One or more of a couple issues is at play here. First would be the seal replacement. Even if you used the correct seal if you touched the surfaces or failed to install it properly it can and will leak. Second, inspect the housing around the seal fit and the stem of the impeller for cracks. A hairline crack is enough when placed under pump operating pressure to allow a leak. Somewhere in there is your solution.
John
Testimonial: "John: Hi! Thanks...maybe it could be the surface was touched....and maybe the spare motor had a worn seal. The fact that both were leaking in exactly the same place is a mystery. I took the motor I worked on to the pool vendor for an exam. Thanks for your feedback...it was helpful. ndmc"
