Question about Goodman GMS1155CNA Heater
Control fuse blowing
My Goodman Furnace GMS8 control board fuse is blowing in Cool position
  • 70 Answers
Check for a short on the control wiring.
Posted on Jul 18, 2010
Lennox lb50527cc
high limit switch, no proof of flame.
Oct 27, 2013 | Goodman Heating & Cooling
I have a GMS8 furnace and it will not kick on.. No heat coming out of heater vents..
Is inducer motor running. If not change it. If it is then remove vacuum line from it and blow through the line on start up. If this works change the pressure switch. If not start jumping the sensors around the burner until you find the bad one
Jan 23, 2013 | Goodman GMS90703BXA Heater
1993 Goodman gas furnace keeps blowing fuse when first turned on
You can take each thermostat wire off the control board and use a ohm meter and test to ground, should not have any resistance. Another way is turn off power take each wire off the board, then place one wire at back on the control board terminals ome at a time, untill the one you get to the one that blows the fuse. If the wires check out good sometimes the thermostat itself can have a internal short and cause the fuse to blow.
Nov 27, 2012 | Heating & Cooling
Inside Fan comes on but when you switch the thermostat to the on position it blows the circut board 3 and 5 amp fuses. All wiring was checked and eveything is wired correctly
Try disconnecting all control wiring at the furnace to the thermostat, then jump "R" terminal to "G" terminal, the fan should come on, then jump "R" to "W" the heater should come on, if the fuse holds after testing the problem is either with the control wiring to the outdoor control wiring or the thermostat and or thermostat wiring.
Sep 17, 2011 | Goodman CKL36AR36 Air Conditioner
Fuse blow each time I turn on air check for
disconnect the thernostat wires from the control board. Put a jumper wire between R & G put door back on and turn on power. Blower motor
should run, if it blows the fuse then you have a direct short between R &
G at the board. Do this with R and W(heat) and R & Y(cool).
By disconnecting the thermostat wires and reinserting them make sure that they do not touch when inserted into each terminal. If it still blows
that little 3amp fuse when jumpering between each sequence as mentioned above, then I think your board is bad. When Jumpering out the Y terminal you will have to have the AC wires still hooked up. If it
blows the fuse in that sequence. Disconnect the wires out at the condensor.
You mat have a bad contactor at the outdoor unit.
Jul 16, 2010 | Goodman GMS90703BXA Heater
Need an gms8, control module .goodman furnace
Go to www.americanhvacparts.com or www.furnaceparts.com On the first site type model number of unit upper right corner and pictures of parts will show on screen. Rus
Mar 14, 2010 | Goodman GMS80904BNA Open Flame Mid-Size...
Can I change airflow direction with Goodman GMS8?
I would probably use a furnace for the correct application. However some motors do have a reverse speed connection. Besides the blower speed taps,
capacitor wires and the nuetral wire. There are two wire sets that you can switch that can do this if your blower motor is equipped.
You might experience some airflow problems, probably a lack of airflow, if the furnace was installed
as an upflow model instead of a counterflow.
Feb 17, 2010 | Goodman GMS90703BXA Heater
I HAVE A USED GOODMAN GMS8 FURNACE I HAD INSTALL IN MY HOUSE WITH AIR THE PROBLEM I'M HAVING IS THE BLOWER RUNS ALL THE TIME KNOW WHAT ???? HELP ME PLEASE
Check your themostat. The fan switch may be in the on position and not in the auto. If that is not the problem, try turning the power off to the furnace, wait 1 minute and turn the power on. It may have went into a lock-out which causes the blower to run.
Oct 14, 2009 | Goodman GDS80904BNA Open Flame Heater
I have a goodman furnace and ac unit heat and fan work but soon as i flip the ac on it blows the 5amp fuse at the furnace
their is a control short some place check the control wiring . dog or rodents chewing threw it or shorted controls or thermostat id get service. Tom
Jun 24, 2009 | Goodman CLQ36AR49 Air Conditioner
Replaced Fuse on Board. Unit keeps running
Sounds like crossed or shorted wire going to the thermostat. Disconnect the wire from the thermostat and see if it shuts off. If it does, it is the thermostat. Then disconnect either the white wire or red wire at the control board and see if the furnace shuts off. If it does, its the wiring. If it continues on, it is the control board. Remember you will need to tape the access panel door switch to the on position to be able to run the furnace with the panel off.
Nov 22, 2008 | Goodman GMS90703BXA Heater
Heating & Cooling Logo
166 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
Paul Carew
Tim Whalen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
