Question about Microwave Ovens
GE Microwave JES1656: The turntable on the unit has stopped turning. There is a regular clickng noise from the drive socket beneth the glass turntable. Can tis be fixed?
  • Microwave Ovens Master
  • 9,098 Answers
You can see and hear a video of how a turntable motor should sound when you rotate it by hand: http://www.microwavedisplay.com/blog.htm
If yours won't rotate or it sounds like it's grinding, etc., you may have a bad motor or plastic coupler.
To replace either, you need to unplug power, then remove the bottom cover of the oven, as you're looking up from the stove top.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
We're happy to help and we appreciate your thoughtful rating of our answer.
William E. Miller, AS-EET
prototech@usa.net
Posted on Apr 23, 2008
My ge micro will not stop turning
HELLO.
If by not turning mean turntable fault,the solution is given below in detail.
1 Press "Stop" to halt microwave operation.
2 Press the "Turntable" button once to turn off rotation.
3 Push the door-release button to open the microwave oven if you do not have a "Turntable" button on your control keypad.
4 Lift and remove the glass platter from the oven, then pick up the plastic track with three wheels below the platter. Set aside these parts.
5 Insert the elevated microwave cooking tray into the oven. The tray has three to four short legs that hold it above the bottom of the microwave, keeping it from interfering with the rotating bolt in the bottom center of the oven the drives the turntable. You can now place food on the elevated tray and cook normally without disrupting the drive bolt.
Thanks.
Sep 20, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
GE Spacemaker XL1800 Microwave
see for the turn table obstacle of any screw or something else.
Aug 04, 2008 | Samsung MW1030WA Microwave Oven
I have a GE Microwave JVM1842BD-001 and the turntable has stopped turning,I notice when I remove the glass tray the unit turns but very slow.
The problem is in the turntable motor it has become defective "common issue in a number of brands" the only solution is to have it replaced.
Mar 21, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
My turntable does not turn
The turntable motor in the microwave oven needs to be replaced.
Jan 24, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
GE SpacemakerXL Microwave oven clicking noise
Spacemaker t/t motors are very easy to change. Removed the screws from bottom of microwave. the bottom panel will found towards wall. Mtr is in very center of unit. Should have 2 wires going to it
Nov 21, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
I have GE JES735-BJ02 that heats but makes weird sounds like a rumbling sound.
It could be a failing fan motor or magnetron.
While a microwave should never be left running unattended under any circumstances (as your owner's manual will tell you) it's even more important when one is exhibiting a failure or any odd behavior. So play it safe and stay with it while it's running!
And, as with anything that is not working right, it should be fixed as soon as possible or it can get worse.
If it's less than one year old, it would be fully covered under warranty. I'd suggest contacting the manufacturer to get it fixed free.
GE Customer Service is here.
Let us know if we can help further.
Jun 27, 2009 | General Electric Microwave Oven
Turntable makes grinding noise and barely turns
Unplug unit and take bottom off of it with the screws that go around the outer edge. The turnatanble motor has 2 screws and is removabe from the bottom underneath.
Sep 24, 2017 | GE JES1851 Microwave Oven
Turntable stopped rotating.
this microwave has a turntable motor that can be accessed from under the micro.. usually a $15-30part.. put your modle number on partsdirect.com and you can see how it comes apart
Feb 28, 2009 | GE JVM1651 Microwave Oven
Glass turntable won't turn - spacemaker - XL 1400
Most likely a bad turntable motor - check with www.martinmicrowave.com for a replacement .
Dec 23, 2008 | GE JVM1440 Microwave Oven
GE JVM1650 truntable noise
Sounds like the turntable motor is going bad.
If you or a friend decide to work on it, we have *critical* safety, disassembly, and troubleshooting info at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk
You can find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
Nov 18, 2007 | GE JVM1650 1000 Watts Microwave Oven
Microwave Ovens Logo
236 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
