Question about Watches
I need some braclet links for citizen bm 6552-52e where can i obtain them
3 Suggested Answers
escapement
  • 2334 Answers
SOURCE: need to resize watch braclet on a mens invicta watch
You may or may not have arrows inside bracelet. Arrows are pointing the way the pins must come out.
First you have to find out what sort of pins or even screws are used to keep links together.
Examine both bracelet sides and find the side where pin ends have a groove.
Start with a tiny screwdriver and unscrew one of the screws. If it turns, but doesn't come out, that means you have a pins instead.
For removing pins the best would be pin removing tool (approx.5GBP on ebay), but it's possible to do the job without it.
Take a hardened steel needle and blunt the sharp end to the approx. size of pin end diameter using any sharpening stone or sandpaper. Get an old towel and fold it to make a soft base for work (like small cusion). As you don't have a special bracelet holder you will need a pair of helping hands to hold the bracelet steady upright. You will need small hammer and pair of flat nose pliers as well.
NOTE: The pins MUST be driven split end out first, not vice versa. Make sure that the grooved pin ends are facing towel, not the needle and hammer!!!
Now place the watch on the folded towel, take that needle and smallest hammer you have and start driving the pin out using light blows. Do Not hit hard, as you will brake the needle, scratch your watch or even injure yourself. Watchmakers are using 45 gram hammer, so, calculate your strength of blows.
After a few blows check if the split end is coming out and when you see that the end is long enough to grab it with pliers, pull the pin out with pliers. When pulling, do NOT turn pliers, as pins tend to brake when twisted. Use firm grip and your strength to pull the pin without twisting.
After shortening the bracelet or adding extra link(s) make sure that the pins go back EXACTLY the same way as they came out- the blunt end first in the hole and the split (grooved) end last. Before doing that check remaining pins in bracelet to make sure that you put them back from the right side of bracelet.
It is recommended to use plastic hammer to drive pins back in or you will scratch or damage bracelet. If plastic hammer is not available use an old toothbrush handle (or some plastic item) as an absorber. Simply put pin into the hole as deep as you can with your fingers, put the toothbrush handle on split pin end and hit handle, not the pin.
Make sure that pin ends are flush with bracelet. If needed- hit few more times.
Job done!
If you do not want to do it yourself, any jeweler will do it in a matter of few minutes.
Don't forget to rate, please.
Posted on Apr 02, 2009
gemineye61
  • 831 Answers
SOURCE: im in need of two links for the slimline watch
Thank you for contacting FixYa.
You can usually get extra links from JJ/Helbros but for some reason I can not get their website. I would look for a phone # in the manual and call them. They will want the #'s on back of watch.
Best regards. Jewel
Posted on Sep 21, 2010
Hello i bought citizen jy0010-50e , the analog and the digital not matching up. when the digital on 12:00 the big pointer stand on 12, but the small pointer run to fast and standing min after .
it sound like you have motherboard problem, or mechanical problem - unfortunately neither of this can be solved at home, in most countries citizen offers 5year warranty on these time pieces, usually warranty is handled by the seller.
call your seller, obtain ra and then send it back...
Apr 05, 2015 | Citizen Watches
Remove links from braclet
does this expand? or links.if its pins they need to be punched out, look inside there should be arrow.
Mar 23, 2012 | Dunhill Millenium DC2601M Wrist Watch
I am desperate to find an owner's / instruction manual for the Promaster SST Citizen Eco Drive watch.Please TELL ME A PHONE NUMBER I CAN USE TO OBTAIN THIS.
To determine the exact model and specifications of your Citizen Eco-Drive, flip the watch to the reverse. On the case back will be extensive information about your timepiece. You're looking for the "movement caliber," a four-character combination of letters and numbers, separated from the seven-digit "case number" by a hyphen.
Next step, visit this links:
- citizenwatches.com.au/instruction-manuals
- citizenwatch.com/COA/English/settings.asp
Hope this helps (remember to rate this answer).
Apr 14, 2011 | Citizen Eco-Drive watch
I recently received a Citizen Blue Angel Skyhawk Watch from my brother's estate. Is there a download for the manuel? Or anyway to obtain one?
You can get instructions from the Citizen web site.
Go to "citizen.com" and on the upper right there is a menu. Click on "technical
support" and then on "setting instructions"
Fill in the information required from the back of your watch and then click on
"get setting instructions"
or
Go to "citizen.com" and click on "watch finder".
Put your watch model into the search box on the left and click on
"search".
Click on the watch to view details.
On the right is a small menu, click on "get technical info"
On the right you you will see a list of instructions you can download.
Feb 02, 2011 | Citizen Blue Angels Skyhawk Watch
Im in need of two links for the slimline watch braclet
Best regards. Jewel
Sep 21, 2010 | Jules Jurgensen 5000YG Watch
Extra links for tag heuer 2000 stainless steel and gold braclet
Links need to be ordered from TAG.They cost about £30.00 per link best contact www.rolexrepairs.co.uk if you send them the watch they will supply and fit with a free estimate first.
Regards
Aug 10, 2010 | Tag Heuer AquaracerWAF1110.BA0800 watch
Braclet has come off watch.
It is difficult to be sure what the problem is without examining the watch but it sound as if the pin spring (which which makes it telescopic) has broken.
It should be possible to get arepalcement from you local watch shop, they usually have a range standard items to fit most watches.
Jun 30, 2010 | Rolex Submariner 16618 Wristwatch
Howdi i set time on citizenwr 300
I assume that you haven't go your instructions.
To obtain a copy, go the "citizen.com", click on "technical support" and then on "setting instructions".
Follow the instructions on that page to get your instructions.
Jan 23, 2010 | Citizen Watches
Do you by any chance have the instructions for the citizen wr100
"wr100" stands for water resistant to 100m and is therefore not the model of the watch.
To obtain instructions go to the Citizen web site "citizen.com"
Choose your area from the menu.
On the right you will see options, choose "technical support"
Select "setting instructions"
You will then be asked to enter the calibre number ( see instructions just above the box for information on where to find the number).
You should now be able to read the instructions.
Jan 07, 2010 | Watches
The black coating on braclet is coming off after 6 months
Citizen's has a no question return policy I hand the silver 3o'clock position marker knocked loose and the replaced my watch with no problem. Just take it back to the store you got it from if you dont have the receipt the usually can look it up i had mine for over a year and it wasn't a problem
Aug 12, 2009 | Citizen Skyhawk Eco-Drive JR306059F Wrist...
Watches Logo
Top Watches Experts
Ansel Alberto
Ansel Alberto
Marvin
Marvin
Are you a Watch Expert? Answer questions, earn points and help others
