Televison & Video Logo
Posted on Jul 17, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Cant get dtv to work on panasonic - Panasonic Televison & Video
Anonymous
Level 2:
New Friend:
  • Expert 177 Answers
  • Posted on Jul 17, 2010
Anonymous
Expert
Level 2:
New Friend:
Answers
177
Questions
0
Helped
50319
Points
494
Do you live where DTV is available? Does the TV support DTV? Are your signal levels adequate? Have you switched the set to its DTV setting? Have you run an autoscan?
How to reset mintek dtv-265-d telivision after replacing power supply
MINTEK DTV-373-D OWNER'S MANUAL Pdf Download.
www.manualslib.com > ... > TV DVD Combo > DTV-373-D
View and Download Mintek DTV-373-D owner's manual online. Mintek DTV-373-D OWNER'S MANUAL 37''. DTV-373-D TV DVD Combo pdf manual download.
Mintek DTV-265-D 26 in. LCD TV Factory reset - Questions ...
www.fixya.com > ... > Mintek > Mintek DTV-265-D 26 in. LCD TV
...factory reset to this TV. It will make all to factory settings. There are two types ofreset to TVs. The first is simple to do; a Hard Reset. The other is somewhat ...
Mintek reset button location Combination Televisions ... - Fixya
The sound on my Panasonic TXPG20, 50" is poor, how
THE SPEAKERS IN MOST FP DTV'S ARE QUITE ORDINARY. BUY A 5.1 SYSTEM FOR IT. IF U GET A PANASONIC UNIT, THEY AUTO CONNECT VIA PANASONIC'S LINKING SYSTEM. EVEN THE SMALL SYSTEMS PRIMARILY AIMED AT COMPUTERS TO ENHACE SOUND WILL WORK BUT THE BIGGER TOWER TYPE SYSTEMS WITH WIRELESS REAR SPEAKERS AND DECENT SIZE SUBS WORK REALLY WELL. I HAVE AN LG 50" DTV AND LG BLUE RAY HOME THEATRE SYSTEM HOOKED UP TO IT. IT IS 1100 WATTS AND GIVES YOUR MOVIES VERY SERIOUS SURROUND SOUND.
1helpful
I cant get a singal for my antnna
Tv does work for HD but must have cable or satellite tv signal.Yes,this tv able to play HD signal,but it is a CRT-(tube tv) design was built before the DTV switch over and never added the DTV tuner in it board circuitries.Sorry antena free DTV this tv must have to added the converter box to get the DTV free air signal.
4helpful
SAMASUNG 32 INCH TV FROZEN ON DTV CHANNEL 1 CHANNEL WORK WHEN YOU CHANGE TO TV CHANNELS 1 - 5 BUT DOES NOT WORK ON DTV CANT CHANGE JUST FROZEN ON CHANNEL 1
These are the steps to reset the DTV features and unfreeze your TV:
  1. Ensure the tv is in analogue mode, not dtv and turn it off.
  2. With the remote: press info, then menu, then mute, then power. These buttons need to be pressed sequentially, not all at the same time, and in quick succession. A menu will appear on the tv.
  3. Navigate to the reset option and press the left arrow key on the remote (or press the enter/ok button). The tv will reset itself and turn off.
  4. Turn the tv back on & it'll re tune all its channels. DTV should be working again.
I hope that helps.
Does a CT-27614A need a digital converter for antenna?
According to http://www.dtv.gov/consumercorner.html#faq9
I hope this soultion is helpful.
How can I be sure that I am buying a digital TV (DTV)?
By law, beginning March 1, 2007, all television reception devices (including TVs, VCRs, DVRs, etc.) imported into the U.S. or shipped in interstate commerce must contain a digital tuner. Retailers may continue to sell analog-only devices from existing inventory, but must prominently display on or near the analog-only device a Consumer Alert label with this advisory:
What is the difference between “Integrated” DTVs and DTV or HDTV “Monitors”?
An Integrated DTV set is a television with a built-in digital tuner (also referred to as “a DTV”). A digital tuner is also sometimes called a DTV decoder or DTV receiver. If you have an Integrated DTV, you will not need any additional equipment, with the exception of a broadcast antenna (either a rooftop antenna or “rabbit ears” connected to the set), to receive over-the-air digital broadcast programming. Integrated DTVs can also receive and display analog broadcast programming, so you can continue watching analog broadcasts.
In contrast, a DTV Monitor is not capable of receiving digital broadcast programming without additional equipment; it is simply a display device without the processing capability for DTV reception. A digital or HD set-top box must be connected between the antenna and the monitor to receive and display over-the-air digital or HD programming.
If you have a digital or HD “Monitor” and would like to purchase a digital or HD set-top box to view over-the-air programming, confirm with your retailer that the set-top box is compatible with your Monitor.
Not DTV ready?
it meens the tv set is in dtv and the dtv conection is not set up.
hd tv is a red blue a green cable.
and the antena conection needs to come from a converter box if signal is coming from antena if from sat or cable you should have a hd box that feeds your set.
hope this helps.
daniel.
New Rca DTV converter / panasonic tv trying to get remote to work
You must set the code to conect your tv to your remote. The instructions are in your manual with a list of codes.
Panasonic & directv cable
firstable we need to know what kind model your talking about in both dtv model and remote control model......saludos
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Grand Canyon Tech
Grand Canyon Tech
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
