Question about Frigidaire 24 in. FDB1050REC Stainless Steel Built-in Dishwasher
I HAVE A KENWOOD KDW12ST3A DISHWASHER AND IT HAS THE E4 ERROR CODE THEY DID NOT GIVE ME A MANUAL WITH IT CAN YOU HELP
  • pd_kuwait Jan 06, 2009
    I have a Kenwood KDW12ST3A displaying E4 error code, washer not draining and leaking water out of front.
I hav a kenwood kdw12st3a and the e4 code came up and it said in the manual it had overfilled but it did'nt tell you how too fix it can you help
Posted on Oct 29, 2008
From here you can download the complete geniuine instruction manual and usee guide for Kenwood KDW12ST3A Dishwasher.
http://www.partmaster.co.uk/company/partmaster/manuals/Kenwood%20KDW12ST3A.pdf
Enjoy!
Posted on Jan 13, 2009
3 Suggested Answers
  • 113 Answers
SOURCE: error code e4 on kenwood kdw12st3a dishwasher too much inlet wate
HI there,
I have had the same problem as most of you. I seem to have fixed it by
1. Bail out all the water from the inside
2. Remove the filter and 2 x mesh pieces.
3. Continue to bail out the water from the filter well.
4. You will probably find pieces of food or fat/debris in the bottom of the well. Remove these.
5. Tilt back the dishwasher at 45 degrees for 30 mins or so to drain and dry the flood sensor.
6. Boil a kettle and pour it down the well. Immediately put the dish washer on a eco wash (no tablets or anything) with half load (ie half water) and this will ease the water pump.
7. Let the dishwasher run its cycle.
8. Clean the filter again and the filter well.
It sounds quite long winded but with a £250 item you need to take care of it. Make sure you rinse most plates before loading in the future.
Hope this helps!!!
Good Luck!!!
neo
Posted on Mar 01, 2009
HansPP
  • 2510 Answers
SOURCE: i have a kenwood KDW12ST3A
HERE IS A LEAK AND IT IS BUILDING UP IN THE BOTTOM DRIP TRAY!. It is filling up the drip tray and tripping the micro switch. Remove the lid(2 screws at rear),givng access to screws on top of right side panel,remove right side panel, you will have to remove plastic cover on bottom front first to give access to screws on side panel. This gives access to the hoses and such, where the leak is most likely coming from. I would buy some inch and a half to 2 inch hose clips first, as the clips on the machine are not really reusable.The machine will have to be put on its left side, you may have to remove the bottom drip tray also, this holds the micro switch and the polystyrene float. You may have to run the machine to see where the leak is coming from, It is time consuming, but very "doable", remember electricity and water do not mix,unplug and make sure everything is dry, particularly yourself!.
Posted on Apr 26, 2011
Kenwood KDW12ST3A dishwasher keeps bleeping and showing E4
Many owners manual list common error codes. I would check there first. If that doesn't work try repairclinic.com and access trouble shooting DIY help by model number for model specific information. Good luck.
Jun 27, 2015 | Kenwood Dishwashers
Hi ive lost the instruction manual for the kenwood dishwasher KDW12SL3A could anyone help me please?
You can download one from here:-
www.partmaster.co.uk/.../manuals/Kenwood%20KDW12SL3A.pdf
Feb 01, 2012 | Kenwood KDW12ST3A Built-in Dishwasher
I need a manual for a kenwood dishwasher kdw12st3a
HI!!
Click on the following link to get a manual for your Kenwood Dishwasher http://www.partmaster.co.uk/company/partmaster/manuals/Kenwood%20KDW12ST3A.pdf
Don't forget to rate this post!!
Sep 02, 2010 | Dishwashers
My Kenwood Dishwasher shows an E4 error code
Howdy:) An E4 or E5 error indicate an abnormal water level which means too much inlet water. Here is the shortcut to the Kenwood PDF file with the user's manuals.
http://dl.owneriq.net/4/4e71b4c9-e100-4066-a29e-9c46abc1f5cf.pdf
You can cut and paste it into your browser's address window. Your model was not indicated in your message, but the error codes are standard throughout the Kenwood models. I hope you find this useful:)
Aug 25, 2010 | Microwave Ovens
What men cod e4 on dishwosher kenwood kdw12st3a
Hi
Error e4 on Kenmore usually occurs when there is drain clogging or due to debris stuck in the bottom of the dishwasher. Drain out the excess water from the dishwasher, now remove the mesh and the filter. Now, check and remove any food material or debris stuck. Now pour 1-2 litres of luke warm water and let this water drain. After this replace the parts and run the dishwasher on eco mode without any tablets or soap. Try this 2-3 times and then reset the dishwasher by unplugging it for 5-10 minutes.
Please post back for any further assistance.
Daniel
Jul 21, 2010 | Kenmore 15762 Dishwasher
Hi there, I have a kenwood dishwasher KDW12ST3A an...
For the manual, try this link: http://www.partmaster.co.uk/company/partmaster/manuals/Kenwood%20KDW12ST3A.pdf
hope that helps
May 19, 2010 | Kenmore 15762 Dishwasher
Kenwood dishwasher kdw12st3a user guide
GO TO PARTMASTER http://www.partmaster.co.uk/cgi-bin/home.pl
SCROLL DOWN TO BOTTOM LEFT AND USE INSTRUCTION MANUAL DOWNLOAD
AND ITS FREE.
Dec 09, 2008 | Kenmore 15762 Dishwasher
Kenwood dishwasher kdw12st3a error code e3, what does this mean ?
in the manual I have for this machine model E3 means: Longer heating time but not reaching requied temperature. The possible causes: malfunction of temperature sensor or of heating element
Aug 01, 2008 | Dishwashers
Open Questions:
See all Frigidaire 24 in. FDB1050REC Stainless Steel Questions
Frigidaire 24 in. FDB1050REC Stainless Steel Built-in Dishwasher Logo
3,220 people viewed this question
Top Frigidaire Dishwashers Experts
Mike
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
