Question about Propellerhead ReCycle 2.1 (7350002920091)
Recycle constantly gets stuck after 20 seconds or so, and then i have to force quit it, and loose everything again. Do you have a solution?
    President:
  • 2,571 Answers
Try re installing it, updating your audio driver if possible.
Posted on Jul 17, 2010
New (reconditioned) 33cc. Starts ok, after 20-30 seconds at cutting speed starts to loose power. Eventually dies, then after 10 mins or so, starts up, same problem again. No smoke or other indication.
Try popping the fuel cap for a moment when the saw quits. If this helps, remove the left side engine cover and check the small porous bronze fuel tank vent disc that allows the tank to breath. It may be plugged with sawdust. Make sure the bar/chain is being properly oiled, and that you can turn the chain by hand. A very sharp chain always helps. Remove the spark plug when it quits to make sure the spark is good. Try a fresh plug gapped at 0.020" if there is no spark. If no help, the ignition module may be failing with heat (time to take the machine back for refund or warranty repair). If you are stuck, get back to us for further help. Hope this helps!
Nov 16, 2010 | Homelite Garden
A/c heat mix up volvo v50
The Dealer has a software upgrade the fixes this
Aug 07, 2009 | 2006 Volvo V50
Pump hums when switched on but does not work more than 20 seconds
hi i had the same problem with my booster pump motor it hum but did not turn. to make a long story short see if there is a metal cap on the back of your motor if there is pry it off and you should get to see the shaft turn the shaft with a screwdriver if it has a notch in it or if it don't turn the shaft anyway you can and make sure it turns easy. my shaft was tight as hell but i got it to turn and it started right up again and i had no problem. the hum means it is stuck and it shuts off because the breaker is tripping and after a few seconds it will click back on again, hope this helps
Jul 06, 2009 | Emerson Pool & Spa
I have a Panasonic DP 2310, everything starts and goes to ready. I press start and the display blinks, almost like a power recycle and it says copying but nothing happens, no errors. Any ideas?
there is a short on the board under the start button some where , its quite possible that the solder on the button has come loose and you mite need to solder it again
Jun 29, 2009 | Panasonic FP-D605S2 Copier
Flame will cut off in 30 second
check the loose blower wheel and lint in the filter housing phenom associated with these dryers. The operator coils will get hot and quit and cool down after several hours and work again making it imposible to pinpoint a solution. Replace those coils. $20 bucks.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Dec 17, 2008 | Maytag Neptune MDG5500AW Gas Dryer
GAME NOT GOING IN STUCK AT THE ENTER TO THE PS3
That or the bluray track is off.. if you are brave take it apart.. but I suggest calling sony to see what they can do!
Jun 27, 2008 | Sony Playstation 3 (PS3) Console
Constant switch between ON/OFF/source
Does the menu controls work on front panel?If so you can try factory reset or Recall as it is called on some monitors.
Mar 07, 2007 | ViewSonic VX924 19" LCD Monitor
Propellerhead ReCycle 2.1 (7350002920091) Logo
94 people viewed this question
Top Propellerhead Computers & Internet Experts
Chris Larocque
Nikki  Mclean
Nikki Mclean
Alun Cox
Are you a Propellerhead Computer and Internet Expert? Answer questions, earn points and help others
