My Cuisinart Grind and Brew Thermal coffee maker isn't brewing coffee. I can set the timer, I can...
(More)
My Cuisinart Grind and Brew Thermal coffee maker isn't brewing coffee. I can set the timer, I can hear the beans being ground, but it won't brew. All the pieces are in place/engaged. Even if I don't use the timer function, it doesn't work. HELP!
Hi, I have the stainless steel grind and brew and all of a sudden the coffee grinder part won't come...
(More)
Hi, I have the stainless steel grind and brew and all of a sudden the coffee grinder part won't come off for me to clean. How can I get it off if it's stuck? I mean really stuck. Thanks.
The grinder in my Cuisinart Grind & Brew is stuck and can only be removed by prying with a...
(More)
The grinder in my Cuisinart Grind & Brew is stuck and can only be removed by prying with a screwdriver. Should I replace the grinder?
When I use whole beans, the grind seems very coarse. It wasn't always like this, I'm just noticing...
(More)
When I use whole beans, the grind seems very coarse. It wasn't always like this, I'm just noticing it in the last couple of weeks after dumping the used grounds. Is there any way to fix or adjust the grind setting?
