Question about Raymarine Raystar 120 GPS Receiver
Installed Raystar 120 as replacement for raystar 112. Display reads "no data". Had unit for a couple years before installing. Is the 120 downward compatible to the 112? I have the RL70 radar/chartplotter linked to seatalk.
  • sailortom Jul 17, 2010
    I've read on the net that the two are compatable.
  • 1,284 Answers
Hi, it is possible for you to use the 120 as a replacement for the 112. They are compatible but i don't understand what the display reads "no data"....
Take care
Posted on Jul 17, 2010
  • sailortom Jul 18, 2010
    read "no data" and "no fix". seems like you guys don't have a clue what is wrong. I'll fix it myself. Thank you and good bye. also giving false info "not compatable" causes me great concern.
  • Shehu Pro
    Shehu Pro Jul 18, 2010
    o.k..
  • 532 Answers
The raystar 120 download is not compatible with raystar 112.
Go to raystar website to download it manual.
Thanks.
  • Rahman Rufai Jul 18, 2010
    Sorry, i most apologize to you, this was a typographical error.what i mean was that Raystar 120 is compatible with raystar 112.
    Go to www.raymarine.co.uk/customer-support/.../navaid-manuals/ and down the manual for both raystar both use the same manual
    Thanks
There are 5 wires . What color wire go to sea talk and where do the others go?
From page 4 of the owners manual (link below), there are a couple of ways the cables could be connected depending on which setup you have.
Hope this helps.
-Steve
https://www.sv-zanshin.com/manuals/raymarineraystar125gpsownershandbook.pdf
Mar 11, 2015 | Raymarine Raystar 125 Gps Sensor
I lost the Manual for my C 120 GPS Receiver. Is there the Possibility to download the Manual
You can download and print the instruction manual in PDF format from the official Raymarine website by clicking this link.
On the page which opens, click on "Manual s & Docs" tab. The download the required manual.
Please note: Adobe PDF Reader is required to view this manual. Click here to download the latest version of Adobe Reader.
Hope this solves your problem. Thanks for using FixYa.
Sep 20, 2010 | Raymarine Raystar 120 GPS Receiver
My GPS Raymarine (installed in 2001) with Raytheon Raystar 120 antenna indicate offen a NO FIX. A technician tells me that there must be a problem with the antenna and that the best solution is to...
Before you buy a new one if that is a raytheon raystar unit there is a lithium battery inside the unit check that first thats all you may have to replace.
Sep 04, 2010 | Raymarine Raystar 120 GPS Receiver
I got a raytheon sl70 pathfinder gps that wont get a fixed signal the antenna is wired right but there dosent seen to be power comeing out of the cord that leads to the antenna. what should i do ????? i...
If you're using a raystar 125 antenna, you will have to power the red wire + and the shield wire - separately. Sl70's don't provide power over seatalk. Also make sure your green and brown wires are properly connected. If it's a 120 just power the red and sheild(black) and leave off the all except the yellow that's your data. If you still have nothing may probably have a problem in the antenna itself.
Jan 20, 2010 | Raymarine RL70CRC GPS Receiver
Machine does not acquire its GPS position. If it does it can take up to 45 mins to achive. Can I put an external antenna on it? The unit is used in an open boat, so has clear access to the sky, so should...
your antenna is probably original and obsolete see if you have a RayStar 120, if so, it is junk. The RayStar 125 is plug and play for you and sells around 300. Your GPS is a self contained receiver, that means it uses 12 V and output computer language. If you have no power to the seatalk antenna, you get nothing. If it is intermittent as you describe, 90% chanace it is the antenna, (mushroom or puck). 847-746-0100
Dec 28, 2009 | Eagle Seacharter 502c Df Igps T/M, Hst...
My Raystar 120 GPS keeps losing its fix.... the fix comes b ack a few minutes later, but then i lose it again. I have tried a cold restart, but the problem persists. Ideas?
Guys, most likely the litium battery is eol. Buy a new litium 3 volts battery for 3-4 euro's with soldering points . Use a pair of scissors, note the plus and minus side of the poles and carefully cut out the battery leaving enough metal to solder a replacement battery. Solder the replacement battery, and the problem is fixed. You're ready for another 6 years of fun saving 300 USD for a new GPS!
Oct 10, 2009 | Raymarine Raystar 120 GPS Receiver
I can't access dsm reset through fishfinder menu, it keeps saying no data source and I can't scroll down!
Check that there is power available at the DSM. Then verify that the DSM connector cable is correctly connected between the DSM and the C120. Finally, be sure that you have the most recent software version installed ( V 4.29). If all of that fails to bring back the DSM, try a factory reset. You accomplish this by holding down the first softkey while powering up the display. Hold the softkey until the reset countdown ends and the display begins to reboot. Be aware that a factory reset will delete any waypoints, routes, etc. so be sure to back upp anything important.
Sep 25, 2009 | Raymarine C120 System Pack C120 Raystar...
Raymarine C120
You need to download the latest software version from raymarine.com which turns on nmea2k.
Jul 24, 2008 | Raymarine C120 System Pack C120 Raystar...
Cable to another screen?
No. It is not a networkable unit. That's why they made the E-series
Jul 07, 2008 | Raymarine C120 System Pack C120 Raystar...
Raytheon rl70
I've had the same problem. before replacing the antenna, try to reset the antenna by removing power to the Raystar 120. Disconnect power by either turning off all batteries or disconnecting the red wire from the antenna at the point where it enters the junction box for the chartplotter. This action effectively removes all memory from the antenna and resets it to factory settings. There is a lithianium battery in GPS antenna that holds memory data in the antenna. Disconnecting the power to the antenna for a few seconds clears the memory.
This is exactly what I did and when I turned the chartplotter back on, my Raystar 120 immediately began working again.
May 05, 2008 | Raymarine RL70CRC GPS Receiver
GPS Logo
341 people viewed this question
Top Raymarine GPS Experts
Steve
Steve
Jon Piercy
Are you a Raymarine GPS Expert? Answer questions, earn points and help others
