Question about Fujitsu Siemens Business Line 431V FA 17" LCD Monitor
Monitor turns off
My monitor stops displaying but the on LED is still on. I turn it of and on again. It displays but after some time (10-20 seconds) it stops displaying again. I switch it off and on again. it keeps on doing this tedious routine again and again.
  • Ron Kloiber May 18, 2008
    Same problem with a different Fujitsu 17"... traced it down to the inverter 1/2 of the power supply board (both inverter and p/s on same board), but not to the component yet.
  • delt0r Dec 19, 2008
    I have exactly the same problem. Working on the inside of the monitor sounds like a bad idea
  • 180 Answers
That would have to do with the invertor board inside the lcd monitor.
Posted on Apr 21, 2008
Display not working, power button LED turns on blue for 1 second and won't turn on again
Have you tried checking with another monitor. Meaning that if the second monitor does not come on then the problem is with your computers mother board. But if the monitor other monitor you check it with comes on then of course it is your monitor.
Jun 12, 2016 | Acer 22" X223w LCD Monitor
My hp 1502 lcd monitor only shows a white screen
If you don't use an identical monitors, then they may not work if your video card can not handle them. The "check video cable" it means the monitor does not get a signal, and it does not mean that the monitor is a problematic monitor. You can test this monitor as a single monitor (and try to connect it using first video port, and then move it to the second video port).
Mar 05, 2014 | HP 1502 LCD Monitor
Lg flatron 192ws ....... when i power on the display, it shows the display for 2-3 seconds and then goes off, and the power led still remain lid. i press the power button to turn off the power led and...
Possible causes of "2 seconds to black" can be
a) bad caps
b) bad ccfls and/or ccfl wiring
c) bad inverter transformer
d) bad ccfl sense circuitry
All are discussed in more detail starting with post #13 and #14 at
http://www.badcaps.net/forum/showthread.php?t=10419
Also look here. https://www.badcaps.net/forum/showthread.php?t=14144
Nov 01, 2017 | LG L192WS LCD Monitor
Screen goes blank when first turned on, have to keep restarting m
If you turn the monitor off then about 1020 sec turn it back on and have a picture for five sec again it sound like the power supply in the monitor. but if that did not solve the problem, the picture board on your monitor is bad, since it goes off after few seconds and the power led or button is on, it means the picture board of your monitor has developed fault and will need to be replace.
I advice you replace the picture board on the screen of your monitor to solve the problem of the blank screen.
Take care.
Jul 24, 2010 | Dell E153FP 15" LCD Monitor
Screen goes blank after a few seconds
Hi ,
The monitor flicker problem. The monitor when turn on will display image for couple of second then turn black. The monitor status led is still green. This will happen each time it is turn on. The symptom at appear to come from the inverter board.
May 08, 2009 | NEC-Mitsubishi NEC Display Solutions...
When i turn my CRT on, after a few seconds my screen goes blank, then displays again, while this thing is happening, i can hear something switching... power led is on(green)... even when the display goes...
It sounds to me that the monitors power supply is dying. I would replace it with a different monitor as soon as possible. I would consider this a dangerous situation, and a possible fire hazard.
Thanks for using FixYa,
Hope this helps,
Eric
Dec 11, 2008 | ZT Group CISNET A7050 PC Desktop
Benq FP71G+ 17" LCD with Power Recycle (shutdown & return).
Seems either aproblem with Invertor board or Front panel switches are leaky.
Samir
Aug 17, 2008 | BenQ FP71G 17" LCD Monitor
IC POWER CM2017 LCD MONITOR
Normally when this type of problem happens, the first suspect would be the inverter board, then the filter capacitors and lastly the mainboard.
A defect in one of the lamps and faulty inverter IC may cause the display to shutdown as well. If the lamp is defective, it will send a feedback and cause it to stop producing output signal thus the display just shut off once you switch in ON.
Jun 24, 2008 | Gateway FPD2275W LCD Monitor
Fujitsu Siemens Business Line 431V FA 17" LCD Monitor Logo
250 people viewed this question
Top Fujitsu Computers & Internet Experts
Alun Cox
Computer Links
Are you a Fujitsu Computer and Internet Expert? Answer questions, earn points and help others
