Question about Cell Phones
My blue tooth isn't working
I purchased a sony w300i recently and can't get the bluetooth to pair with other phones and it will not find any other devices... really weird but can you guys help out....
  • 563 Answers
Hi rob-b
First check if your bluetooth is swithed on.
If this still doesn't work after switching the bluetooth on , then reset the phone and try again.
Hope this is of help.
Posted on Apr 22, 2008
    Genius:
  • 1,447 Answers
HI- what device are you trying to set it to? did you set Bluetooth setting as dicoverable or hidden?
  • Edgar Allan Pagayona
    Edgar Allan Pagayona Apr 22, 2008
    For headset pairing
    How to pair the phone with a Bluetooth™ headset
    The phone identifies and maintains up to 16 devices which are displayed
    in a list. To add a new device or pair a headset via bluetooth, turn
    Bluetooth™ on in both devices.
    1. Put headset in pairing mode. See Headset User Guide for more information, if needed.
    2. Turn on Bluetooth in your phone, Go to menu, [SETTINGS] > [CONNECTIVITY] > [BLUETOOTH] and press "Select"
    3. Choose [TURN ON] , press "Select"
    4. Choose [MY DEVICES], press "Select"
    5. Choose [NEW DEVICE], press "Select"
    6. Choose the headset to be paired and press ' Select '
    7. Enter the pass key '0000', press "Ok"
    Link for headset setting, just choose the headset model
    http://www.sonyericsson.com/cws/support/...
    If you are using a different device the just set the Bluetooth to on on it as well
  • Cell Phones Master
  • 19,396 Answers
Remove all pairings and irt should work again
  • Ginko
    Ginko Apr 22, 2008
    Before proceeding remove and put back phone battery, so to reset the phone.
    Sometimes an installed pairing can cause troubles to the system, if you have paired devices remove first all pairing, and then do again pairing, usually this work.
    If the above did not work, then either you are not doing pairing procedure properly, or there is a problem with the paired device, or with your phone firmware, in this last case reinstall firmware.
Code for sony dr-bt100cx bluetooth
Hi, when you want to connect a blue tooth to a phone, You will need to switch on the blue tooth device and the phones blue tooth you are pairing with.
When pairing both device, you will ask for pairing code, You four digit numbers(default code(0000). and pair.
After pairing both device, you detected paired, you can now use the blue tooth device with your phone.
there are no special code for pairing Blue tooth device.
Normal codes used are any four digit, four numbers you want to use.(0000, 1234).
Hope that helps...
Thanks for using fixya.
Nov 25, 2010 | Sony DRBT100CX Bluetooth Headset
How to connect jawbone bluetooth device to htc evo 4g
HOW TO CONNECT BLUETOOTH
It all depends. When you want to connect a blue tooth to a phone, You will need to switch on the blue tooth device and the phones blue tooth you are pairing with.
Take care.
Oct 02, 2010 | HTC EVO 4G Smartphone
I go to the bluetooth menu and turn it on. it says "Bluetooth turned on" But the icon fails to appear and file transfer fails.
HOW TOCONNECT BLUETOOTH
Take care.
Aug 16, 2010 | Sony Ericsson K550i Cellular Phone
How to put a hbh705 into pairing mode
Take care.
Aug 06, 2010 | Sony Bluetooth Headst HBH705 Sandcolor...
Bluetooth not working in sony W580i phone
After attempting on this process, if doesn't work,that means thee blue tooth is corrupted and to restore bluetooth, you will to flash the phone. Flashing the phone will restore back blue tooth.
You can use this links to see how to flash your phone.
hubpages.com/hub/How-to-Flash-your-cell-phone
and
unlocktotalk.com/UnlockCodeInstructions.htm.
Take care.
Take care.
Jul 03, 2010 | Sony Ericsson w580i Cellular Phone
What is the bluetooth passkey code for lg gt505 mobile phone to pair with other devices
Take care.
Jul 02, 2010 | LG GT505 Cell Phone
My bluetooth dosent work in my nokia 6600
But if it doesn't pair after you've tried the above, that means the blue tooth is corrupted and will need to be flashed to restore bluetooth back.
FORMATTING PHONE
Formatting a phone is the same as flashing a phone to remove VIRUS infections on phones.
You can use this link to flash the phone and remove any VIRUS infection on the phone.
Read and learn more about flashing and how to flash a phone on this link.
unlocktotalk.com/UnlockCodeInstructions.htm),
Take care.
Take care.
Jun 30, 2010 | Nokia 6600
Plsits just that my phone's bluetooth refuse to work. It says 'unable to perform bluetooth operation'. Wat can i do to get this prob solved?
first reset the phone and try to connect again.
If it connects,you can use this step to,But if it doesn't connect that means the blue tooth is corrupted and will need to be flash to restore back blue tooth.
(You will have to flash the phone to restore the memory of the phone.
You can use this link to see how to flash your phone.
(hubpages.com/hub/How-to-Flash-your-cell-phone)
and
(unlocktotalk.com/UnlockCodeInstructions.htm.)
HOW TO CONNECT BLUE TOOTH,
Take care.
Jun 28, 2010 | Nokia N73 Cellular Phone
Problem in transfering file via bluetooth
Take care.
Jun 17, 2010 | Sony Ericsson K750
Sending phone book from sony ericsson w580i to bluetooth mirror
Not 100% on this, but your Sony may only work with Sony bluetooth for this. I know they do such things to promote their sales. Since the actual Bluetooth communications protocol is the same for all phones, you'll be able to pair, but you may not be able to transfer your contacts.
Nov 13, 2008 | Sony Ericsson w580i Cellular Phone
Cell Phones Logo
47 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
