Question about Maytag Neptune MAH5500B Front Load Washer
Pink mold in outer rubber ring and mold extends to door.
  • Maytag Master
  • 43,501 Answers
Here is a tip that I wrote about cleaning your washing machine...
How to have a Clean Washer
http://www.fixya.com/support/r4356970-clean_washer
Make sure to leave the door open when the machine is not in use to let it dry out...
heatman101
Posted on Jul 17, 2010
1999 buick century weatherstripping failed
You can add flexible tubing inside of the rubber molding on the door this will help with the seal
Mar 01, 2014 | VPI Buick roadmaster weatherstrip. rear...
How do I get all the stains and crud/mold off the front side of the whole tup enclosure.?? The grey rubber outer ring ??
Try soda crystal solution and elbow grease or a sterilizing tablet( type u use for cleaning false teeth) on hottest wash your machine has do this regulaly as black marks are bacteria left after cool washes . If all this fails u will need to replace rim I hope this helps
Oct 29, 2012 | Bosch Nexxt 100 Series WFMC1001UC Front...
Was cleaning rubber gasket for mold and noticed when I cleaned inside outer lip of steel drum a lot of brown sludge-is this grease for drum or is this build-up of some sort that should be cleaned? Also-do...
The brown sludge you are finding should NOT be grease as the bearings for the drum are sealed. This may be soap scum build up, and a combination of mold or mildew if you have been leaving the door shut between washes. It is strongly recommended by the manufacturer that you leave the door open when not in use to allow the drum air out. This aids in preventing mold, mildew and odors. The following link explains some of the common causes of front loader odors and how to remedy the problem:
http://www.fixya.com/support/r3608512-getting_rid_front_loader_mildew_odor
As far as the water fill hoses are concerned, the hoses are usually good for about 5-10 years (rubber), 10-15 years (stainless steel). They usually only require replacement if the rubber begins to crack or dry rot and/or begin leaking. A general inspection of the entire length of hose, cleaning the sediment screens in the ends of the hoses (if equipped) and replacing the gasket at the fitting will extend the life of the hoses. Replacing the hose has nothing to do with preventing odors. Odors are generally caused by not leaving the tub open to air out, using too much (or improper) detergent which causes soap scum build up, or a clogged drain trap. The following link explains how to access and clean out the drain trap:
http://www.fixya.com/support/r3574284-checking_the_drain_pump_on_a_front_loade
I personally own a washer similar to yours and have never had any problems with mold, mildew, or odors, by following this regiment. If you have any questions or concerns, please post back and let me know. I hope you find this information helpful.
Oct 28, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Clothes stained and mold growing on rubber ring inside, constant odor despite using monthly washer clean tablets, leaving door open and draining water out of washer
Use a mixture of bleach and water in a spray bottle to kill the mold. Leave door open after washing. Also spray your drum and rinse unloaded to kill the mold on the inner drum.
Jan 06, 2010 | LG WM2016C
There is mold on the underside of the door ring. Am unable to remove ring in order to clean it. Washer thus has a musty smell. How do I clean this?
It cannot be cleaned - it must be replaced.
The rubber absorbs the mold - and you cannot get rid of the smell.
This part is called a door bellow.
It will require disassembly of the machine to replace - and a professional service contractor is recommended.
Thanks for using Fixya - a 4 THUMBS rating is appreciated for answering your FREE question.
Dec 30, 2009 | LG Washing Machines
Water sitting and mold growing in the rubber gasket ring around the opening for the door
Front loaders are known for building up mold and the smell.
It’s caused by using liquid detergent which is made from animal fat. Use powder. And use the minimum amount.
It’s caused by using fabric softener. Dilute it 50/50 with water.
It’s caused by the water remaining in the tub between washes. Leave the door open to allow it to dry. .
Pull the rubber door seal back and clean the mold off .
affresh is recommended by some manufacturers. You run it through a wash cycle with it.
Oct 09, 2009 | LG WM-2277HW Front Load Washer
Mold in rubber ring front loader Fridgidare washer
Common problem. Clean the moulding as best you can, even scour with steel wool. Leave the door open so the machine will be dry when not in use or/and wipe the rubber after each use. You can try to cover up the odour by wiping with a rag moistened with vanilla essence. Otherwise fit a new rubber and keep it dry in future.
Jul 03, 2009 | Maytag Neptune MAH5500B Front Load Washer
Mold build up around ribber gasket . Heavy, black and hard
Front load washers are notorious for developing mold/mildew to build up because they retain a lot of moisture in the round gasket the door closes into. Wash it down with a 50:50 soulution of bleach and water. You may have to use a brush on the "hard" stuff. Occasionally, run a quick load with no clothes and just bleach through a complete cycle in the washer. After a heavy day's washinh, leave the door open a little to help dry it ou.
May 28, 2009 | Washing Machines
Maytag Neptune MAH5500B Front Load Washer Logo
156 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
