Question about Kohler K-3492 Purist Hatbox Toilet
SOURCE: Master bath toilet replaced with a Cimmeron class
Kohler is correct. The most likely cause of this problem is an obstruction in the common vent stack that both toilets share. When you flush the old toilet it need more air to flush and will get it from the easiest source (your new water saver toilet). First adjust the float level in the old toilet so it won't use as much water or just stick a brick in the tank to take up space.Second, run a snake down the vent stack from the roof to check for obstructions. Birds will sometimes nest in there.
Posted on Mar 16, 2009
SOURCE: Toilet won't shut off
Does it leak from the overflow? If so then the washer at the top of the Fluidmaster needs to be replaced. If it is not going over the overflow then you will need to replace the flapper on the flush valve.
Posted on Apr 11, 2009
SOURCE: Can't adjust flush time for complete flush, low bowl water level
flush time depends on how much water is in it,
the water level flote has an adjuster on it, but i cant rember were it is,,, sorry
Posted on Oct 24, 2009
SOURCE: Kohler Highline Class V tech toilet. Bowl does not
Check tank for fill line running from fill valve to overflow tube. It will be a 1/4 " line that allows the tank and bowl to fill. It should be connected from fill valve and connected at the top of overflow by a clip or hanger.
Check out the water level in tank to make sure it is filling to line on overflow or within 5/8" to top of overflow pipe.
Posted on May 29, 2010
SOURCE: Porcher 6.0 Lpf / 1.6 toilet. Plumber said he
Try replacing the flapper, they are cheap and so long as the tank and or bowl are not cracked you can replace all of the internal parts and basically have a brand new toilet much cheaper then replacing the entire unit. Go down to your local hardware store and everything you need is in one simple kit with very simple instructions. Good Luck.
Posted on Jul 22, 2010
Sep 22, 2017 | Kohler Home
Feb 08, 2014 | Kohler SAILE ELONGATED ONE-PIECE TOILET...
Aug 25, 2012 | Kohler Santa Rosa K-3323-55 Innocent Blush...
Jul 22, 2011 | Kohler K-3492 Purist Hatbox Toilet
May 03, 2011 | Kohler K-3492 Purist Hatbox Toilet
Mar 14, 2011 | Kohler K-3492 Purist Hatbox Toilet
Feb 09, 2011 | Kohler K-3492 Purist Hatbox Toilet
Jul 17, 2009 | Kohler Toilet - One Piece with Ingenium...
97 people viewed this question
