Question about Dell 924 All-in-One InkJet Printer
Printer is installed but still isn't printing
    Guru:
  • 366 Answers
Hi
You need to Check
1. Is the printer turned on or is the usb plugged in?
2. If so, try pressing the printer resume button.
3. If it still doesn't print, look at your printer settings at the control panel and see if the actual printer your using is the default printer...
Once all done ... please re start your printer and it should work fine.
Posted on Jul 18, 2010
I have installed the lexmarkx1100 printer and the computer tells me it was succesful, but wheb I go to use it a message says that the local print spooler is not running. What do I do I tried to instal
Rebooting the PC will restart the Print Spooler service, if this isn't an option go to:
Start>Control Panel>Administrative Tools>Services find Print Spooler in the list and right click and select Stop then right clikc and select Start
Feb 08, 2012 | Lexmark All-in-One Printer, Scanner &...
Printer prints fine so far as text, but a black and white photo has streaks in it. Black Ink level shows it isn't low
Try to clean the printhead nozzles. From the printer operator panel, press the Setup button > Maintenance > Deep Clean Printhead. Your printer will then print a test page forcing ink through the cartridge nozzles and clean them. Try to print your photo again to verify that the print quality has improved.
Also, make sure your printer is udpated. Please visit the Lexmark website to download and install the Lexmark Pro200 Series Firmware Update. The update will help give you a highly reliable print system.
If that doesn't help, please contact Lexmark Technical Support Center for additional assistance.
Sep 02, 2011 | Lexmark Prospect Pro205 Wireless...
My printer isn't printing anything. It takes the paper and sounds like it's printing bur pages are blank.
Did you remove the tape from the cartridges before you installed it?
Did the printer work before?
Let me know because I would really like to help
Andre
Aug 25, 2011 | HP Officejet 7210 All-In-One InkJet...
I BOUGHT A HP NEW PRINTER J 3680 WICH DOES NOT SUPPORT WINDOW 98. IS THERE ANY PRINTER DRIVER WHICH CAN HELP ME PRINT FROM THE SYSTOMS WHICH IS RUNNING ON WINDOWS 98.
No there isn't since the hardware of the printer can't support the 16bit drivers the Win98 uses - you will need to install XP to use this printer.
Jun 06, 2011 | HP Office Equipment & Supplies
Trying to reinstall HP PSC 1610 printer. Getting print spooler service not running. Tried to fix with Diagnostics, get an error 1068. Cannot install printer.
Check in control panel->administrative tools->services
This will show all services, running or not, that are installed on your pc. You are looking for the one called "Print Spooler" double click on its entry in the list and set it to automatic if it isn't already.
May 05, 2011 | HP PSC 1610 All-In-One Printer, Scanner...
I am a senior citizen lady who is not a printer use expert, but my printer is not working well..the black print is light gray and the color print is only light pink. I got new ink cartridges and it still...
Please check out this tutorial from the Hp Official Website...
Click here to open the link
This is a step by step instructions on how to install the cartridges.
If you have problem, let me know.
Good luck.
Thanks for using FixYa.
Aug 12, 2010 | HP DeskJet F380 All-In-One Printer
Windows 7 cannot find my hawking pn7127 print server. All my xp computers print to it no problem , My port is http://192.168.1.5/lp1. Even when I input this info, Windows 7 cannot communicate with the...
1. Click "Add a printer".
2. Click "Add a network printer".
3. Click "The printer that I want isn't listed".
4. Select "Add a printer using TCP/IP". Click "Next".
5. Type in the print server's IP address. Click "Next".
6. Select "Custom". Click "Settings".
7. Change Protocol to "LPR". In LPR Settings, type in "lp1". Click "OK".
8. Click "Next". Select your printer. If your printer isn't listed, click "Windows Update". If still not listed, install driver from manufacturer's website.
9. Print a test page!
Mar 10, 2010 | Hawking 10/100M Internet Print Server...
Priter does't respond when i used it to print a document
Printer isn’t responding? Please check the following:
i. Is it powered on? If so good.
ii. Is the printer cable connected from printer to your computer? If so good.
iii. Check to see if printer is properly installed. Go to start/control panel/printers and faxes. When the box pops up with the list of installed printers check to see if your printer is listed. If not listed it means your printer is not installed. This also invariably implies that your printer cable (from printer to computer) is bad. Change it and your printer should install and you should be able to print then.
Dec 04, 2009 | HP DeskJet 3550 InkJet Printer
My printer is intalled but it does print.
Your problem is that even though you say that your printer is installed it stll isn"t and you need to reinstall your printer driver softaware and be cautious to answer all the questions correctly.
Dec 26, 2008 | HP LaserJet 2840 Printer
Dell 924 All-in-One InkJet Printer Logo
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
