Question about Pioneer GM-7100M Car Audio Amplifier
After 5 seconds of being on, it will shut off for no reason. I checked all fuses and they were fine. all wires seem to have a good connection as well.
  • 58 Answers
Check to make sure the coils on your speaker,are good.
Posted on Jul 18, 2010
Lead pops off thermal fuse on my panasonic ne1054f
The thermostat and the terminal on the wire must be replaced.
When a terminal is overheated (usually due to excessive current or heat due to a loose connection) the physical characteristics of the metal change, and they will never be the same.
You should also cut back the lead wire an inch or so until you get a bright shiny copper color, making sure you have cut away all the dull pinkish wire.
A similar service manual can be found here, and it should be close enough to help you.
You can order Panasonic parts from Encompass here.
Nov 30, 2012 | Panasonic NE1054F - Pro Microwave Oven, 10...
'74 CB200 headlight not working.
i would change the headlight because if one side of the bulb lights up that means that the lower beam is bad or just check your fuse you may have two fuses to that connection
May 30, 2012 | 1974 Honda CB 200
My 99 Taurus acts like the battery is dead it will crank the engine over a couple times slowly then nothing I've had the battery tested and it was good same with the starter it won't jump start...
If the battery and starter have proven good, then you probably have a connection issue.Check condition of battery, wire to battery, and starter wires and connections also. I dont know your particular situation, but there is always the possibility of a motor trying to sieze.
Sep 02, 2011 | 1999 Ford Taurus
Wired jvc stero in a 2005 jeep cherokee, push power button nothing, push cd eject button & lights up plus accepts a cd then shuts off? what can i do?
First check the fuses, if the fuses seem to be fine then do the following steps.
Try doing everything you explained with the ignition key in the off position. If you can still do all of that with the ignition off, then you probably have a bad connection on the RED wire. If you can't do that stuff with the ignition off, then you may have a bad connection on the YELLOW wire. Also you might as well check the BLACK wire (ground).
If the fuses were good and all of the wires had a good connection you may want to use a tester to check and make sure the wires don't have a short somewhere.
If you checked everything and you still have the same problem, then my guess would be that something has went out internally on the stereo.
Hope this helps.
Mar 11, 2011 | Car Audio & Video
Just replaced spark plugs and wires with one that were recommended for the car. Drove the car for a week after chaning them it ran fine. Now I seem to have a idle issue to the point that the car shuts off....
CHECK ALL PLUGS AND WIRES MAKE SURE THEY ARE ON GOOD.IF ALL IS GOOD YOU COULD HAVE BAD OR WRONG TYPE OF PLUGS AND WIRES.RECHECK MAKE SURE SPARK PLUG GAPS IS CORRECT.
Jun 09, 2010 | 2002 Mercury Cougar
98 FZR600. No Electric
check main fuse again by the starter solenoid
Jul 09, 2009 | 1995 Yamaha FZR 600
AVR-589 Denon Receiver Keeps Shutting Off
even if the wires are not touching they can still arch. make sure there is no bare wire showing ie. cannot see any unshielde speaker wires. id unplug then replug back in
May 18, 2009 | Denon AVR-3805 Receiver
05 Suzuki Forenzo Radio Problem
Display connection faulty, take apart and check connection from the display screen.
Apr 21, 2017 | 2005 Suzuki Forenza
AMP FOR SUB SHUTS OFF SOMETIMES
your amp may be overheating, or you have it up too loud and the surge protector is shutting it of in fear of damage to your amp.
Apr 24, 2008 | Kenwood KAC-7202 Car Audio Amplifier
Pioneer GM-7100M Car Audio Amplifier Logo
29 people viewed this question
Top Pioneer Car Audio & Video Experts
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
