Question about Western Digital Passport WDXML800UE (WDXML800UETE) 80 GB Hard Drive
I backed up data w/ WD Passport External Hard Drive, and when finished my computer's free hard drive space went from 115 gigs to 11. What happened, and how can I fix this?
    Scholar:
  • 39 Answers
What could have happened is that you backed up your drive onto itself. Check your external and see if it's still empty. If you named the backup, search for that name and remove it. If not, retrace your steps right until the beginning of the backup and see what location the software stores the file then remove it.
Worst case scenario you can always use the windows restore utility and go back 1 day before you ran the backup.
Good Luck
Posted on Jul 17, 2010
Its making a really sick grinding or static sound and it will not connect to my laptop no more i have 300 gigs of music on it am i screwed
The hard drive is about to die. only thing to do is to try and down to a new drive . Any important data should be backed up to another drive . and you won't have this problem. There are data recovery people that may be able to help, but get a quote as it cost a lot of money.
Mar 28, 2015 | Western Digital Wd 500gb My Passport Elite...
My passport is originally 250 GB but now it says that it's only 94 MB. I don't know what happened.
is that a free space and used space graphic? or does the entire disk(use start my computer right click on hard drive and see what total amount of space says)
if you have been using this for a while, that would explain the lower figure but this graphic will clearly show the balance on that drive
here's a link for a free disk optimizer that might help too
May 19, 2012 | Western Digital WD Passport 250GB Portable...
I just bought a WD My Passport 1 TB. I had my computer shop back up some files from an old hard drive. When I attached it to my CP for the first time everything was there. I clicked on the smartware and...
The first thing to do is determine the condition of your 1TB drive. You can check if there are problems with the drive using the free trial version of http://www.hdtune.com/
If it checks out ok then you can try to recover your data with Recuva it's free http://www.piriform.com/recuva
Or if you need data recovery help this a good choice for low cost and fast data recovery. All data recovery work is performed remotely over the Internet from a boot cd that you download and the best part is they just ask for donations if you are happy with the results: http://FreeDataRecovery.us
Aug 09, 2011 | Western Digital 1TB My Passport Essential...
I can't access my wd external hard disk (passport )through (my computer) i can see it using windows disk management as unallocated partition...when right clicking..no options are active but properties
Hello
Have you tried accessing the hard drive on another computer?
Have you tried using a different USB cable?
Was the hard drive dropped or moved while it was plugged in?
Check the WD Site if you hard drive has warranty.
I hope this solves your problem and please reply if you need more help.
May 11, 2011 | Western Digital Passport WDXML800UE...
Why a wd elements 320gb external hard drive only registers 298 gb when connected to computer?
Because the remaining space is for the file allocation tables. That tells the computer where to look on the hard drive to find the files. It's like an index for the hard drive.
Feb 12, 2011 | Western Digital WD Passport 250GB Portable...
All my files say they are shortcuts that cant be opened and cant be found, the location given is toiofix.exe (E:) and the wd passport itself is on drive (F:) .. The WD passport itself , i am told by the...
This blog article is exactly what you need to read in order to fix it. As your external wd drive probably infected with virus. Note: to start with, do not format the drive immediately. Regards
Oct 14, 2010 | Western Digital Passport WDXML800UE...
How do I completely reset my external hard drive
1. You need to check how much free disk space is available on your laptop.
2. You need to check what duplicated files you have on both the laptop and the external hard drive and which is the latest version.
3. You need to decide to move the latest versions of the data files from the external hard drive to the laptop. This automatically delete these from the external hard drive. The older versions on the external hard drive can be deleted.
4. Now you need to check how much data is stored on your external hard drive.
5. If the amount of data stored on the external hard drive exceeds the available disk space on the laptop, then you cannot copy these files to the laptop.
6. If you have sufficient disk space on the laptop you can copy the data from the external hard drive to the laptop. I suggest you make a folder to copy this data to it.
You can now delete all the data from the external hard drive or you can format the external hard drive to make a clean external hard drive.
Oct 01, 2009 | Western Digital WD Passport 250GB Portable...
Can't retrieve data
Be sure to use the WD supplied USB cable to connect the drive. I had a similar problem with my WD Passport 320 and was told that using a cable other than that short 8 inch cable can cause some odd operations.
Sep 30, 2009 | Western Digital WD Passport 250GB Portable...
External Hard Drive will not show up. Tells me to format it.
I have a Western External Hard Drive 320 and when I plug it in the computer will recognize it and allow me to access my files but after a short while if I go to click on a file t open it the WD 320 will click off for a minute and then reappear in the auto run mode.
Jun 20, 2009 | Western Digital Passport 320GB External...
External hard drive disk space
Hi
Is it showing the 300gig in the properties? if yes then try to copy with command mode,If again its given problem then u need to backup your data and format the drive, then try copying.I think it will work.
T.Boopathy
Aug 17, 2008 | Western Digital My Book Essential Edition...
Western Digital Passport WDXML800UE (WDXML800UETE) 80 GB Hard Drive Logo
132 people viewed this question
Top Western Digital Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Marvin
Marvin
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
