Question about Goodman Heating & Cooling
The fan is running, but the conpressor is not kicking in. Godman ck49-1
  • 674 Answers
Check the capacitor first. Some units have 1 capacitor that runs the fan and compressor and it's possible for one side to go bad. If the capacitor looks swollen then it's probably bad. You can check it with a multimeter or take it to a heating and air supply and they can check it for you. This is a very inexpensive part. If the capacitor is good then you will need to check the compressor windings with an ohmmeter. Let me know what you find.
Posted on Jul 17, 2010
The compressor run 5 sec stop for 2 min and keep on like that what can course that the fan run normal and it blow hot air inside room
You have a dirty condenser coil .Wash coil with water and see if that helps .If not you might have a bad compressor
Feb 22, 2018 | Heating & Cooling
Armstrong concept 1200-bad start/run capacitor?
Yes, most likely the start capacitor has failed & should be replaced. You have proven this by being able to hand-start the fan. Once replaced, the compressor should kick in & work fine.
Jul 20, 2012 | Heating & Cooling
My air conpressor went out fixed it but now my cooling fan wont come on and the car is running hot when i run the air
You will need a Ford dealer to look at this, there is no way to knopw what those two wires do without hands on looking.
Jul 03, 2012 | 2002 Ford Mustang
A/c unit vibrates entire rv. could not find any
You may have to remove cover on roof and check condenser fan as well. That will also allow you to observe for possible fan wobble, bad compressor mounts etc. Please shut power off at breaker until you have cover completely off, and be real careful for wasps, and roof may be slippery if wet, or early morning dew on it. Stand back, hands back and have someone turn it on.
Jun 15, 2010 | Dometic Rooftop RV Air Conditioner
Dayton blower fan repeatedly kicks on and off
chech the air filter is clean and the fan limit switch look to change fan limit
Nov 01, 2008 | Dayton Gas Furnace Heater
Volvo v70 air con fault
This is probably a clutch problem on the compressor, either buy a new clutch or get a second hand compressor and swap the clutch over.
Jun 27, 2008 | 1999 Volvo V70
Fridge Maytag model MCD2257KES. The fridge is getting power because the light comes on when the door is open. It for some reason lost all its cooling. Is there a rest button?
Under the front kick plat on the bottom there is a device called a defrost timer.. these go out quite a bit.. also the coil cooling fan could have gone out which is allowing the conpressor to overheat and making the compressor shut down and not allowing it to cycle enough to keep it getting cold... check these things out..
May 30, 2008 | Maytag Refrigerators
Heating & Cooling Logo
168 people viewed this question
Top Goodman Heating & Cooling Experts
Paul Carew
Paul
Paul
Dennis Boxerman
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
