Question about Dell W2600 26 in. LCD Television
Dell w2600 I have been working on my w2600 for a while. The power supply isn't the problem. It works fine when you disconnect it from the T.V. Something is "shorting" it out when it's connected back to the T.V. I've heard to take out the "standby" pen and it will work. Mine is in the repair shop right now and I told them to try that but I haven't heard back so that tells me that they have tried it and it didn't work or they are tired of messin with it. I'm thinking it's the latter.
    Genius:
  • Dell Master
  • 1,689 Answers
Do you have a way to load test the power supply to know that when it is under load it is okay? Testing the supply with boards disconnected is not a good way to know if it can take the normal load.
The way to service these sets is with board substitution. I doubt that DELL will sell the boards to non authorized service people. As for servicing the boards at component level, this is a very strong challange and this type of service is not supported.
Jerry G.
Posted on May 15, 2008
Dell tv model w2600 - sometimes th tv will not turn on. However if i unplug the electric plug and then replug it, the tv will eventually turn on again. I have been told the power supply could be the...
Your power supply board is dead, u know basic electronics' and soldering? Most of the times, the power supply board just have dead leakages gases capacitors.These capacitors always bulges up on it top,or puff up on it top.Replaced these gases leakages capacitors will get your TV power stable,and work again.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Hope this help in solving the problem. Take care....
Oct 01, 2010 | Dell W2600 26 in. LCD Television
Dell W2600 TV
Hi have a nice day!
It is probably a power supply problem. Remove cover and check for a line fuse blown or any burnt component mainly at power supply area.
write a new comment
Mar 10, 2008 | Dell W2600 26 in. LCD Television
No power
i have the answer to the power supply problem on the dell w2600 lcd tv email me at wmattern@aol.com att: dell tv no power
Feb 13, 2010 | Dell W2600 26 in. LCD Television
DELL W2600 26" LCD with audio but no video
The problem will more likely be bad backlight inverter board, or it is not getting the 24vdc from the power supply. Check out the DC voltage output of the power supply for 5v, 12, and 24v first.
Parts: http://www.shopjimmy.com/catalogsearch/result/index/?q=Dell+W2600+&stock=all&limit=200
Jan 05, 2010 | Dell W2600 26 in. LCD Television
Dell W2600 TV. Picture goes black after being on for 10 min.
http://www.shopjimmy.com/catalogsearch/result/?q=W2600
Back lights invereter or power supply. look for 24vdc on the power supply which is needed for the inveeter board.
look for bad caps in the power supply.
Nov 24, 2009 | Dell W2600 26 in. LCD Television
I CANNOT POWER ON MY DELL 2600 TV
Unplug set and remove back, be aware that the power supply employes high voltages.
Remove power supply and remove heat sink, under the heatsink on the main board you will find four small boards mounted upright on the main power supply board, replace all electrolytic caps, put it all back together and Presto!!! it should work.
Sep 22, 2009 | Dell W2600 26 in. LCD Television
The problem is when you switch it off, especially using the button it will not come back on. You have to leave it disconnected from the mains for at least an hour, sometimes overnight.
Replace all electrolytic caps on small upright boads on the power supply board.
Be aware of high voltages on power supply leave set unpluged for at least one hour befor working on the power supply to let the main electrolytics discharge.
Ken
Sep 21, 2009 | Dell W2600 26 in. LCD Television
W2600 no picture but sound
There is a porblem at the video card of this TV pls check the voltage from the power supply to this board
If then votage is there then an I C if overheating or licking ie the processor add a fan to cool this chip .
its going to work
good luck
Sep 08, 2009 | Dell W2600 26 in. LCD Television
Dell W2600
The video drive board may have failed, or the output section of the power supply that drives the video drive board may have failed.
It is also possible and is common on LCD sets, that the backplane lamp supply, and or the backplane lamps have failed.
Turn on the LCD TV set, and shine a flashlight in to the screen at an offset angle. If you can see a bit of the image, you know that everything is working, and it is a backplane illumination problem.
Jerry G.
Apr 09, 2008 | Dell W2600 26 in. LCD Television
Dell w2600
There is no fix for the W2600. It has a power supply problem.
For sometime Dell was replacing the tv's with new ones, but don't think they are anymore. If you go to the Dell Forum and type in your tv you will see the amount of people that have had the same problem. Unbelieveable. As a matter of fact, Dell is not even making TV's anymore. Guess they gave up. They cannot be fix, cannot get the parts for it.
Mar 20, 2008 | Dell W2600 26 in. LCD Television
Dell W2600 26 in. LCD Television Logo
128 people viewed this question
Top Dell Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
CoppellTVRepair.com
Are you a Dell Televison and Video Expert? Answer questions, earn points and help others
