Question about Sony Grand WEGA KDF-42WE655 42" Rear Projection HDTV
Sony Grand Wega KDF-42WE655; 2 problems
I have had the set for two years, (1) about a year ago, a constant buzzing occurs when we turn on a particular light switch that sounds almost like electrical feed back.(2) The more recent problem is quite annoying, every few seconds a crack/crackle occurs through the speakers, doesn't matter if volume is high or low.
    Sergeant:
    Champion:
  • 319 Answers
You have a problem with EFM interference from a light that has a dimmer switch. Turn dimmer all the way up or off, buzzing will cease
Posted on May 10, 2008
Pure dab radio keeps cutting out
My Pure Evoke 1S ran fine for years. Then two years ago it started cutting out every now and again, and, at other times, just failing to switch on, by constantly recycling between off and on. The higher the volume setting, the quicker it cut out.
I persevered with the radio because a) it was expensive at £90, b) the sound is very good quality, and c) I could not see a reason for the fault other than a component failure (and there was no obvious sign for that).
I then discovered the fix and it is quite simple. With the radio on, select the menu option "Energy Saving Settings" and set the option to "NO". The radio will works as normal, immediately.
Hope this works for you, too.
May 28, 2012 | Audio Players & Recorders
The tv made poping sound & it lost the picture but the sound was ok, their is buzzing sound coming from inside the tv, after about a min. the set turn off & red light stays on. reset tv, same...
This model is prone to a lot of problems to the point where a year or so ago they offered a chassis replacement on an exchange basis.
I would with rear cover removed try to localize first where the sound or buzz is coming from: The ballast? the Light engine? The power supply?
I can help but as I said this model has a LOT of chronic problems.
Steve
Nov 01, 2011 | Mitsubishi WD-52525 52" Rear Projection...
I have a bose wave radio fo many years, when turn it on there is a constant buzz as the radio plays. the buzz varies if i move or position the radio differently. sounds antenna related but there is no...
The antenna is built in. The buzz you're hearing is a 60cycle hum (electricity from a nearby appliance) Try this, put an extension cord on it and walk it around your listening room for best reception. You can also find the culprit appliance by turning items off 1 by 1 until buzz subsides.
Jan 04, 2011 | Bose Wave Radio
I installed a Heat-n-Glo 6000GLX with wall mount control 4 years ago. Has been trouble free till this year. Actually problem may have started last year where the flame would light then flame out in 3-5...
sounds like your control module is defective, put you hand on the control unit and see if you can feel the noise.
Please Rate/Vote this response. Thanks
Dec 20, 2010 | Heating & Cooling
Constant noise from Mirage NanoSat 5.1 System Subwoofer
sounds like an earth fault either with the plug circut or more likely with the power board of the unit.
Jan 06, 2010 | Mirage NANOSAT 5.1 System System
Dead sony
The $1200 was for the lcd engine not the lamp. You should change the lamp. The buzz is the power supply trying to light the lamp.
Apr 25, 2008 | Sony Grand WEGA KF60WE610 60" Rear...
Sony dead !!!!
Jedi,
Sounds like lamp and driver need to be replaced again... Lamp is Sony p/n# A-1052-675-B and the driver p/n# 1-468-798-14
Bill
Apr 24, 2008 | Sony Grand WEGA KF60WE610 60" Rear...
My 60" lcd projection tv wont turn on sometimes and throws a lamp light, and if i watch tv for a while and turn it off it wont turn back on and throws the red lamp light
The buzzing sound you most likely hear is the ballast trying to fire up the lamp. I would say replace the lamp and yes they can act up at will. If this is the first lamp replacement ever then you are doing good.
Feb 01, 2007 | Hitachi 60V500 60" Rear Projection...
Sony Grand WEGA KDF-42WE655 42" Rear Projection HDTV Logo
105 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
