Question about Troy Bilt 25HP VTwin Hydrostatic 50" Zero Turn Radius Mower
How do you replace the belt on a Troy Bilt Mustang RZT? I need to know how to loosen the tension so I can get the belt on.
  • 12 Answers
SOURCE: NEED A DIAGRAM OF HOW TO ROUTE A BELT ON A TROY
type in your model number to your search engine. find your model and the diagrams will be there.
hope this helps.
Posted on Aug 13, 2010
SOURCE: belts slippin on troy bilt horse
Have you adjusted the locking cam for forward. This cam is held in place with one bolt. The further you move it down the tighter it will make the belt
Posted on May 05, 2009
  • 81 Answers
SOURCE: How to replace air filter on Troy-bilt TB20CS?
May be air filter but sounds more like your muffler is stopped up. First take the muffler off and see if it runs better without it. If so, burn the carbon out of the muffler and clean the muffler port on the engine. If not, then remove the four screw at the very end and disassemble. The ait filter is in that area. Diagram is located at
www.stollerlawnandgarden.com/.
Click on parts lookup in left hand column.
Posted on Jun 24, 2009
vincob
  • 718 Answers
SOURCE: how to replace drive belt on troy bilt lawn
Go to this website, upper right hand corner and do a parts look up. Search for your model and that good stuff they ask of you and then choose mower housing should be there, browse the site it's really cool and has a lot of info.
http://www.jackssmallengines.com
I did a sample search for generic riding mower deck and found great diagram of belt routing. Give it a try you will find same results Good Luck! Don't forget the thumbs!
Posted on Sep 18, 2010
  • 13 Answers
SOURCE: Need help on replacing drive/transmission
I believe their is a plate between the seat and steering wheel. Unscrew the plate and you will see drive pullies, push in and lock brake, this should supply enough slack for you to reach under the seat remove old belt and install new. It is a real pain.If brake can not be locked you need someone to press it while you do the work. Removing the deck will really not help because you will not be able to reach transmission pulley under seat.
Posted on Feb 24, 2011
How do I replace the drive belt on a 2008 50" troy bilt zero turn mower
You didn't include a model number so here is a link to Troy Bilt where you can download the user manual.
At top right click on owner center and follow directions.
Mustang 50 XP Zero Turn Riding Lawn Mower
Sep 11, 2014 | Garden
Troy Bilt Mustang XP mower belt diagram
https://www.partstree.com/parts/troy-bilt/mowers-zero-turn-lawn-mower/17wfcacp011-troy-bilt-50-mustang-xp-zero-turn-mower-2013/mower-deck/
Aug 27, 2014 | Troy Garden
How to turn park break on. I have a troybilt rzt mustang
If it is the same model I just purchased, to engage the parking break you simply push both handles out to the side. That's the only way I know to engage it.
Jun 15, 2014 | Troy Bilt 25HP VTwin Hydrostatic 50" Zero...
Mower: Troy Bilt 42 Mustang Zero-turn mower: The
Hello Donna,
I would remove the battery and have it tested at a local parts store. It sounds like the battery to me.
Sep 08, 2013 | Mustang Rzt 50" Zero Turn Riding Lawn...
How much oil goes in my Troy Bilt Mustang RZT 50"
at least one quart up to 2 quarts
May 23, 2012 | Garden
On the Troy-bilt RZT 50, the drive belt keepers were factory welded to the deck at the engine pulley. How do I remove the keepers and get the belt over the pulley?
have you considered removing the pulley from the top of the mandrel? might be easier to put the belt on by taking off a nut than breaking welds and rewelding when you are done. i do not have a lot of respect for troy bilt, but even they know belts have to be replaced at least once in the life of a product so there must be some less drastic way. have you troubled yourself to take a look under "support" over on the troy-bilt website?
Sep 10, 2011 | Garden
Why is my troy-bilt mustang 50 zero turn lawn tractor is smoking and burning oil?
it could need a oil change if it as some age to it could need a new ring set or a new overhaul and it my need a new plug ...
Aug 04, 2010 | Mustang Rzt 50" Zero Turn Riding Lawn...
Troy Bilt 25HP VTwin Hydrostatic 50" Zero Turn Radius Mower Logo
550 people viewed this question
Top Troy Garden Experts
Matt Olenzek
Matt Olenzek
DROPNDEAL
DROPNDEAL
Wade Mobley
Wade Mobley
Are you a Troy Garden Expert? Answer questions, earn points and help others
