Question about Xantrex Technology Xantrex 458 10 12 Freedom 1,000 Watt Inverter/Charger
I have a freedom 10 inverter charger and the reset keeps tripping
I have a freedom 10 inverter charger and the reset button keeps tripping and will not run the front air its a 1997 discovery running 30 amps out the plug any help? we have looked at all the wiring and ran fine 3 days before we were suppose to leave on a trip now were stuck trying to find out what might be wrong with our inverter.The input does not trip just the switch for the inverter/charger most of the appliances were in the RV but not the ac.
SOURCE: Freedom 20 stopped working after ac breaker tripped
How do you get the PCB out all the 4 screws are out and clips are pushed off the pcb contacts on the sides. Unscrewed the antenna, but not the soldered in bulk antenna mount. I is still locked in somehow? how do I get the board out to look at the keypad buttons so I can see if threre is a bad contact?
Posted on Sep 11, 2009
  • 91 Answers
SOURCE: Wiring Freedom 20 inverter
make sure your new inverter is made for 220 volt supply as that is what the red wire represents. its the other leg of a 220 circuit and should not be connected to your new inverter until you read the manual to see if it is designed for this and if so how to wire it in. it could cause you are the unit serious harm if you connect a 110 inverter to a 220 circuit. consult an rv repair shop or a good electrition if you cant find the needed info. it may actually be printed on the side of the inverter as well.
Posted on May 28, 2010
kel1guy2002
  • 3740 Answers
SOURCE: my 2000 Fleetwood Discovery Motorhome
Terry this unit has 2 AC outputs so the reading that you got is correct. I am trying to surmise the actual problem that you have. You may have lost a system ground in the mobile home which would give you power as you stated but no power to the mobile home as the system ground has been lost.
Dumb questions time.
1. Battery voltage above 10 Volts?
2. Have you checked the DC Fuse?
3. Have you reset the breaker on the control panel?
Last test.. is to disconnect all outputs and try a voltage test again. A system distribution short will cause the inverter to go into the self protect mode.
Kelly
Posted on Aug 25, 2010
  • 905 Answers
SOURCE: Freedom Combi inverter/charger stopped working
Sounds like the link between the inverter and the remote is bad. Chaffed wire, broken wire, etc may be the culprit.
You should still have the shorting jumper that came with the Freedom. Put the jumper into the AUX port, and you should now have local control of the inverter. If so, then replace the wiring between inverter and remote.
Posted on Aug 30, 2010
mwoodring1
  • 496 Answers
SOURCE: I have a xantrex 2000 watt freedom 458 freedom
this isn't an answer but i would like to just clear the water a little. how old is the unit? you say it the inverter works when on shore power ( 110v A.C. wall plug or 220 ) but it will not charge the batteries while hooked up to shore power? are you trying to use a generator to run the inverter and charge the batteries? I just need to a little more so i can better understand you problem and help you better
Looking forward to hearing back from you.
M.Woodring
Posted on Jun 21, 2011
Why does my Freedom 100 Watt Inverter/Charger remains in bulk
It sounds like a bad battery mine did the same but it was a much larger unit changed the house AGM Batteries and works perfectly
Jun 09, 2014 | Xantrex Technology Xantrex 458 10 12...
My Xantrex freedom Marine 25 inverter cut-out trips
Call Tekris I used therm for a repair they are friendly reasonable and do excellent repairs Tel is 732 938 4996 Located in Farmingdale NJ.
Aug 14, 2017 | Xantrex Technology Heart Freedom 25...
Is there a bench test for the Xantrex freedom 458 inverter/charger?
My experience has been thay there is no real "bench test" available to the general public. You can do some testing if you are familiar with how to read the color codes on resistors, and know how to test relays. There are two fuses inside, so you can check their continuity. Before going to this trouble though, get on line and download the Xantrex trouble shooting guide, bulletin No. 512-0084001-01 rev1. If that is ok, it'll be a trip to the dealer, where you'll learn that it costs about $400 to replace the board. I'm on my second one, in two years, so they aren't a long life article I'm afraid.Hope this is helpful for you.
May 09, 2011 | Xantrex Technology Xantrex 458 10 12...
Freedom Combi inverter/charger stopped working with the remote inside the RV. Replaced remote but still didn't work. I have to press inverter button inside RV, go to inverter outside RV and press...
Aug 08, 2010 | Xantrex Technology Xantrex 458 10 12...
Xantrex 458 freedom....has stopped charging house batteries off of engine alternator. Alternator is showing that it works (dash gauge). It does charge while on shore power or generator....but not charging...
Fis\rst of all is the inverter supplying 120 VAC? when turned on?. If so the inverter seems to be working.I think your problem is in the truck alternator/charging system. The inverter is independent of this charger..
Mar 23, 2010 | Xantrex Technology Xantrex 458 10 12...
Our Inverter works but the battery charger seems to trip out everytime we try to charge the batteries.
There is no way to guess what the problem is, we technicians use a multimeter to look at the electrical circuit values to determine the problem. The charging circuit could be bad, or the batteries could be shorted.
Nov 23, 2009 | Xantrex Technology Heart Freedom 25...
Sep 10, 2009 | Xantrex Technology Heart Freedom 20 12...
Xantrex Technology Xantrex 458 10 12 Freedom 1,000 Watt Inverter/Charger Logo
98 people viewed this question
Top Xantrex Technology Boating Experts
Craig Butler
Craig Butler
Tre Elkins
Are you a Xantrex Technology Boating Expert? Answer questions, earn points and help others
