Question about Logitech Televison & Video
A logitech product that has one end ps2 connector and one end usb connector and these connectors are linked at a one point where there is led and button
    President:
  • 2,571 Answers
Just google ps2 to usb adaptor
Posted on Jul 17, 2010
W7 using dongle ps2 to usb
If you are trying to convert your Logitech Trackman Marble FX from PS2 to USB so it will work with Windows 7, you can't just convert the port type - you have to get an "adapter" that converts the PS2 signal to a USB signal. See for ATen - UC 100KMA. WEB SIte:
http://www.aten.com/products/KVM/KVM-Modules-&-Accessories/PS2-to-USB-Adapter~UC100KMA.html#.U5sYrCi4NAE.
It allows you to convert a PS2 keyboard and PS2 mouse/trackball with the one device. It's what I use and it works just fine. The regular $2.00 port adapter was useless.
They are on EBAY sometimes for $20 or so. GOOD LUCK. :)
Feb 14, 2014 | Logitech Trackman Marble FX Trackball
How to convert ps2 cunnector to USB connector in ncx 2000-xp
You can buy devices to convert USB to PS/2 like this.
http://www.newegg.com/Product/Product.aspx?Item=N82E16812150091
You might just be better off upgrading to a newer PC if you're able to do so. Good luck!
Dec 31, 2013 | NComputing X300 3 User Expansion Kit...
Logitech mouse left button does not work
That is a circuitry problem. You can try this following procedure if you can. --unscrew and open your mouse casing. --you need a tester (VOM) to test the wiring continuity. If one of the wire is open connection you can replace it with a new USB or PS2 connector. If all the wire is shorted, proceed to the next step. --Check if the microswitch is ok by testing the pin connection using the tester. Microswich has 3 pins, test only the soldered pins. When you press the switch, it might be shorted. If not, replace it with a new microswitch.
Microswitch and USB/PS2 connector are available in all electronics shops.
May 27, 2011 | Logitech Computers & Internet
USB Keyboard and mouse wont work with PS2 KVM with adapter
Have you tried rebooting once it is connected? Not sure if it makes a difference, but I know you can not hook up PS2 peripherals without rebooting.
Nov 03, 2009 | Dell OptiPlex GX280 PC Desktop
My dell sk8110 keyboard has a round purple connector plug that fit my old computer. My new computer has only USB ports. How can I connect my keyboard to the new computer?
http://www.microcenter.com/search/search_results.phtml?keyword=usb+adapter+ps%2F2&category=
The round purple connector is refered to as "PS/2" type connector. You can find an adapter that converts PS/2 to USB connector. The above link was just to show what I was refering to. Hope this helps.
Aug 24, 2009 | Dell SK8110 Keyboard
Usb keyboard not support windowsxp
You using a USB connection wtih a USB cable from Logitech? And, did you keyboard come with a USB to PS2 adapter plug.
Because you would have to use this adapter and then install the Logitech software, once that is done you can shut down and use the USB connector from that point onwards unless you would just feel more comfortable with the PS2 connector.
Otherwise you will need to borrow or use a PS2 keyboard boot up into Windows, install the logitech software, shut down and then try attaching your USB keyboard and you should be fine after that.
Regards,
Worldvet
Please don't forget to rate our solutions on FixYa, thanks.
Jun 25, 2008 | Gigabyte GA-8LD533 Motherboard
Instructions state------plug in PS/2 adapter on desktop
You can simply remove the PS2 adapter from the end of the cable to use the USB connector instead.
Remove the green part and use the black USB connector instead.
Apr 09, 2008 | Logitech LX5 Cordless Optical Mouse
Optical mouse doesn't work
try to insert usb mouse maybe the ps2 connector fuse was defective
Mar 28, 2008 | Logitech Cordless Mouse
Televison & Video Logo
Top Logitech Televison & Video Experts
Greg Ulan
Jerry Umali
Are you a Logitech Televison and Video Expert? Answer questions, earn points and help others
