Question about Brother MFC 210C All-In-One InkJet Printer
After inserting a new black ink cartridge the only things that print are graphics and text art. I have done the troubleshooting tasks and the printer still doesn't print.
  • 11,800 Answers
Do this: keep the pc on; remove all 4 cartridges and start the printer for 5 minutes- ignore the error message; put the old cartridges back and try to print something; put the new cartridge in. That should be enough, the printer has been reseted.
Posted on Jul 17, 2010
  • 2 more comments
  • sunshine_rae Jul 17, 2010
    Hi, I kept working on the problem and found a solution. I put the printer through several cleaning cycles and now it prints. In fact, even the colours are brighter. Thanks for your help. Rae
  • Azrael SRL Jul 17, 2010
    If this has happened it's because the ink is old or of low quality. Either buy a better one or from now on make sure to regularly  do a thorough clean of the heads at least once a week.
  • sunshine_rae Jul 19, 2010
    Good idea. It is the manufacturer's ink and it is changed qute frequently.
  • Azrael SRL Jul 19, 2010
    If it's original ink then surely it dries in the cartridge because you don't use the printer enough. As i said you have 2 options - either use the printer at least once every 2 days or buy a much cheaper compatible cartridge and replace it more often.
False ink empty
Are you sure its exclamation mark?..
This warning message related to print head. (warn out). When you are replacing ink tube assembly use dummy print heads to do the priming (new ink tubes are empty & they have to fill with ink)..
Action: Remove all cartridges and print heads, switch on the printer follow the screen message.(Insert cartridges first next dummy print heads).once its recognizes cartridges then it switch over to print heads,insert dummy print heads. Once printer recognized the dummy print heads, printer will perform priming, during priming dummy print heads will filled with respective inks.(follow the display message)Remove dummy print heads & insert normal print heads. Wait till printer recognizes print heads, load the paper & wait till performs the calibration, once calibration is successfully done issue closed.
If calibration not successfully done, check align print out for which print head is not printed properly, replace it..
Pl ensure that minimum 50% ink levels required in cartridges before performing the priming. Best of luck..
Dec 03, 2012 | HP DesignJet 500 InkJet Printer
Does not print dark enough to read. Changed toner and adjusted print darkness feature. Still does not work. Any idea what to do?
Hi
When printing, just adjust the PRINT QUALITY to PHOTO because I believe your print quality is set to TEXT. I am sure it will print move darker than before.
I hope it helps you solve your problem.
Regards
Feb 15, 2011 | HP LaserJet 3030 All-In-One Printer
I cant seem to print text. i can only print graphics. i recently put in new ink cartridges, tried to print a page of only text and the pages were blank. tried to print another page with text and graphics,...
Have you tried printing text in different colour if that works the black jets are blocked- try running the cleaning cycle to clear (it may not use black ink in graphics)
Nov 15, 2010 | Brother DCP 130C All-In-One InkJet Printer
Printer will not print text. will only print picutres and graphics and text on graphics. just replaced the black and white cartridge.
It sounds like you are either out of black ink or you have a clogged black printhead. Perform a nozzle check/test page, then do 3-4 printhead cleanings. Run another nozzle check/test page and compare it to the first one. If you see improvement, keep cleaning your printheads until the black printhead is unclogged. If you do not see any improvement, you may need to replace the black ink cartridge. (I am assuming that your printer uses a tri-color and black ink cartridge) Replacing the ink cartridge will give you a new printhead (attached to the ink cartridge).
Jul 05, 2010 | Computers & Internet
6180 will not print black text
Are you using genuine or knock off inks?
Take out the blabk cartridge and knock in onto your hand while using a paper towel to absorb ink.
If ink comes out you have a communuication problen with the printer ink carriage or a defective cartridge.
Jul 21, 2009 | HP Photosmart C6180 All-In-One InkJet...
Black ink not printing
Fix ink cartridge
I had same problem. I must have ran the clean cycle more than 30-50 times over a period of days. That never made any difference. I was about to toss the whole thing but figured I would try one more thing. If it didn't work I would be in no worse shape. Here is what I did.
Took an almost empty black cartridge and inject a lot of 100% Acetone to dilute ink. Left some black in it since I didn't want to think it was empty. Inserted this cartridge and ran the cleaning a few time. IT WORKED. I used my word processor program and filled a page with large bold font characters and printed a page or two. Each page cleared more nozzles. After doing this cleaning/printing a number of time, I put in the full good cartridge. Ran the cleaning a few time to eject any of the Acetone diluted ink. Ran the printed page a few time to remove more of the diluted ink.
Everything seems to work now.
Apr 20, 2008 | Brother MFC-5440CN All-In-One InkJet...
No text
Check that your black ink cartridge has ink inside, eventually try a new cartridge , as ink may have dried up in old cartridge.
If you use a new cartridge ensure you removed cellotape from cartrige.
If cartridge is ok, then it is printer nozzle/head for black ink.
In this case do nozzle check / head cleaning in printer tools a couple of times.
If problem persist you may need to check and clean printer's head with cotton and solvent.
regards
Mar 20, 2008 | Computers & Internet
Use of black ink
My husband answered this for me- it takes different colors to make black, therefore it uses some of the color ink
Jan 16, 2007 | Canon Pixma iP6600D InkJet Photo Printer
Brother MFC 210C All-In-One InkJet Printer Logo
138 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
