Question about Whirlpool Duet GHW9150P Front Load Washer
I have a Whirpool Duet Washer Model WFW9200SQoo It's Giving me an Error Code of F28 Does anyone know how to fix??
  • 10,515 Answers
F28 is a serial communication error between the motor control and the machine control board.
The Check all connections between the boards--- if everything looks good 95% of the time the board that is bad is the machine control board NOT the motor control board. Replace and access this part by taking the top panel off--- it is held in by a few screws coming in from the back holding on the top of the unit.
If you are not very handy or a mechanic you may want to have a hands on tech do this work. As per service manual , the solution is given as :-
Possible Causes/Procedure
1. Unplug washer or disconnect power.
2. Check wire harness connections to the MCU, the motor, and
Central Control Unit (CCU).
– Check connections of the CCU board within the housing.
– Make sure all grounding switches are engaged.
3. Check the drive system for any worn or failed components.
4. Plug in washer or reconnect power.
5. Verify CCU operation by running a Diagnostic Test or any
cycle.
6. Check the MCU by looking for operations of the drive motor.
7. Check the drive motor for powered rotations.
8. Check that the serial harness at the MCU is not mounted
upside down. The wires should be to the left when facing
the MCU connectors.
However, i would strongly recommend that you should call technician for this Error as this is quite tricky and needs some good intelligent guess on the basis of the diagnostic tests.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Jul 17, 2010
I have an F28 error what is wrong
As far as I know F28 error code means - SERIAL COMMUNICATIONS ERROR/MOTOR CONTROL UNIT ERROR. Caused by either a communications problem between the Central Control Unit and Motor Control Unit, or Motor Control Unit internal failure.
Jan 12, 2015 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet Sport Model WFW8300SW0 basket won't
The following list of codes indicates an electronics communication problem with the washer: - Duet HT washer - F01, F03, F06, F11, F23, F24, F27, F28, F29, F30, F31, F32, F35, F42, F61, F62, F63, F64, F65, F70, F71, and F99
If Pause/Cancel does not work:
  1. Unplug washer or disconnect power for one minute.
  2. Plug in washer or reconnect power.
  3. Re-select the cycle and press Start.
NOTE: If the error remains on the display, call for service.
I would first replace the door latch/lock assembly, a number of users have and it fixed the F-11 error code completely. Its the cheapest part for this problem.
Hope helps.
Jun 27, 2011 | Whirlpool Duet Sport HT WFW8400TE Washer
Fi pops up on my front load whirpool duet model wfw9200sqoo. and wont finish the cycle. unless we manualyput in rense and spin mode and somtimes unplug it, and reset spin mode,, and somtimes like today...
Frontload failure code
F-1= EEprom error due to:
power glitch
remedy: unplug washer for 2 minutes
if error exists replace CCU board
Causes:
Pump driver failure to activate on CCU.
Main Relay stuck on CCU.
Relay points welded or open on CCU. Bummer.
DUET SERVICE MANUAL AND MORE HERE
Jan 25, 2011 | Whirlpool Washing Machines
Code f28
Hi, the error code F28 means one or both of these parts are bad.
  • Motor Control Unit (8540135)
  • Microcomputer Machine Control Unit (8540788)
It would be a good idea to order both, as both components have been problematic for error code F28. If you find either the MCU or the CCU(Microcomputer Machine Control Unit) fixed it.
Oct 02, 2010 | Whirlpool Duet GHW9150P Front Load Washer
My Whirlpool Duet front load washer is giving a F 11 error.
power failure--------unplug the unit for 5 minutes and see if it clears that code
Jul 26, 2010 | Whirlpool Duet GHW9150P Front Load Washer
I washed a large load in our Whirlpood Duet Washing Machine and it stopped with a flashing F28 code. I unplugged it for 5 minutes and it still will not run a cycle without stopping with a flashing F28...
The error code F28 means one or both of these parts are bad.
You can download the online repair manual in the below link
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/6545d78b3f479480852571650061b1ba/$FILE/8178558.pdf
On page# 4-20 it shows how to access your MCU.
Jun 27, 2010 | Whirlpool Duet GHW9150P Front Load Washer
F28 code washer stops working. Reset will only
Error code F28 indicates that one of the below part is bad
If you find either the MCU or the CCU(Microcomputer Machine Control Unit) you can fix it,
Here's the online repair manual for Whirlpool Duet Sport, but its identical to your HE2.
Refer page# 4-20 it describes how to get to MCU.
May 04, 2010 | Kenmore HE2 Plus Front Load Washer
Error code f35 on my washer
Duet HT® washer - F01, F03, F06, F11, F23, F24, F27, F28, F29, F30, F31, F32, F35, F42, F61, F62, F63, F64, F65, F70, F71, and F99
Duet® washer - F05, F07, F09, F10, F11, F13, F14, F15, F21, F22, and FdU
Duet SportTM washer - F01, F11, F23, F24, F27, F28, F29, F30, F31, and F33
To remove the error display, press Pause/Cancel twice.
Dec 19, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpoo; wfw9200 F22, F28, A17 A27 error codes
f22 is a door lock error and f28 is a commication error you still have warranty thorugh whirpool. you're going to need pro. help
Dec 13, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
52 people viewed this question
Dan Webster
Dan Webster
Sal De
