2010
Transmission problems, after going down hill it stalls out and wont go again for a while.
Hi Marsh:
Sounds like an interesting situation.
There appears to be unrelated issues to resolve.
- Transmission - I'd be looking at the questions:
1) When I want to go forward does it go forward?
2) When I want to go backward does it do it?
If the answers are yes, then UI'd tend to be happy with the transmission.
- Engine - Questions to consider
1) Does it run totally fine on the level?
2) Does it only stall out when going downhill?
Yes answers would make me suspicious of a contaminated fuel problem that is getting into the fuel delivery system when the level of the fuel tank changes.
I'd start by draining and cleaning the carb AND completely draining the fuel tank. Replace the fuel filter, and start over with fresh gas.
Hope this helps;
Cheerfuls.
Time for me to go cut grass.
Jul 07, 2015 | Cub Cadet LTX 1050 KW 50" 23HP Kawasaki...
2001 ford ranger 3.0 auto trans swap out with a 2002 auto trans
On Chevy transmissions there is, on the input shaft, there are two (2) little tabs at the 12 and 6 O'clock position or 180 degrees from one another. When installing the transmission these can often break leaving the transmission useless. It will need to be taken apart and checked on. If it is broken then you can easily replace it from a junkyard trans. (just look forward to a day in the yard tearing apart a transmission) and replace it accordingly.
Keep in mind when reinstaling the replaced transmission, that you HAVE to line these up by spinning the Torque Converter untill it slips on easily. otherwise it will just break again.
Feb 24, 2014 | 2007 GMC Sierra 1500
V70 poured new Dex3 auto trans in. Reverse gear stops working after a few days equal 500km, but all forward are still ok.
Sounds like your transmission is going bad. If your transmission is slipping only in drive or forward gears, then it could be just that it is low on fluid, but when reverse starts to slip it usually means rebuild/replace transmission.
Good luck
Dec 02, 2013 | Cars & Trucks
Just bought a 4wd 07 chevy tahoe LT. Was spinning out in reverse on a sheet of ice and only the rear wheels moved. did it a few times and got same result. Is the car just not 4wd in reverse? Thank you...
WERE YOU in auto 4wd or 4hi? sometimes vehicles will pop out of 4wd in reverse the auto mode detects slip going forward not backwards so if in auto tes it will have problems in reverse.
Dec 22, 2010 | 2007 Chevrolet Tahoe
Auto trannsmission, shifts nice in reverse but feels like it slips when trying to go in forward gears, would transmission flush help or is it internal?
reverse is the last gear to go out in a auto trans when the clutch packs are wore out. It would be a internal problem.
Dec 04, 2010 | 1990 Nissan Maxima
Wife was driving home from work in 2002 Mazda 626. While going up off-ramp, suddenly, the auto transmission started slipping, then she couldn't move forward or back, just slips. After car sat, I tried and...
I believe your transmission may be shot, Check your dipstick level to make sure your fluid level is full. If it is than your transmission may need a overhaul.
Jun 16, 2010 | 2002 Mazda 626
I have an automatic trans mission that doesnt go
The forward gears slip but dose the reversr gear slip as well if not your problem is either the forward band is worn out ,,,,or the forward pump is playing up and also it could be the thing that starts it all off is the filter in the auto sump is clogged up with metal or drive band dust is the colour of the auto oil dark or dirty..
When was the trans oil last changed.
Oct 10, 2009 | 1995 Jeep Grand Cherokee
I have a 4 cyl 91 Camry ...the transmission seems to be slipping and when i am on a hill i usually put my left foot on the brake and the right on the gas ...do a EZ rev and get the transmission to engage...
Hi and Welome to fixya.com.
Changing the Gearbox oil is fine but this is nothing to do with your clutch slipping, sounds has if you need to replace the whole clutch unit.
Best regards.
George.....
Jul 27, 2009 | 1994 Toyota Camry
Daughter owns 96 960volvo transmission slipping ,where is the transmission stick? feel stupid Hamone
Need replacement or overhauling. When it becomes really bad, the car will not able to move forward or backward. if that happen, stop the engine for about 20 to 30 minutes. Start the engine and straight to he nearest garage.
Jul 14, 2009 | 1996 Volvo 960
Ford Falcon 1995 Auto Problem
have you checked the transmission fluid? if it is low can cause this. if not then it is an internal problem in transmission.
Dec 12, 2008 | 2004 Chevrolet TrailBlazer
Craftsman 24 Hp 48" Deck Yard Tractor Logo
652 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Mike Squire
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
