Question about Soleus KY-32U Portable Air Conditioner
Drain hose fro Soleus KY-32U
How do I hook up a drain hose for Soleus KY-32U portable A/C
3 Suggested Answers
TheMobilian
  • 8220 Answers
SOURCE: We have a 9000 btu portable frigidare air
Wow maybe you have a lot of moisture in the air.
It is a strong posibility the pump has trash in it. periodically clean out the pump for best results.
I realy have never even seen a 9000 btu portable ac or worked on one. Just guessing.
Posted on Jun 25, 2009
guru_fixya
  • 944 Answers
SOURCE: On soleus ky-32u air conditioner,
The water tank is full the solution is to Empty the water tank.
The water tank is not installed correctly.Just install it correctly.Completely re-insert the water tank again
See page no 14 in the manual.
click here to download the manual.
post a comment for further assistance.
Thank you for using fixya have a nice day:-)
Posted on Sep 25, 2010
I have a soleus pe2-10r32 portable a/c and it is leaking out of the back of the machine but not all the time! i put a drain hose out of the drain port so it can drain into a bucket that worked fine for a...
This is your condensation build up on the A/C unit. You will have to have a drain on it all of the time. Should have a drain that goes outside. The more humidity the more water run off you will have.
Jul 21, 2014 | Soleus Heating & Cooling
Exhaust hose
I would try any plumbing/heating store.
May 14, 2014 | Soleus KY-34 Portable Air Conditioner
My portable ac says to add water, how do i do that
There are 2 issues.
The first is that there is a water container in which you must fill water so the compressor cools. This is housed usually in the side. There is an automatic push panel on the side of the unit which when pushed opens the door. The container sits inside which needs to be taken out and filled daily.
The other is the water that condenses because of cooling the air. This settleas at the bottom of the ac. Bend down abd you will see a drain plug and a rubber blocker. Unscrew the drain plug and pull the rubber. All the condensed water will flow out. It can be messay so preferably drain in the bathroom.
Nov 15, 2011 | Soleus KY-34 Portable Air Conditioner
My unit keeps pouring water out what does that mean it also keeps saying full how do I make it stop or how do I empty it?
In case you have misplaced your owners manual, I have included a link to one that is almost identical to yours. There are several ways to drain the water collection tank. So, I want you to be able to choose the one that fits your situation the best.
You can download and print the manual for future reference.
http://cache.air-conditioner-home.com/manuals/soleus-ph3-12r-03.pdf
Hope this helps you.
Jul 08, 2011 | Soleus KY-34 Portable Air Conditioner
Need a new window kit adaptor for 9000ah
you should be able to find that through a heating and air condition company they should with all the model and searial numbers be able to order it for you
Aug 23, 2009 | Soleus KY-34 Portable Air Conditioner
Soleus A/C unit is leaking water out of drain plug
it is working well, possibly has a bad sensor to tell you it's full but put a permanent drain on, run it in the sink or dump it more often. just means it's pulling out excessive amounts of moisture
Nov 03, 2017 | Soleus KY-34 Portable Air Conditioner
Same problem with the leaking from the base of the soleus unit
There is nothing wrong with the unit, you just are in a humid area, the water is from the air.
The water is being pulled from the air, that is part of how it cools, by condensing water.
Some units have hose fittings that can be hooked up to normal garden hoses and routed outside.
You could also install something like that yourself.
Jul 25, 2009 | Soleus KY-34 Portable Air Conditioner
My Unit is running but is saying it is full
yes you do need to drain the water that has built up. there is a little hose with a plug in it located at the bottom rear under the exhaust hose. but be sure to drain it somewhere so that you don't ruin your floor. the water of course builds up from the ac's condensor. It doesn't take all that long to get full either.
Jul 06, 2008 | Soleus KY-34 Portable Air Conditioner
Solebus heating
yes, it is intended that way. I also have a Soleus and a special manual addendum sheet was inside the manual and it pointed out this feature..I think Soleus had a lot of customer phone-ins over this...I guess the idea for the exhaust is to withdraw moisture from the room, since anytime air is heated or cooled, moisture is a by-product that must be eliminated.
Nov 03, 2007 | Soleus KY-34 Portable Air Conditioner
Soleus KY-32U Portable Air Conditioner Logo
104 people viewed this question
Top Soleus Heating & Cooling Experts
Michael Galve
Michael Galve
Coss
Dennis Boxerman
Are you a Soleus Heating and Cooling Expert? Answer questions, earn points and help others
